no worries John
i have started on drilling and squaring out the 3x3 mm holes through the 2nd deck :
the bottom of the poles have a 1mm brasswire atached to fit in a 1 mm hole so that the whole construction is sturdy.
once the 3rd deck is one i will make the smae 3x3 mm holes there then cut off the pole drill a 1 mm hole in that to fix the top part on. this because the poles are not at a 90 degree angle except on top
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Looks nice Adrieke, these railings will finish the look of the steamer.
Regards,
John
<span style='font-family: courier new'>In progress: <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/177-king-of-the-mississippi-artesania-latina-scale-180/'>King of the Mississippi</a></span><br />
<br />
<span style='font-family: courier new'>Completed : <a class='bbc_url' href='http://modelshipworld.com/index.php?/topic/176-mare-nostrum-4331-artesania-latina-scale-135/'>Mare Nostrum 4331</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://modelshipworld.com/index.php?/gallery/album/51-16th-century-galeass-imai-scale-1160/'>16th century Galeass</a></span><br />
<span style='font-family: courier new'><a class='bbc_url' href='http://members.upc.nl/carla.en.john/Modelbouw/Rocket.htm'>George Stephenson Rocket Locomotive</a></span><br />
<br />
<span style='font-family: courier new'>Next build : sl Louise</span>
Adrieke,
Looking very clean and well built!
Jim
:cheers:
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
thank you Jim :)
thanks Sjors. this was just a dry fit to see how it would look. i am drilling th e holes first then finish off the doors and shutters.install the 2 stairs. varnish the second deck. install the lights then i can glue the 3rd deck. drill th eholes there and then i can finaly install the railings . so still weeks to go before that. but there are a lot of railings to install but not as many as you have ratlines to make :P
thank you WIm :) . i had visions of me knocking down the railigns while building or while handling her and then i thought of doing it this way :)
to make the 3x3 holes i first mark it on the deck then use a bit of plywood underneath to prevent splintering the wood
then use a 3mm drill wiht my pinvise to slowly drill the hole
since i was unable to get some needle files from my local hobby store ( the supplier didnt deliver any and i cant tell you an eta when i wil have them :huh:
so i use the tip of this squae file
once the hole is big enough i use the 3x3 wood dowel with brass wire at the bottom to push through too
and with th eprecut railing parts make sure its sqaured off before pushing the brasswire into the lower deck to mark where to drill the1 mm holes
takes me about 10 - 15 minutes per hole . over the 2 decks i ll need to drill about 40 of them :huh:
Looks nice Adrieke, a very solid construction. Your King is about RC ready.
Regards,
John
<br />
<br />
oh i doubt she would float ;)
after finishing the holes on one side i figured i try out to see if i can make the door a bit better:
first and easiest is framing the door. making the curve for the top with sapelliu though is a nightmare and if you look good you can see it broke in the middle but i am hoping all the railings in front wil make it unnoticable
then i add the middle frame and the solid part on the bottom (this is from 1x4 mm sapelli)
then the 2 horizontal frames follow to finsih the left side
do the same on the right side and then finish off with glueing the window to the back
here are both of the doors.
any comments on which one looks the better ?
Edited by Adrieke
Sapelli is the hardest type of mahogany I understood. There exist another type mahogany called Sipo which is easier to handle. In my humble opinion I prefer the left door. If you could arrange to create a kind of smoked glass or someting like that, I think you have the ultimate profit of your led lights.
Nice job Adrieke.
Regards
John
<br />
<br />
Your king is looking sharp Adrieke. :)
Since you ask... I think I prefer the solid door on the right... it gives contrast to all the windows with glass. The left one is good, well done, but it isn't as distinctive as the solid door. IMO of course ^_^
Randy
thanks John and Randy
the opinion here was divided too.
i decided to go with the glass door. partialy because it was easier to make. partialy because that was how the original ones look.
i have finished the second door . the glas is done the same way as the ones on the first deck (scratched then painted black to get a diamond pattern). everything on that side is done so i could add the shutters and then touch them up where i scratched the paint of by accident.
I read that you have a lot to do before you are on the railings.
Same as my ratlines  :D
But it looks great Adrieke.
2 kings on the road…..
Adreike,
I agree with Sjors...looks great... :10_1_10:
And either door works....whatever looks best to you!
Cheers,
Jim
:cheers:
thanks Jim :)
so happy i got the first curved railing on the stairs. as you cna tell it did split a bit but i will fix that up . hope the second one will go as smoothly
also finished cutting all the holes in the second deck
really happy with the progress this weekend. next wil be to install the 2 doors on the second side.
the 2  at the front and back are going to be a challenge as i didnt realise i dont have enough access from the inside to make it easy
Good progress my friend, with some staining the split in the rail can hardly be seen since the long handrails are at the wall side.
Regards,
John
<br />
<br />
thanks John and Wim
alas when trying to dryfit the first stair i could not fit it properly :(
not sure where i went wrong but i dont see away to fix it without taking it all apart and that woudl most likely brake the sideparts
i set them aside for now and worked on  finishing the 2nd deck stateroom but soon i wil need to put the stairs on or i cant go further
Adrieke, sorry to hear, remember I had to cut the last bar at the top of the sidepart before it fitted. By doing so the stairs came closer to the deck. Maybe it is the same problem you are facing now ?. (just a thought and trying to be helpful).
Regards,
John
Edited by john46
<br />
<br />
thanks for reminding me John. yes that is part of the problem but i also have that i have a 3 mm height gap between deck and top of stairs. i think i pulled the bottom stright stairs a bit make them not horizontal. i need to try and fit the second stairs to see if it got the same problem but they came apart a bit when trying to fit it in. drilling the holes and making the centre pole longer does not work as the stairs in eachothers way for the fitting. so i ll need to cut them down  again.
i am trying to put i t out of my mind and  concentrate on my work but i know its going to be hard. i dont want to give up but if it comes down to havign to scratchbuild the stairs i dont think i am up for that
Take your time my friend and I am sure you will overcome this hurdle. Scratch building these banisters are not an easy job. If you have to separate the various parts you better try to dissolve the glue first.
Regards,
John
<br />
<br />
i didnt even look at them tonight . will deal with them tomorrow
i finished 2 more doors . now only the front and back ones left
also started on the 7 doors for the 3rd deck stateroom
also made some progress on the display board.
Nice progress Adrieke.
Regards,
John
<br />
<br />
Adrieke,
Good progress! :)
You could be like Sjors and just avoid the stairs for a long time like he is avoiding ratlines...... :D :D :D :D
On another note,  I tried to sign up for that site and, as of yet, cannot sign on....
Cheers,
Jim
:cheers:
thanks David , John, Jim and Wim :)
naah i cant ignore them too long they are too much bothering me. but i need to be in the right mood to tackle them and after a days work tackling problems my mind wants a rest so i work on the easy things :)
i got the parts from the hardware store . the board itself is from pressed cardboard (i think ) and the pedestals are actualy drawer knobs.
i know its not the best looking board but it was cheap ;)
yup no display board with this kit. Al seems random iin adding a board or not
Edited by Adrieke
