Great detail work on all the "deck parts", John!  I've be referring to your work a lot when I get to various points on my Bluenose👍
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
Glad I can help. Lots of great builds to learn from. I've found many tips that way when I'm stuck about a procedure. MSW is a great resource. Feel free to ask questions too.
To make the hatches, I again used solid blocks. Double sided tape was used to fasten two pieces of scrap together. The bottom block protects the X-Y table from damage when cutting through the finish piece. A milling tool was used to cut out shapes to size. A slight over size was left to allow for sanding. The corners of the blocks were rounded as shown on the plans using sand paper.
20230210_103159.jpg.abc3d8bd440cbafbd2b697d26f374b82.jpg20230210_115425.jpg.049db59ce5f735c61cc5724074b12eb9.jpg
The blocks were sanded smooth, coated with shellac and sanded again to get a nice finish.
The airbrush was used to put on a primer coat. The backside of an Xacto knife was used to score the blocks, simulating coaming and covers. In retrospect this didn't work well for cross-grain scores. It would have been better to use the knife side first to cut the grain, then score the block. The results were pretty good and acceptable at viewing distance. Next dark grey was sprayed on the coamings. After the paint thoroughly dried Tamiya masking tape was used to protect the coaming and the hatch cover color was sprayed.
20230210_173148.jpg.f21458dc6cf70cfc5138c347bfb4ada6.jpg20230210_205950.jpg.fce2048de41b789d040a95ec2b8c003d.jpg
After that, holes were drilled for the tie-down rings as shown on the plans. The result looks good.
Once again the supplied plans do not agree with photos. The actual hatch looked quite different and there are no tie-down rings. However, the hatches on the plans are more visually interesting. Of course the ship may have been originally built like the plans and later additions and modifications to the hatches made.
For the Galley stack I like the "Dreadnought head" supplied with the kit. The Britannia metal part was not a bad casting, but there were no holes in the pipes. My first thought was to use a milling tool to cut the holes.
This did not work out well. It was difficult to clamp the part at the correct angle. More importantly, the Britannia metal did not mill well. It tends to smear and the tool was prone to wander off axis when I started getting deeper into the metal. I decided to cut the pipes off and epoxy brass tubing onto the part. To get the correct fit the pipe molding was first sawed in half with a jewelers saw. A round file was used to cut the rest of the way and create a proper shape to hold the tubing.
20230212_203037.jpg.9fc8456d3417f4e0c73b7ce164a16fcc.jpg20230212_204040.jpg.7883350f561e59260c2c8ba4b712ac90.jpg
The brass tubing was epoxied in place. Then repeat for the other side.
After some cleaning and polishing the part was primed and painted flat black. A small base was constructed with a hole drilled in the center as show on the plan. Looked pretty good in the end. With real holes!
All great work, John!  I will definitely be referring back to these things when I get to this point in my Bluenose build.  Awesome job, sir!
Gregg
Thanks Gregg!
I appreciate the encouragement. There are times when I think of the next process and feel overwhelmed. One step at a time and it progresses. My goal this winter is the deck furniture. And maybe getting the masts dressed.
I checked out your Ballahoo today. Very nice! A great looking model.
I see you are planning to add an America to your fleet. That one's waiting in my shipyard as well. I have the Constructo kit. It's very old but everything seems intact in the original packaging. There was a paint set with it but it's so old the paint may not be any good. At the pace Bluenose is going it will be a year or two before construction starts.
John
Added the mooring chocks and anchor pads. Airbrushed the mooring chocks flat black and the anchor pads the dark grey coaming trim color. Scraped the paint from a small area under the pads and chocks to increase adhesion. As these small exposed pieces tend to get knocked off epoxy was used for strength.
20230215_210023.jpg.6a38e365ed80e424f0e055508f16a4ba.jpg20230215_210032.jpg.fa4de2c6258a6e00091534356543015e.jpg
There is a grate by the ships wheel for the steersman. I suppose this is to keep their feet dry when water is sloshing across the deck. The one in photos has what looks like 2 or 3 inch square holes.
200400059.jpg.6daabf3ae5aaad8b2eef87130f3000cf.jpg.9499aeffe536c7cf6fd40a98ba00f278.jpg
The plans do not show much detail. Rather than try to create such small square holes I opted to buy some grate material. The smallest I could find was 1mm. This is bigger than scale but at least the holes will be square. My first thought was to have the notches interlock as the prototype probably did. This did not give a good appearance and would be too thick. A better effect is made by placing them side by side.
