Thank you Sjors. Itso coming along great.
Regards, Scott
Completed builds:
Awaiting construction:
Better than I expected anyways
Regards, Scott
Completed builds:
Don't worry. Havnt posted for abit, But everything seems to be happening at once. (Life in the way again)
I have however been tying blocks to the yards. Not enough progress for a picture post though.
Regards, Scott
Completed builds:
A new cutting mat was brought as the old one was way past its useby date.
When I get home from work will try to add a few more blocks and let's see if I can make a post out of it.
Regards, Scott
Completed builds:
Here I have some blocks attached. Abit fiddley trying to get them to all face the correct direction but I got there.
Regards, Scott
Completed builds:
Oh and my new cutting Mat.
Regards, Scott
Completed builds:
Violin blocks on the lower main and lower fore yards. The rest are normal blocks large and small.
Still have to attack blocks on the ends of the mid and top yards.
Regards, Scott
Completed builds:
My little snaplock container seals my rigging glue and does a great job. Every now and then I replace with fresh batch of 50:50 white glue and water.
Regards, Scott
Completed builds:
Painted yards black tonight. And added more blocks. Will have an update shortly.
Regards, Scott
Completed builds:
All painted up. Not far off installing them on the ship.
Regards, Scott
Completed builds:
Another milestone! Main mast with lower and mid yards placed. :)
Regards, Scott
Completed builds:
Ok so now it's confusing.
The line (466 Dark line) that supports the yard (312) runs from the yard, Up and over the Donkey head (mast cap). And then from there, Down to a violin block belayed the the deck.
Thats straight forward on the plans but there is no way I can run the line through the Donkey head as shown in the plans.
The Donkey head is made of very hard metal and drilling is not an option.
There are no holes or sheaves to run the line over.
I could go over the front but that will look bad.
Regards, Scott
Completed builds:
Is it possible to drill a hole directly under the mast cap? Probably a stupid question, if you have no other options.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Cheers John for your input.:)  No its not a stupid question. Unfortunately it is in a real hard to get to place with all the ratlines in place. And the only drill I use is an arcmedian drill.
Even if I had seen this before construction of the masts, It would of been tough to get a hole through there. The rest of the yards have this line simply drilled through the masts as shown in the pic.
So as the only option I see I will have to follow suit with the rest of the yard rigging.:blush:
Regards, Scott
Completed builds:
Turns out John your idea is exactly what the rest of the pans read. Thank you for the tip.
Have attached the parrel beads and cleats.
Regards, Scott
Completed builds:
Hopefully will make a start on the fore mast yards after work.
Regards, Scott
Completed builds:
Have the foremast yards shaped and sanded. Making up blocks for them.
Regards, Scott
Completed builds:
So... busy tying more blocks. I have the lines from the center of the yards down to their respective Belaying pins. Coiling the excess rope as I go.
Here are the first three ropes belayed.
Regards, Scott
Completed builds:
More rigging going on. Slowly but surely.
Regards, Scott
Completed builds:
Main mast and fore mast has all of their yards attached and raising and lowering rigging attached.
Regards, Scott
Completed builds:
One thing I have noticed before I do anymore rigging on the bowsprit, it needs to be darkend to suit the rest of the masts.  It's too light a colour.
Regards, Scott
Completed builds:
Work has called me away over to Queensland for 1 month so sadly no more updates for a little while.
A big thank you to all who are following this build and your comments are much appreciated.
Posts will commence when I return.
Regards, Scott
Completed builds:
Have a good working trip Scott!
Your updates of the spars abd blocks are beautiful.
Thanks for that!
We will be waiting for your return.
Sjors
Well its been almost two weeks away from my most loved Friesland. Been missing it. Have just received word our job is complete here in Brisbane and are now scheduled to fly home to Perth tommorrow!!:36:Two weeks early!!  So looks like an update may be in the pipeline  sooner than expected.
Regards, Scott
Completed builds:
Hey guys. I'm still here. I have been tying blocks, waxing thread, You know the boring stuff. Nothing really noteworthy of a pic post. But yes. The work continues.
Regards, Scott
Completed builds:
More and more blocks.  And also some more rope coils. This time it's the fore mast.  A similar pic is of the main mast Belaying pin racks. Not the most exciting part of the build but it all adds up.
Regards, Scott
Completed builds:
Forgot to mention the blocks still need to receive the seizing.
Regards, Scott
Completed builds:
I am late here, but nevertheless receive my congrats for a job well done. You are nearing completion. Keep up!!!
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
