Onto construction of the 3 masts and bowsprit.
The cross tree timbers that hold the fighting tops are extremely brittle. And one wrong move can mean a split or a snap.
The masts caps are made of a hard metal painted black. And some filing and sanding with light emery paper had to be done to remove the unsightly burs.
To fit the caps on, The tops of each mast segment had to be squared off  to fit the square hole in the bottom of the metal mast caps.
Further on the segment between the fighting tops and the masts cap had to be squared as well.
At this point all the blocks for the running rigging were attached now while the masts were easy to work on before installing on the ship.
Pictured here is the main mast, Fore mast in the background. Yet to be fabricated is the Mizzen mast.
Regards, Scott
Completed builds:
Awaiting construction:
Masts completed with all blocks in place. Hull had also received two coats of "Off White". And the rudder chains also added.
Stern lanterns assembled and installed. If you with me to take any real close ups of a particular area or time of build please let me know:D
Regards, Scott
Completed builds:
Im unsure of the rudder hinges. I have the two above the water line painted black. Should I paint the hinges all black? What are your thoughts?
Regards, Scott
Completed builds:
I like what you've done there, Scott. I'm no expert but I would imagine that the "white stuff" anti fouling mix would be slapped over everything prior to launch. Including the rudder hinges. The hinges above the waterline would remain black.
Cracking build by the way.
Grant
Cheers Grant. Thank you for your comment.
That's what i was thinking. On my previous builds I have simply painted them black like here on my mamoli Rattlesnake, Blue Shadow and HMS Bounty.
I like the look of them black but I want to change my ways to be more realistic of that period. Thanks.
Regards, Scott
Completed builds:
You're right to have them white. They would have painted the entire hull below the waterline with white stuff. Have included a pic of Endeavour high and dry for you.
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Absolutely beautiful photo Cheers.  I have a massive framed picture of the Endevour sailing. She is a beautiful ship.
Regards, Scott
Completed builds:
I shall leave her the way she is then. Cheers for your input guys.
Regards, Scott
Completed builds:
A few shots of Bow, Stern and overall shot. I think its looking good.
Regards, Scott
Completed builds:
In the first photo it shows the 4th band of rope up the fore mast abit on the side. So this has since been removed and rewound. Hope you all like.
Regards, Scott
Completed builds:
She does look fantastic, will be great to see it along side my Sovereign once she's completed being approximately the same scale.
Anton T
Current build
Yes not much between them scale wise. Still fair bit of work to go yet.
Regards, Scott
Completed builds:
Definitely on mine haha!
Just cut the first ports wow what a headache I'll post later once I've done the port side.
Anton T
Current build
Lookin' good, Scott. It would be most interesting to see yours and Anton's Sovereign battlin' it out on Lake Monger.
:cheers:
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Hahaha for sure
When I get a chance I'll pull out my 1/72 arleigh Burke for a size comparison (still in the build process also but the hull and superstructure are complete).  Something appealing with having the models at the same or close to same scale.
Anton T
Current build
Cheers guys. I have back logged up until about now. So the build will progress slower now. Cheers for all the likes and comments.
And it's off to a start in the Rigging. Starting of with all the ratlines, backstays and  main mast supports.
I use CA to harden the ends of the threads to make it easier to pass through blocks Deadeyes etc.
All the knots on all are held by 50:50 PVA glue.
Regards, Scott
Completed builds:
Close up of Deadeye assembly.
Regards, Scott
Completed builds:
I always start ratlines with the mizzen mast first. And work my way towards the bow. Anybody eles do this or is it just me  :P
More to come soon.
Regards, Scott
Completed builds:
I do the same Scott,
Start with the mizzen and work forward.
The only thing that i see is that the rope you are using for the lanyards are very fuzy.
Maybe you can change rope or using beewax?
Sjors
Thanks Sjors. Yes I notice the too. I have been using beeswax but I'm sure I didn't put enough on.
Regards, Scott
Completed builds:
Ratlines continues. Very repetitive but progress is showing slowly.
Regards, Scott
Completed builds:
Ratlines! Oh how I hate those haha. It's surprising though how after one set of shrouds it changes the appearance so much.
Anton T
Current build
Your not wrong Anton. It takes the build on a completely different journey.  It makes constructing the hull seem such an easy task.
Regards, Scott
Completed builds:
Thanks Sjors. No knots in my ratlines.   I use a thickend diluted white glue. And the ratlines are simply glued into place. Dries clear and no staining.
Here is a veiw of the fore mast. The futtock shrouds are not attached yet and are just dangling.
I know you can't see knots with this method but I like the look.
Regards, Scott
Completed builds:
Here is another shot.
Regards, Scott
Completed builds:
Main mast futtock shrouds and more ratlines.
Regards, Scott
Completed builds:
It looks like the Port side futtock shrouds are not attached at the same height as the ones one the starboard side but they are. After taking this pic I had to check actually. Must be the way I took the photo.
Regards, Scott
Completed builds:
That's an interesting way of attaching the ratlines Scott. Especially to come out so uniformed and neat.
Anton T
Current build