20230217_095458.jpg.e39c9ceae51e3f9218061c66dd51dfbe.jpg20230217_095740.jpg.11c679edd2e34a8c9b755d7737aed479.jpg
The strips are laser cut and there is an angle to the shape so that one side of the strip is thinner than the other. That can be seen in the photo above.
The thicker side was chosen as the detail will disappear at viewing distance with the thin side.
These were tricky to glue together. They are so light and tiny they tend to stick to anything that touches them. I experimented with a number methods. I got the best result by using double-sided tape to hold them in place while gluing. Cyno was used as I could use a pin to drop tiny amounts of glue on the joints. As usual it was pretty messy. The problem is to get it all in place before the cyno set.
Unfortunately, after all pieces were in place I touched it before the cyno had quite set. I then had a perfectly nice grate attached to the end of my index finger.
The physical stress of getting it off my finger would be too much for this fragile assembly. I glued a paper to the bottom of the grate with PVA. After that set, I went to work with alcohol and a scalpel. The paper gave it enough strength to get it off my finger with no damage to the grate and little to my finger.
I then glued the end pieces on and trimmed them to size. The next step was to gently scrape the paper off and clean out the holes.
20230217_124211.jpg.2a46ea3b666944e78d7f58686e5bf10a.jpg20230217_130650.jpg.cee7da907d26d19186b6138d363fb597.jpg
The grate looks nice, though the holes are a little big.
Nice work, John!  I had seen this photo before that had the two lovely ladies sitting atop the wheel box, but hadn't noticed the grate to the side of the wheel box.  Nice looking out!  Not that it makes a lot of difference, just placing the grate on the deck looks great (no pun intended), but while the ship is out on the water, would it have made more sense to have the grate positioned directly in front of the wheel?  Where would the steersman be standing while under sail?  To the side where the grate is in the picture, or between the wheel box and the cabin?  Not questioning, just curious as a non-sailor.  Continued awesome job on your Bluenose, sir!  👍😁
Gregg
Thanks for the feedback! Maybe the thinking was "outside the box", but the patience not so much. As my lost fingerprint testifies.
To answer your questions;
The steersman would have been facing forward both to see where the ship was headed and to view the compass which is on the roof of the deckhouse. Also there is usually a telltale at the top of the mainmast for wind speed and direction. If he were to stand forward of the wheelbox it would be awkward to reach behind to grasp the wheel.
The only convenient spot to work the wheel and see the compass would be behind the wheel or to the side of it.
Other photos where the deck around the wheelbox is visible do not have a grate. There would have been no point in other places anyway. These ships were about practicality first and foremost. Any decoration would be secondary. Remember, Bluenose was designed as a work boat.
An interesting observation is how the steering mechanism worked. If you look at the steering mechanism on sheet 4 of the Model Shipways plans you will see that it's a double screw drive with the leverage on the wheel side. A screw drive prevents rudder feedback from moving the wheel, while the wheel can easily move the rudder. This means that in open water the steersman could leave his post and help with other operations. Barring changes in wind or currents the ship would stay on course. It also means operating the wheel does not require great strength.
RetiredGuy did a wonderful job of producing a working scale steering mechanism. Check out his Bluenose.
John
The skylight shown on the plans is, again, much different than the one in photos of the ship. I like the one in the photos. The one on the plans would more likely be found on a passenger ship than a working boat. Much to fancy. The one in the photos is easier to make. It also has the has a hinged lid. That will add more interesting detail to the model. Here's the one in the photo;
It's not clear what type of air vent is on the side. Could be a shutter or angled vents. Or even a round hole that simply doesn't show well in the photo. I decided to go with a round port as shown on the plans. Inconsistent I know. Builders choice!
A solid block was again used. Two pieces of scrap were glued together to get the height. Then the block was cut and sanded to size. 20230219_132213.jpg.097df2948747ed582e89fee127ea8316.jpg
Because there will be an open top, it was necessary to cut out the interior partly as it will show. The drill press with a milling tool was used to hollow out the block. I didn't cut all the way through to retain strength.
20230219_132247.jpg.097043c11b1e05d5df156b580227518e.jpg20230219_150825.jpg.a4645233392084200e108dfb11f5c3b6.jpg20230219_151627.jpg.aa0641c18ba474ec3f05e784421c24c7.jpg
The box was then shellacked, sanded and primed. Because all four sides and the top are being painted, holding the piece while airbrushing was a problem. The pieces are so small and light they blow away when hit with the airbrush. This was solved by using double sided tape to hold the work piece on some scrap that I could then hold with my hand while painting. This had the further advantage that I could turn it to the optimum angle for painting. The inside bottom was painted flat black. Then masked while the white was sprayed.
The top was made from scrap of the appropriate thickness. In the photo the top is a different color than the bottom. Given the trim color seems to be burnt umber, I used that for the top. Makes a nice contrast.
While the paint dried I cut some small pieces of 3mm brass tubing for the airports and blackened it.
Next the coaming was glued to the bottom. I didn't bother with mitering as that detail would not be visible. I glued the coaming strip to opposite sides and trimed. then glued coaming to the remaining sides. After the glue dried it was masked, sanded and the dark gray color applied. Again the tape on a stick method was used for paint application.
A small brass wire was used for the prop holding the top open. The top was epoxied on for strength. The top is open just enough you can see the light from the airport. Here's the result...
Great work, John! Love the meticulous detail.  Anxious to (eventually) get to all of the deck details that you have enjoyed building.
Gregg
Hi Gregg, Thanks for your comments. I see you're starting your decking. I found the decking the most satisfying operation so far. The machinery was also fun. I have two more deck buildings to go before I can install that.
John
Mentioning the machinery got me thinking about the chain types needed for the model. Bluenose has pretty ordinary anchor chain. That seems to be available from many sources in a wide range of sizes. The machinery uses a different type of chain. I could not find it on any of the usual ship modeling sites or on other hobby sites. There are three basic types of chain and each has some variations. Anchor chain comes in standard links and for larger ships the chain has cross link reinforcements. The three types are shown below.
Anchor.jpg.2d057df59aa0473d16d588caae543722.jpgFlatDetachable.jpg.55b5bb63a32776a72b5b306e432b8a89.jpgRoller.jpg.14e105c36a59bd5c84c5352ef2d1dff8.jpg
The first is your typical anchor chain. Next is what the bluenose machinery of the 1920s would have used. It's called Flat Detachable Link chain. The third is more modern(and efficient) roller chain. In the 1920s roller chain would have been expensive to manufacture and for farm and ship machinery efficiency would not have been a consideration. The flat chain would have been easy to punch from sheet steel with little finishing required.
In photos of the machinery you can see the chain is indeed Flat with the square holes. There is one link that has a through bolt and roller. That's no doubt the "Master Link" used to couple the chain ends together.
200330717.jpg.b334234da3af84f32f0ecf3d3e2f1482.jpg200330719.jpg.9b9818ec2a83e7f7b18b5c7ff9955e19.jpg
In researching other build logs and web sites I could not find the flat chain in scale. I have seen jewelry that uses a similar style, but it's usually gold and expensive. It would also be hard to find at the right scale. Most builders appear to adapt anchor chain which really doesn't sit right on the gears because the links alternate direction. I did find a builder who used scale motorcycle chain(sorry, can't remember who). This is actually roller chain but it's close in appearance to flat chain at the small size needed. 1/12 scale roller chain appears about right.
Tamiya makes a kit to create 1/12 scale motorcycle chain that comes with jigs to assemble it. I bought a couple and will see how it works out.
Here's the kit and instructions. It's a Tamiya Metal Chain Kit. The particular kit I bought is for a Honda RC166. Part #12633. The kit contains photo etched side plates and clips. There is a packet of plastic sprues with the assembly jig and tools. There are packets with incredibly tiny rollers and pins. Also a plastic tube of locktite like material. The kit makes a working roller chain! That is of little relevance for my model which will be static - but it's really cool.
The instructions have good illustrations and somewhat limited text steps in four languages. The tube of locktite turned out to be almost dried out. There are some plastic gears for the motorcycle. One of which is the right size to use as a replacement for one of the Britannia metal gears. Everything is high quality and very detailed.
The first step is to assemble the jig and insert the rollers into it. These parts are really tiny! How do they get them so precise? The rollers are about the size of Lincolns nose. If you drop one of these it's impossible to find again. Fortunately they provide plenty of extras. I had about 15 left when I had filled all the roller holes.
The side plates are attached to strips of metal and there are keying posts in the jig. Everything is numbered very nicely.
Now the pins are dropped into the holes in the chain plates. These are harder than the rollers; mostly because you have to poke them into a smaller hole. They're also harder to grasp as they have a "head" on them. I used some tape to keep the springy metal down. It's really easy to nudge this and pop a bunch of pins up.
A supplied cover is placed over this assembly to hold the pins in place. The jig is inverted and the bottom cover pulled off. This exposes the rollers on the other side. Another side plate assembly is inserted and the clips installed. This is done in groups of three.
There is a tool set provided to snap the clips in place while holding the assembly tight. There is some considerable force required. My fingers were a little sore when I finished.
The excess material is then snapped off.
The sprues are then removed. First the clip side. Then the jig is inverted and pin side sprues removed.
The chain looks very nice but is quite delicate. It's important to test each clip and tighten them as needed. I missed a couple and had my chain come apart. The kit designers thought of this as well. There are tools to refasten links. These parts are amazing. They make a pretty good fit to the Britannia metal gears.
20230221_131727.jpg.c84512352af77914f68484f28919a4fb.jpg20230221_132026.jpg.ea5cd2c37325aff3869fb0258a982e43.jpg
3 hours ago, Hsae said:
John,
Did you check 3d printed chains out?
Hermann
Hi Hermann,
That would require a 3-D printer. While they are quite inexpensive now and a wide range of programs are available, that would take away part of the fun and interest of building ship models. After all, why not say "3-D print the entire ship"? One could get super accuracy and detail with little effort.
But where is the challenge? Where is the skill? The sense of accomplishment? The creativity that comes from solving problems? That's like watching sports instead of playing sports.
I've certainly been tempted. It would be so much easier to get to a high level of detail. There would also be less satisfaction and enjoyment. I don't build models to simply produce. I build for the joy it brings me.
I spent two days figuring out the best way to build the skylight and building then painting it. When it was finished I was full of joy and rushed upstairs to show it to my wife whose reaction was, shall we say, underwhelmed. But she understood my joy and shared in my delight. I could have designed and printed that part in great detail in a couple hours but the enjoyment would have been proportionally less.
John
John,
I do have to agree. The creativity / engineerity  and the way how to resolve a problem is not so much there anymore. However you still have to design the part in CAD.
Hermann
Edited by Hsae
6 hours ago, Hsae said:
John,
Hermann
Hi Hermann,
I agree that CAD is interesting and develops skill in thinking and solving problems. I would say that's a different hobby though. If you want to design a ship with CAD and implement it on a 3-D printer it's certainly going to be a fun exercise. It might even be as complex as building the traditional way. The variety of skills and materials would not be wide.
I can see a whole new side channel of the ship modeling hobby developing. After all there are ship modelers who work in cardboard and modelers who work with photo etch. There's the R/C modelers and even people who work in foam. All of these are valid hobbyists.
For myself, I enjoy the traditional way. I do reserve to right to use a 3-D printed part in the future though.
I enjoy hearing your ideas in any case, John
While I'm on the machinery track I decided to work on mounting the windlass and gear train. The sprocket that came with the chain set is the right size for the counter shaft sprocket. Much better than the supplied part. The axle hole was too large though. I filled it with epoxy and drilled it to the correct size. Once painted it will look great.
There's some head scratching to be done getting the position correct. After scaling the drawing details and doing some calculations I came up with the following:
To check these dimensions I set the parts up on my bench and used double sided tape to hold them in place. Unfortunately the chain broke and I'll have to go back to chain repair before mounting on the ship. Here's what it looks like:
Hi Hermann,
Probably not. I'm using the provided part. It's not suitable for adding the handles. They would be like wire at that scale. They do look pretty. Too easy to damage. RetiredGuy is doing them I think. His whole setup is functional, including the pawls and clutches. He has a reproduction of the engine to go in the engine box which opens. Maybe he'll rig a an electric motor to run it.
Here's the page where he built the machinery: https://modelshipworld.com/topic/22010-bluenose-by-retired-guy-model-shipways-scale-164/page/7/
Where did you get the drawings? They look familiar.
John
Edited by JohnU
Richard (RetiredGuy) did an awesome job on his Bluenose build.  Definitely one that I keep referring back to for guidance!
I recognized the text font of the drawings almost immediately!  I was given the book by a local hobbyist who knew I was starting a Bluenose build.  The book's title is Bluenose II - Saga of the Great Fishing Schooners - Measured Drawings by L. B. Jenson, Nimbus Publishing, Copyright 1994.
Gregg
2 hours ago, JohnU said:
Hi Hermann,
John
Yes, I know his log. It is amazing what he did. Would be nice to see his finished Bluenose.
Yes, that is the book.
