Good morning Gentlemen,
Well, for those of you who may not have read my previous thread (below), this is my first attempt at a scratch-build, using Goodwin's (extremely helpful) guide for the Cutter Alert of 1777.
I have drawn out each individual scantling/rib (whatever you may call it) on paper, then card, using the plans illustrated in Goodwin's guide.  If using the traditional method of paper/pencil, be sure to have a waste paper basket nearby :)  I watched a video of a card build of the Alert (this one manufactured by Shipyard models), just to see the method of construction and how to go about it.  Each scantling was then glued to the main section using PVA.
So, as you gentlemen see below, I have now begun this wild project and so far, I am quite pleased with it.
I look forward to hearing any advice you chaps may have for me.
Cheerio,
Caleb
Nice start, but none of the bulkheads should stick up below the center 'keel'? Also, the third one from the stern look as if it's in the wrong place. Check if it is correct.
  • 6 months later...
  • 3 months later...
No, I'm not scared off that easily!
Sorry, Gents, I just haven't got around to doing anything more with it :(  Yes, in fact druxey is correct, something indeed went wrong there.  If I find the time, I shall have to begin again :)  My apologies, indeed.
Cheerio,
Caleb
Cheerio,
Caleb
No worries.  Stuff happens.  I think we've all been there at least once.
