Lami,
Just came across your build log and she really is stunning!  Like Michael Mott (post 17) I cannot see any pictures on the 1st page of this log & I'd love to see some more detailed pictures of her, especially how you've designed the running rigging and set up the sail servos/winches. Also, how many rc channels are you using to control her?
From your most recent pictures she certainly appears to sail well even if she is a little 'light' at the moment.  I've always thought that scale sailing models always look so much better without the addition of an external fin & bulb (or just additional ballast bolted to the underside of the keel). Despite that, it may be worth reading up on the differences and applications of 'centre of effort' for the sail plan, 'centre of lateral resistance & gravity' for the hull, centre of bouyancy and most importantly something called the 'metacentric heights'. I only mention these as nearly every square rigged rc ship that I've seen (predominantly on youtube) has needed the fitting of additional external ballast to enable them to be used in anything much above a couple of knots of wind.  All this only becomes important owing to our ability to produce wonderful scaled models of fabulous vessels but our inability to scale environmental factors like wind!!
I look forward to seeing more of your incredible model sailing the high seas!!
Regards,
Row
1:28 Scale J class yacht 'Enterprise' (R/C)
Build log currently at: http://www.rcsailing.net/forum1/showthread.php?6264-1-28-J-Class-Enterprise-build-log
There are some additional points I would like to make in regard of the sailing stability of models. The sail area is only reduced in square but the hull volume is reduced by cubic based on the scale, so for each sailing model the sail area will always be much greater in comparison the the hull volume as it was with the original.
This males it very likely that a below kneel ballst is required.
  • 1 year later...
"HMS Banterer" on the lake,
very impressive pictures Lami, a wonderful model under sail....
Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 years later...
Hi Lami,
I'm a volunteer researcher with the Chatham Dockyard Historical Trust in England. I've just completed a short biography of the captain of Banterer, Alexander Shippard, and wonder if you'd be prepared to let me use one of your photos as an illustration. If so, can you let me know how you'd like to be acknowledged?
I'd also be interested to know where you managed to get design information on the original ship - I've not been able to find anything!
Regards,
David
Hello David,
There are plans for Banterer in the National Maritime Museum, collections ADBB0595, ADRB0126 and ADFB0016.
Regards,
Bruce
STAY SAFE
current builds:
David, quite right, sorry about that.
These are for Banterer class craft of the right era although not built at South Shields:
J4309, J4307, J4305 and J4310.
Bruce
Edited by bruce d
STAY SAFE
current builds:
… and here is a plan of CYANE, another sister ship, as she was when captured.
STAY SAFE
current builds:
Bruce,
That's fabulous - if Lars isn't happy for me to use his photo, that Cyane plan will do the job; saves me a trip to Greenwich!
So that I can reference it properly, can you let me know where you found it?
Regards,
David
Hello David, I found it on the Games Lab Forum, sadly without a source.
https://forum.game-labs.net/topic/19749-proposed-british-kickstarter-pack-with-plans/?tab=comments#comment-393240
It is near the beginning of the long thread described as '18 Guns Ship'.
Regards,
Bruce
STAY SAFE
current builds:
