I've actually been working on this a couple of weeks now but just started the build log today after I had joined model ship world yesterday. Painted the masts, yards, crows nests and plan on touch ups when I cut them loose to install them. The kit comes with formed plastic sails but I think I won't use them. Either no sails or stored sails made from sheer curtains
Moltinmark
What a fantastic site. Spent the morning looking around to see if this model had any logs to reference. Did find a review of the kit that seemed positive and that JFK had a sea witch model in the oval office. There were quite a few references to " bright" work on the masts and yards. Am I correct in assuming this to mean light colors in the topside and masting?
Moltinmark
Welcome to MSW... your Sea Witch is looking nice so far. I think it would be awesome if you did most of the remaining build using wooden parts. I built a USS Constitution several years ago (Revell- plastic) and wish I would have done the masts and deck things in wood. Just an idea.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Ya, I just think the wooden  masts etc. are something that cannot be captured in plastic. Just my opinion. I'll be watching your progress.
Had to drill 50 some odd 1/32 holes for the masts assemblies and their caps. Assembled the foremast, main mast and the mizzen mast. They look pretty good.   Painted one coat of flat tan so that the darker brown showed through and brushed them with small brass brush.  kind of looks like wood I think.
Edited by Moltinmark
Forgot pics
Moltinmark
I think I can get another kit and that one will use wood on the decks, buildings, fifes masts ect since this one is fairly close to being done. When I got this I was thinking it would give me experience in rigging a multiple mast ship. Thanks Hoss
Moltinmark
Work continues on the standing rigging. Running one line at a time on each side and clipping a heavy duty paper clip on it to create tension and then gluing them in place. And when I put the four stay lines on the tighten up and stiffen the masts. I then glue the false Deadeye assemblies over the top of the backstay lines as you see in the aft of the ship in the picture
Moltinmark
I apparently followed the illustration too good. Did the standing rigging stay taut or did they release them in port? Will only 20 sails most. And maybe try. Main mast unfurl !!!
Plastic tougher to rig because of bending. Than wood
Add a comment
Moltinmark
On 12/27/2020 at 1:07 PM, Moltinmark said:
2nd set of sails20201221_154710.thumb.jpg.36ee2de0e1a26f762ce1fc0116a6ef95.jpg
Didn't like the first set of sails so I cut shape of sails with appox 1/4" excess overlap of the thermal formed sails that came with the kit. I soaked the sail in very hot water to soften the the linen to hug the forms of the thermal sails by brushing them and  then Painted them fully with a 50/50 water fabric glue solution being careful to brush the " sides " flat against the forms and down onto the flat area beyond the shape of the sail and let dry. I then cut out the sails with scissors. The jib and stay sails were cut at the extreme edge of the form of the sail. The square sails were cut at the extreme point of the sail top and bottom with the sides cut just beyond the corner of the flat plane of the sail. This gives strength to the shape of the sail. I now have a very lightweight sail that I can hang from the masts without deforming the plastic masts or existing rigging that appear fully wind filled and have vague outlines of panels within them. I wasn't concerned with any hems as I am at 1/96th scale and think that they wouldn't be visible
Moltinmark
