The casing
the casing is now finished the model set inside and this closes the build log
Nils
Current builds
-Lightship Elbe 1
Completed
Looks lovely Nils - where is it going to be displayed?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Many thanks Keith,
it is already displayed in my little private museum together with 8 other models...
The Gorch Fock model had (in lack of place) to be DSCI9036.thumb.JPG.93e174a9c9b2ab58f483d9727b320661.JPGmoved upstairs to my attic office
Nils
Current builds
-Lightship Elbe 1
Completed
Nils, that is one impressive office! I think you could easily charge admission.
Jim
Current Build: HMS Winchelsea, Model Shipways Mayflower
Completed Builds: NRG Half Hull Project
                                   Model Shipways 18th Century Armed Longboat
                                   Dumas 1954 Chris Craft 36' Commander
                                   Dumas 1940 Chris Craft 19' Barrel Back
Thank you very much James
Nils
Current builds
-Lightship Elbe 1
Completed
Gary,
thank you for your kind words, much appreciated, and I´m very pleased that you like the boat....
Nils
Current builds
-Lightship Elbe 1
Completed
Another fine addition Nils.  Question:  Do you use plaxi or acrylic for your cases...or are they glass?
Rob
Current build:
Finished build:
Current build(On hold):
Hi Rob,
I used 4 mm thick glass panes for all my 9 display cases to date. It is a bit tricky in preventing the panes to tilt during assembly, before the frame can secure, but meantime I gained some experience in handling that quite well. The handicap is that the glass cases are rather heavy, and I finaly need two helping hands from my wife to put and lower down the glass bonnet over the model and on to the case base-plate.
Nils
Current builds
-Lightship Elbe 1
Completed
Bonjour Nils    😍
J'espère que vous allez bien. Je reste sous le charme du contenu de votre bureau. C'est un véritable musée j'adore !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Surtout continuez à nous faire rêver. Il ne faut surtout pas s'arrêter en si bon chemin, quel sera votre prochaine modèle? certes il faudra trouver une petite place pour exposer la prochaine vitrine.
Bonne journée et merci pour votre contribution.
Stéphane
Thank you Stephane, for your words,
I have a great problem in finding additional display space in my home. For instance the #5 Elbe schooner will have no own case, and will have to share the case of the Zeesboot from time to time, as both models (one at a time) can fit in it. As this is an English speaking forum, please would it be possible for you to correspond in english rather that in French language, so that other members can also follow, thank you
regards
Nils
Current builds
-Lightship Elbe 1
Completed
