I started a build log some months ago on the 18th Century Armed Longboat 1/24 scale, but have only been able to work on it very sporadically. I'm having trouble making templates for the cap rails. I think my build of the boat probably isn't up to par with other builds, such that the hull is not level from bow to stern, making it hard to trace a good line of its upper perimeter. The cap rails on the plans don't match the contours on my build either. I'm stumped and would very much appreciate any ideas/suggestions. I hope this is the right forum for this post.
You can turn your hull upside down and place it over a sheet of cardstock or thick paper. Trace the outside profile of the hull onto the paper with a pencil. Cut out the profile, place on the model to insure it matches then draw an offset line to the inside of the cap rail to the required thickness. Works well for me.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
