Is anyone using their Byrne's saw for cutting thin brass stock?
If so, which blade are you using and what is the maximum thickness you're cutting?
Dave
Previous build: NRG Half Hull
Previous build: MS Bluenose
In theory,  I would use a slitting blade.  Thin sheets of non ferrous metal will probably react poorly to the stress of cutting if it is pushed thru the blade by itself.
I would use thin sheets of model aircraft plywood and double sided tape to make a sandwich. The metal fixed between two sheets of ply.  Cut using one of the more coarse toothed slitting blades, but still a lot of teeth.
I have no actual experimental data to confirm that this would work.  But, I expect that curling and other adverse problems would be avoided.
A top hold down stick and butt end pusher should resist kickback.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Exactly right for thin brass. It doesn't have to be top quality plywood, just solid with no 'voids'. Also works with acrylic sheet.
I have cut .004" (4 thou) brass this way with good results on a saw nowhere as good as a Byrnes.
It is surprising but the same setup will allow you to make good cuts with a router provided the ply-brass-wood sandwich is rock solid and you have good router bit. You may harm the teeth of the cutter but just use another depth setting next time to bring a different section of the cutting edge into contact with the workpiece.
The tricky part, whichever tool has been used, is removing the plywood without distorting the brass. Tip: soak the whole kit and kaboodle in methylated spirits to soften the double sided tape bond. Once finished, throw the plywood away.
STAY SAFE
current builds:
Apparently the saw will cut "larger" stock as well. Greg Herbert used the saw to help make this tiller.
https://modelshipworld.com/topic/370-speedwell-by-dvm27-greg-herbert-ketch-rigged-sloop-1752/page/7/?tab=comments#comment-654207
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
