Hi Everyone. new member here from New Zealand. also a member of modelspace forum and currently doing two builds. I have build logs there and will start them here as well.
HMS Victory and
Endeavor lifeboat by Artesania Latina
I started the lifeboat as a means to enter into the world of wooden ship building and then got a absolute bargain on the Victory.  so set myself up and got started.
then life sort of gets in the way a bit so very slow progress currently.
Im 56 currently and did a lot of plastic models when younger.... ok like 40 years ago :)been looking at these builds for a while now and finaly decided now was the time to make a start
regards Erik
Ships in Drydock for build. De Agostini HMS Victory, BB Dannebrog, Artesania Latina Cutty Sark and Endeavour longboat.
:sign:
Hi Eric - welcome (and a quick Heads up).
It sounds as if you're going from a good basic starter (as I did) straight to one of the more complex kits available. Hopefully you'll build a couple of others between as the skills learnt in the first build will realistically only be of minimal use on the Victory. Obviously I don't know your skill level but just wanted to give you a warning in case you suddenly find you've bitten off more than you can chew. 😉
Rick
Eric, a warm Welcome our amazing world at ModelShipWorld.
Glad you found us, you have just entered a world where questions can repeated and you will an answer and guidance.
Start a build log, when you get stuck (which will happen) just ask for help and we will do our best to get you past that point.
Again, warm welcome.
Respectfully
Welcome to MSW! All the best to you on that Victory build. :)
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
