A cross section is in fact a slice of a ship which is sawn out of it. I want to up light all the kerfs by painting them in red. On the lower deck a piece of deck remained to  support the stairs, where the deck is cut, the kerf is painted in red.
Now the gun deck structure has to be re-puzzled. I start with the gun deck stanchions. They will be kept on position by a bamboo pin on the foot and at the top. The deck beams are glued on top of them.
I will now make the forward hatch ladder. Because there is always a slight difference between the plans and the execution of those plans, I take the dimensions of the ladder immediately from the model.
The stringers are 2.5 mm thick, so I plane two planks to that thickness (2 because there have to be made 2 stringers in mirror image). I set my table saw for a thickness of ±1.2 mm and saw the grooves for the steps. Some time ago I made a simple table saw sled on which I glued a piece of millimeter paper, that makes it easy to saw the groves exactly parallel and with the correct intervals.
The ladder looks great ,I will try to use your technique when I get that far .thanks for the detailed post.
Derek
Derek C
Quote
A man without a goal is like a ship without a rudder --Thomas Carlyle
Current Build
18th Century Whaling Vessel "Lagoda"
Finished Builds
Triton Cross Section by Derek C 1/48
18th century longboat by Slideways - FINISHED - Model Shipways
18th century longboat by sideways from MS plans
I make the grating in walnut because it is a better wood than oak to saw out little pieces. I start to saw 3x3 mm thick planks and I glue them together with a drip of wood glue at each end. Like this they form a 3 mm thick plank.
On my Proxxon saw table I like to use a table saw sledge on which a millimeter paper is glued with the 0 mm line exactly on the saw blade edge. With the help of that sledge it is easy to saw 3 mm wide grooves of 1.5 mm deep at 3 mm intervals.
In the grooves I glue 3 mm wide and 1.5 mm thick laths.
I start at the outsides and form the grating on a piece of mm paper to be able to glue the laths at 3 mm interspaces
I glue them together using the same piece of millimeter paper as before to obtain right angles. I let the glue of the hatches dry with some weights on top of them. On completion I check them on the cross section.
