very good, every day better !!!
Lupo nero
_______________________________________
finished models  Carrack Santa Maria by luponero - scale 1/50 - diagrams of Adametz
https://modelshipworld.com/topic/19739-carrack-santa-maria-by-luponero-scale-150-diagrams-of-adametz-finished/
models under construction Athenian triere of the 5th century B.C  https://modelshipworld.com/topic/25956-athenian-triere-of-the-5th-century-bc/
  San Giovanni Battista 1598 by luponero - Medicean galleon  https://modelshipworld.com/topic/25930-san-giovanni-battista-1598-by-luponero-medicean-galleon/
Hi Oliver, Nice build so far.
I am sure others will correct me if I am wrong but I think that you have built up the anchors wrongly.
The wooden stock should be perpendicular to the flukes, rather than parallel as you have built them.
Hope this helps, good luck!
Completed Build --- Virginia 1819 - Artesania Latina
Other Models      --- German Armor plus others    Mastermind
Current Build --- Liveship Vivacia
That it quite right! I have noticed the mistake and will correct them. Thank you for your input!
Guys I need your help again. I do not know how to link the two blocks in the pictures. One of them is on the mast the other is on the yard. The instructions are telling me that they must be linked somehow with a line in order to further put it throw them in the small holes. How can I link them??
20 minutes ago, Oliver24 said:
Any ideas how to link the lines?
If you mean joining the two blocks in your first diagram with the letter A,  I think you need to widen the gap between them then wind some thread round and through them like in the diagram.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Oliver, you need to wrap another line around the block that is attached to the mast, just like you have done already. The other end of this new line goes down, through the block attached to the yard, back up, through the block attached to the mast, and then down to the belaying pin.
Hope that helped.
A have made a little progress. I have attached the boat and the necessary rigging to it. Also, I have attached the fences. It was a tricky process due to the fact that I have introduced a 0,7 mm wire in them in order to ensure better stability. I used some wood glue also, of course.
Realy nice work.
OC.
Current builds
Completed works.
Very nice work.
OC.
Current builds
Completed works.
  • 1 year later...
