Does anyone know what this object is? The “N” and other markings stamped on it has led me to believe it is naval in origin, but that’s a guess. It’s thick oak, with a brass plate on one side, and is approximately 11 1/2” square. I would be very grateful if someone would identify it, and solve a mystery for me...
CC1967B6-105B-4BD8-9F1F-2F197462325C.thumb.jpeg.899d4ae05567d69baeeebef5a08fff5a.jpeg711ABFE2-750B-484F-887C-54341F219C0E.thumb.jpeg.40df332f62ec36c08b59aab1d858570f.jpeg40EDBE68-9321-402C-9687-2CB9747CAD3B.thumb.jpeg.e019a341956a87bdea72e6b85823272e.jpeg
looks like an ancient cup holder 🙂
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
I would assume (and we know about what happens when we "assume") that the 1929 is a date.  If the date is right, not a shot garland like we think for ball shot.  Are the "holes" tapered?   Can't tell from the photos.
I agree with your summation Hallibag as to it being from the Arsenal - Carriage Department.  The Rod stamped on it may indicate a proofing device for some of the rods used in the the carriage (1926)? The attached may have something as there are 3 parts - Army, Coastal Defense and Naval gun Carriages discussed.  I have only perused the Naval section (Part 3) at the moment and do not recall seeing it, but....
cheers
Pat
Treatise_on_military_carriages_ W Kemmis 1974.pdf
1926, breach loader days. Device to hold ready service cartridges, dropped in and stopped by the cartridge rim. Hole in the center used as a holder so the holding plate could be removed and replaced by a different caliber if the Ammo Cart was used for a different sized gun. Don't know, pure speculation. Maybe some evidence of compression on the bottom of the small hole, it may have been set on top of a cylinder and secured, Possible compression showing on the brass plate around the large holes. Hope someone with better research skills can solve the mystery.
From what I have been able to find, looking in the Royal Navel Handbook of Field Training 1926, the MK II Carriage Land Service was used for the MK I Howitzer.  However, that is a 6 inch diameter shell so they would not be fitting into those holes
Regards
Henry
Laissez le bon temps rouler !
cheers
Pat
Thank you for this. I will give the Treatise a careful examination!
