HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Hey out there in knowledgeville, can anyone tell me if that plumbing on the aft end of the boiler (Detail 1-6), is supposed to be a water level sight glass? I would think so but before I go trying to dig up research, I figured I'd ask here, thanks in advance, John D. AKA Sea Hoss.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Hi Ron, thanks for the speedy reply. I'm referring to the plumbing on the right side, thanks again.
I found that it is a sight glass explained in the instructions. Missed it in the first reading, thanks anyway.
Thanks guys, always better to make sure! It is a nice relaxing build...
What kit(?) is that ? The boiler seems to be very rudmentarily fitted, going by the drawings above. There is no fired door and the wood lagging should not cover the fire-box (where is it actually ?). There is no pressure gauge, etc.
Wefalck,
It's this one from Model Expo.   There's several builds going on and completed so I just grabbed the first one that popped up.
Ah, ok. It is a rather simplified version of a 1860s picket-boat fitted with a spar-torpedo.
The pictures indicate that the boiler is of the return-flue type, stoked from the smoke-box side. Most of the time such picket boats had a locomotive-type boiler that is stoked and operated from the same side I think. The fire-box is totally encased in the boiler, which explains that the lagging is going all around.
The prototype boilers would have had much more elaborate fittings, with double sight-glasses, double check valves, double feed-pumpes, manometer, safety-valve, etc.
