Hi Folks,
 I’m a retired PA and former USN Corpsman just a beginning modeler. Looking for advice on planking vises or clamps. Seem to me that the small part of the hull to be clamped might be pretty delicate and prone to snapping off with too much pressure being applied during the planking process. Any suggestions regarding vises vs hull clamps for a rank amateur? I just purchased the large Model Shipways 18th Century Armed Longboat and a paint set. Can’t wait to get started. Thanks for your help.
Hi SeaDoc,
Welcome to MSW.  I would suggest that you go to the kit build area and you'll see an index of all logs....  https://modelshipworld.com/forum/130-build-logs-for-ship-model-kits-by-era-launch-date/    Also, if you scroll down a bit, you'll see indexes by era.  Go to the appropriate era for your models and you can search for logs from there.
The best way to clamp is one of long debate as everyone basically has figure out which way works for them and for their particular model.  There is a section for "tools" but it's not specific on the application to a particular ship, so the best way is look at the logs and see what others have done.
Also, open a log of your own so that others can follow along help out when needed.
Hi SeaDoc and welcome to Model Ship World.  The 18th Century Armed Longboat builds into a nice model.  The large 1:24 scale is a lot easier to work with than the smaller scales.  If you brace your bulkheads, you will be surprised at how strong the framework will be.  Check out the build logs for the 1:48 scale Model Shipways 18th Century Longboat.  There are a lot of tips and techniques in them that will help you with your build.
Ryland
               - Nautical Research Guild
Hello!  New modeler here; COVID made me do it!  Working on my 4th kit, and hoping to learn from the experienced builders here.  Specifically, I’m building the Liman 2 tugboat, and thrilled to see some one working on it here, too.
