I have been by the sail bug of late and nostalgia and ventured back to my youth when I made just about all of Revell sailing ships.So I picked up the USS America simple get my feet wet again with the rigging and such.I p/u from HISmodel the wooden deck and block/pulleys which the pulleys will be a new venture for me I have dealt with wood decks on the Eugen.I have the hull,decks and the mast are just about finished in painting just a little bit more.Russ lives like three houses down and says the black iron on the rudder goes so that be fixed and I went with 16' planks right or not I don't know but I mark them lined the ends and nail.I have seen alot of these decks with one nail hole ? call it my personnel   interpretation ;) Kevin
Now were I am at as of now.The blocks from HISmodel and I made the grates for the hatch looks much better than the plastic in the frame and the deck has two coats of semi-gloss water base clear I like for indoor furniture.The mast I tried something we use on WWI propellers to simulate a wood grain using oils not enough grain effect came through then I sprayed over it with a orange acrylic clear diluted with yellow to try and highlight and give depth(still need more practice at that).The rings will be taped off and sprayed black or burnt iron and can anyone answer about the metal on the mast heads black?
A small update is in order.I have been playing with the mast of late and experimenting with and enamel base then using a mixture of of a not quite golden brown and umber in oils to simulate the wood effect.The next step is to go over the oils with a clear acrylic clear mixture of red and yellow thinned and airbrushed on to your taste the pictures do not do it justice but they do look a bit like wood.The bowsprit just came out to dark but I leaving it as such since all pieces did not come from the same tree or type I would think.The rings on the mast were all taped off ( @#% ) and  painted with MM Metalizer  Gun color and sealed with a clear.
very nice bevy of boats :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
