Nice job. I like all your tools. I have also made some tools. Will post them later. My homemade lathe is here.
http://modelshipworld.com/index.php?/topic/126-my-homemade-wood-lathe/
Ron
Ron
Current Build: H.M.S. Triton Cross Section 1:48
Why is it that I always find out the best way to do something is after I have already done it the wrong way? - Me
I noticed on the thickness sander drum some screws. Do they not scratch your work piece? Also are there any height adjustments on the thickness sander?
Tim
Current builds: San Fran II AL, Santa Maria AL
Finished Builds: Sharpie Shooner Midwest
Inventive work. Do you still have some pictures left on how you made them?
Carl
Thank you guys you are to kind  :)
Ron, I see the lathe and is the best it can be and is pretty to you did a great job.
Fabius, I made the jigsaw stand because I don't own a band saw or a scroll saw and for now is working just fine.
Tim, the screws doesn't scratch the work piece because they are lower in the drum it self, and yes there is a system for  height adjustment you can see in the pictures-screw with a T-nut on a raising table which is attach with hinges.
Carl, I really don't have pictures how to build them but I will help you with any question even with a hand drawing  if you will.
I will be happy to help about anything, Thanks again!  :D
Greetings, Sinan :pirate41:
Build log:TRITON POB 1:72
Sinan, a great job on the tools I also particularly like the jigsaw and the sander variable speed control, looks like it came off a sewing machine.
Michael
Great job Sinan, I like all your tools. I notice the nice parts of the machines made of aluminium . You have workshop to work with it?
Greetings from your neighbour.
Gregory
Edited by greg-kam
Gregory Kamtsikoudis
Thank you Michael and Gregory.
Michael yes that is a  motor from a sewing machine. :)
Gregory, the aluminum profiles are hand cut and then filed. The precise parts like the disc is made by a lathe machinist (I paid like 10 euro for that). The motor stand is a part from another machine I'm not sure from what really (I find this part in a secondhand store). Almost all other is made of wood or plywood.  Greetings :)
Very inventive tools, Sinan! I like them all. I will study your sanding tool, I need also a machine like it.
(Vidi se da imas klikere za nesto smisliti. :) Malo cu prouciti debljacu, to bi i meni dobro doslo.)
Kind regards,
Hrvoje :)
Finished: Leut by Dida
My current build: Leut II
My forum dealing with traditional Croatian and Mediterranean shipbuilding: http://drvenibrodovi.forumotion.eu.
