Same here, I find it hard to do the seizing, it feels that I need 3 or 4 hands to be able to come out with something that looks somewhat decent. Part of the problem may be that I am no longer a spring chicken, having gone trough 76 of those springs. LOL
Joe
I've not yet mastered the proper seizing method...ie pull the end of the thread back in to the thread bundle using the thread loop created.
Instead, I tie the seizing thread around where the rigging loop (different loop) starts...to tie, you can do a reef knot (or a half reef knot, adding a touch of PVA to hold it in place)...then wrap the longer thread strand around the two strands of the rigging loop + the other end of the shorter thread (ie three items just like in proper seizing) and then after 6 or 7 wraps of the longer thread take the shorter thread strand that was being tied and make a reef knot with the longer strand at the far end of the wrap.
That's maybe not the world's best explanation, but I hope it makes some sense.
From a distance it's difficult to tell it's not proper seizing. One day I will master proper seizing.
I tend to use a 3rd hand device to dangle the three lengths from whilst doing the wrapping.
Regards,
Richard
  • Does anyone remember HUBERT'S "Zipseizings"?  They're a preformed seizing collar made in a group on a wire mandrel, locked with CA , removed and cut to size,  The parts to be seized are threaded through the collar which is then slid into the right position and glued in place.  If you don't like CA that's a problem, but otherwise they  do a good job once you master their making.
CW
I have created a sort of “third hand” for seizing shrouds around dead eyes. I take a small alligator or binder clip and tie a piece off line to it. Cut the line long enough to go up and over the mast head plus a bit more, which you will tie around a small weight. I have used both nuts and fishing sinkers for this.  So you end up with a piece of one with a weight on one end and a clip on the other.
To use this, fit the shroud around the deadeye, fasten the clip to the running end and run the line over the top. As the weight hangs down from the top, it will tension the should, holding it in place around the deadeye. Make your seizing, remove the clip, And cut any excess shroud away. Use the same third hand line on the other shrouds.
Vince
I’ve used Hubert’s seizing and it works very well if you follow the specifics.  He gives very specific sizes for drill bit sizes, etc....Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Ken; the link I have is  “ship-modeling.ca”...   If you can’t get the info let me know. I can probably find prints of the info needed and post them when I get home tomorrow...Moab
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
Moab, it's now a drug pedaling site now. The site was saved on a Pintrest site now, which I'm not a follower.
Ken
Started: MS Bounty Longboat,
Ken,
The site is shipmodeling.ca. Its a subscriber site...$45 for a lifetime membership.  I was (am) a member but I haven't been signed on in a long time and I've forgotten my credentials.  What comes up looks just like what I remember.
CW
Ken; sorry about the error. My great typing added the dash...Moab
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
Ken; I totally understand how you feel. I subscribed several years ago and have gotten a great deal of info from the site. Although watching my budget is important I felt the $45 for a lifetime subscription was a good value (for me).
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
