Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
Self-made sand  disk . Three-phase motor frequency control, can achieve accurate grinding, chamfering, low speed does not affect the torque output, ultra-low noise night operation. The table surface of the two-axis slide rail can be moved and polished, and can also be locked at any angle. The sandpaper can be quickly changed by hand by turning two nuts on the dust-collecting cover. High precision machining ensures minimal deviation and in some cases can be used as an alternative tool for milling small parts.
DSC07788.thumb.JPG.d3783641abe0a4e0cb203284df0b4851.JPGDSC09741.JPG.2c1f1f36e3617f15d3f35b07bf49017a.JPGDSC09748.JPG.8f5f2cc46a333aa5f118deb4084cc703.JPGDSC09750.JPG.bbc4092630f8fb8f49ef09dd72435724.JPGDSC09754.JPG.dfdb4d9019cbfa013da9411c5c995dc4.JPGDSC09755.JPG.b2d2f2dffb4c3f0f29f9218caaf54f30.JPGDSC09759.JPG.7c70991e2a3bc152a8e26b7dd5c0fc0a.JPGDSC09765.JPG.812e4290d9fca9caeda017732cbf1e16.JPG
This really looks great! I know nothing about motors but does “frequency control” mean variable control? What was the total cost of the parts?...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Hi hyw,
That's a nice piece of machinery. Based on the size of the square (250x160) I estimate the sanding disk to be 125 mm in diameter.
The table is 200x100 mm (?) and sits on a linear guiding rail, but how do you tilt it?
And a last question: this seems to be a 3-phase AC induction motor with frequency converter, but what is its power rating.
It looks quite heavy for working with wood pieces of the size most used by modellers.
Anyway... this is well done.
regards,
   Kris
Hi Moab.  By changing the frequency speed, the basic loss of torque output, than the usual current speed is much more stable. The cost per unit must be much higher than the cost of mass production. . .
11 hours ago, Kris Avonts said:
Hi hyw,
regards,
 Kris
Hi  Kris, The diameter of this sand table is 150. As a high precision grinding tool, the more the joints, the greater the deviation; in the effective range of grinding, whether horizontal or vertical, the role and stroke is the same. So I through the table on the backrest design angle adjustment to achieve the "tilt" function. It's much more stable on the countertop. Because of the need to polish the metal parts, the motor has a power of 750w; the weight is about more than 30 kg.
That's engineering !
Could you you show the machine in a tilted configuration ?
