thanks for the vote of confidence David . it has helpded :)
i tried the overlapping John suggested and knew straight away it didnt look right to me
after measuring the shutters grinding the beveled edges off on both sides still would not have been enough and as Josh siad i would end up with a long shutter between windows
the only option left was the one i rejected at first because too much hasle/work
i had to reposition some of the windows. after careful observation the best way was to reposition the windows next to each door and move them closer to the door.
first i had to remove the already installed windows. luckily except for one i had only pushed them in as they fit snugly so that didnt take too long
i also had to remove some of the planks and add a 1.5 mm thick strip of wood on the side furthest away from the door
i tried to work too quickly and ended up with too much gaps between planks and window so i removed it all and started again
and here is the end result :
i noticed on the pic i had scraped of some of the brown paint on one of the shutters so i ll need to do a bit of retouch there
i have now installed al the strips so i could paint them white on the inside.
tomorrow i can work further on filing the repositioned holes to the right sizes, reinsert the windows and replank
Edited by Adrieke
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Adrieke, well done.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
thanks for the comments geoffrey,John and David
i am pleased with the result  :)
in the mean time i have also worked on a way to get the stairs finished. i love basswood so flexible :)
thats my goal for the next weekend then finish and install the stairs :)
Found this old link, thought of you.
http://steamboats.com/museum/modelplans.html & this one http://steamboats.com/museum/woodenmodelboat.html
Edited by Billl
La Nina, Latina - Wood / 1:65
On The Shelf:
San Francisco II, Latina - Wood 1/90,     U.S.S. Constitution, Revell - Plastic  / 1:96 (Remake),     H.M.S. Bounty, Latina - Wood / 1:48,     H.M.S. /Mayflower, Latina - Wood / 1:64,     La Pinta, Latina, Latina - Wood / 1:65,     La Santa Maria, Latina - Wood / 1:65,
Completed:
San Francisco / Cross Section, Latina - Wood / 1:50,     Coastal Submarine, Revell - Plastic / 1:144,     Cutty Sark Wall Plaque, Revell - Plastic / 1:50,     H.M.S. Victory, Revell - Plastic / 1:146,
H.M.S. Bounty, Constructo - Wood / 1:50,     Oseberg, Billings Boats - Wood / 1:25,     Clipper Ship (Sea Witch), Unknown - Wood / 1:46,     U.S.S. Constitution, Revell - Plastic / 1:96,
Man Of War, Scientific - Wood / 1:50,     Robert E. Lee, Scientific - Wood / 1:45,     PT-109, Revell - Plastic / 1:72,     U.S.S. Enterprise, Revell - Plastic / 1:720,
R.M.S. Titanic, Revell - Plastic / 1:720,     Numerous other wooded tall ships and boats from companies named: Ideal, Dumas, Pyro.
slowly getting there
all the windows on one side are now repositioned . i will wait to add the shutters till i have installed the doors and added the holes for the railing construction
Looks nice Adrieke, indeed step by step is the way to do it.
Regards,
John
<br />
<br />
thanks for the commetns John and WIm :)
today more of the same . i am running out of windows so i ll finaly have to finish them
the planking is mostly done except above the windows.
no more excuses now i ll have to make the windows
With the windows in, it will look so different. Those holes always look awful like a wreckage.
Regards,
John
<br />
<br />
not much done this week. after cleaning up my workbench i had a lot of issues with my allergies this weekend.
i did finish 8 of 10 last windows  i ll be fitting them in tonight hopefuly
Sorry to hear Adrieke, hay fever in the autumn I supppose :(
Regards,
John
<br />
<br />
HI John
no i am alergic to dust, cats dogs and anything that has sharp smells.
in this case i think its the ca+ glue as i had been using it a fair bit . so from now on i am using a mask to prevent this again
i finished all the windows on the 2nd deck state room :)
next the doors. from earlier trials just plain veneering the metal parts was not enough. so i am going to try to recreate how the metal door looks but then in wood. i will need to slice 1x1 mm sapelli strips from the 1x3 ones to get the fine detail so thats going to be a lot of fun. atleast there are only 6 of these doors :)
Good work Adrieke, curious how you will end up with the doors. Is that your brother-in-law- staring at the KoM :D ?
Regards,
John
<br />
<br />
lol
nah thats my new workbench supervisor to make sure i keep it clean :P
although he is a bit weird keeps asking : do you know the definition of insanity ?
thank you Sjors
so far he has just been doign his work . but i did tell him to put away that ukelele
finished the first door. not sure if its a success or not
also had a look at markign where the railing posts shoudl go so i can start making the holes.
I hope John can figure it out because i cant. first there are suposed to be 4 preformed curved parts for the railing aft acording to partslist. however there are 8 acording to the drawing of the preformed part sheets. but they are actualy 2 different lengths
with fitting them and using the plans it seems like they are not long enough. looking at the building fotos it could be that the aft middle railing is wider then the 35mm its supposed to be.
Hi Adrieke,
Don't know how I missed your build....guess I should start browsing the forums instead of just the 'my content' section.  Sure like the scale much better than the 1/160 I'm currently dealing with.  :mellow:   But my bride seems to think there is no room for models much larger than the one I'm currently working on....Oh well, as long as magnifiers are available I guess it's okay.
Your build is looking great! :10_1_10:
Too bad about the allergies but I will tell you that mine were miserable in my 20's and 30's and have now just about disappeared.  May be one of the few benefits of aging. :D
Cheers
Jim
:cheers:
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
thanks for the comments Jim
i have seen your build and its looking really good :) dont know how you do it i alreayd have trouble on my scale
unfortunately for me my alergies are still the same. but now that i figured out what is causing the issue (the CA+ glue) i am wearing a mask when using itand so far i have had no issues again :)
oh i noticed that the link to your robert E lee in your signature is not working
Hi Adrieke, the door looks good on the picture. Are you using coloured acetaat for the door-windows ?
Regards,
John
<br />
<br />
Adrieke,
Thanks for the heads up.  I think the broken link to my build is now fixed. :)
Keep up the good work!
Cheers,
Jim
:cheers:
I'm allergic to everything - so I sympathize - the reason I've avoided CA thus far, afraid it will trigger an asthma attack. The various wood glues (titebond/gorilla) have no odor and have found both a fast set and a slow set. Plus there are no odor craft glues that will work on most other parts.
Good luck! Rebecca
First-time builder
Current build: Mini-Mamoli Mississippi Sternwheeler
On the shelf:
MM: Charles Morgan, La Goleta
MW: Ches. Flattie, Crabbing Skiff
thank you Rebecca i wil check out these other glues. i sympathize with you as for me its mostly just sneezing runny nose headaches and a bit of wheezing which is already bad enough but so far i have had no asthma attacks.
today i am certain that i am not happy with the door. have to think about it thats why i worked mostly on sanding the burnmarks of the curved railing parts
also i cut a bunch of the straight railing parts and together with the curved one did a measure on how the 2nd dack railing should go.
surprise surprise the ful scale plans are wrong. they show that the aft straight railing should be 35mm long
but if you look at picture 70 in the instructions and count the railing vertical poles of that piece you come to 21 while the normal 35mmm piece only has 17 . that would mnake this aft part about 43mm and with the measuring i came to 44mm . close enought to be right :)
also the two differnet sizes of part 186 are correct (why not number them differedntly AL) the longer ones are for deck 2 the shorter ones for deck 3
the last picture shows that way the railing vertical bar line sup perfectly
Adrieke, thanks for checking. Once I start with these railings, I will recall.
Regards,
John
<br />
<br />
