I’m still working on finishing my first wooden model ship, so I was hesitant to undertake such an ambitious project as this. However, seeing the great mentorship that Chuck and others have been providing, I figured I couldn’t pass up on such a great learning opportunity.
Anyway, I don’t anticipate my work to be anywhere near the level of some of the master builders on here but if in the end, I end up with a ship that looks the part of a Frigate, I will be quite content. Needles to say, any and all constructive comments and suggestions will be greatly appreciated.
Cheers,
-Waldemar
I have Proxxon mini tablesaw that I’m quite content with. I’m able to achieve accurate cuts and with its variable speed settings, it’s proving to be a very useful disk sander. To accomplish that, I’m using the 80-tooth blade with required blade adapter and a self-adhesive sanding disk.
wja_winchelsea-8753.jpg.3a9c13a7b75d71b842581406e8e9919c.jpgwja_winchelsea-8751.jpg.fbb0450d2c18d98cd92c0ed14b79dd4d.jpgwja_winchelsea-8750.jpg.f491aa73c82b3ec4ca6b286f97948c95.jpgwja_winchelsea-8745.jpg.a5c999a7a60cde63a2b84c1fb232ba05.jpg
I’m using couple of right-angle steel plates to make sure the bulkheads are parallel to the keel. Also, since some of the plywood bulkheads are a little warped, I decided to glue some square reinforcement pieces between the bulkheads. This should also add quite a bit off rigidity for the fairing process.
wja_winchelsea-9026.jpg.12300e83598ae2c78f56268b02d63e56.jpgwja_winchelsea-9025.jpg.3e172c1615a89ec485c9891da4f3c704.jpg
wja_winchelsea-9045.jpg.56cdb39afdb0005348f504765e6d158b.jpgwja_winchelsea-9039.thumb.jpg.ba7af6eb2a00b001e49aed006cef15ed.jpgwja_winchelsea-9036.jpg.782c4d0105a90a14900dcc8d4afe74df.jpg
Thanks Jeff…. I’ve been involved with many other hobbies, which helps, but I wouldn’t even attempt this project if it wasn’t for all the great examples provided by so many experienced builders in their build logs.
