How would the clewline be attached to the Topsail Yard ?
1) By an eye then lashed to the yard.
2) By an eye with the running end passed through the eye
Lees shows the second option but that is on a model from 1692. The pix of other models are not really
clear enough to see an alternative.
Thanks,
Dave :dancetl6:
Good Evening Dave;
Depends on the size of ship and the date. Can you give us a bit more information.
All the best,
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
Here is an illustration from Mondfeld, as well as a grab from Chuck's build log.
The line would be seized to the yard, then lead through the blocks as seen in the drawing.
Clue1.JPG.5c2137b88f4c53396e55e816a0484a49.JPG  727175633_clue2.jpg.6138e37695e3d3c0f37ec7a29a41fcc5.jpg
Edited by Gregory
― Jimmy Buffett
Slow crawl:    Rattlesnake
Thanks Gregory,
I will just form an eye and sieze the Clewline to the yard. The Mondfeld
illustration and Chucks rigging plan don't actually show how  it's attached to the yard. Also
Lees doesn't say how in the text in his book. Likely standard practice and not worth mentioning.
Mark,the model is of the cutter HMS Cheerful scratched from Chucks' plans.
Thank you,
Dave :dancetl6:
Thank you Allan and BE,a timber hitch it will be. I have Andersons' books didn't think to look in there :(
Spyglass,lovely photo's,thanks for posting them.
Kind regards,
Dave :dancetl6:
