Good point They are a little. The main mast needs to be a little more. The masts are not glued in yet.
Edited by Organ tech
Added info
I am drilling the holes in the fife rails for the belaying pins - a modified sewing pin works well as a drill for the Britannia metal. The plan shows the foremast fife rail 180 degrees oriented to how I would expect it ( see my photo of the top plan view). I want the haulyards to belay behind the yards so I will place them accordingly. I am not sure why the main mast has a fife rail, but will ask that in the right forum.
I assembled and installed the foremast fife rail. One piece is missing so I used wood. Too bad I spilt the deck under the rail when installing! In this small model, I only noticed it in the photo. I tensioned and belayed the port topgallant halyard to it, after gluing in the foremast at a little too much rake :-(.
Belaying all of the lifts-halyards. I hang a clothes pin on the line to make it just taught, but not bending the mast, then add a drop of clear glue. I will simulate the rope wrap- arounds on the pins, later, with extra thread.
Yes, the direction one threads line through a block makes a difference, but that's all part of the learning curve!
Pretty tricky at that scale! What happened to the aft cross-piece, though?
I have glued the deck structure- pilot house in place. The chains, supplied, for staying the funnel are too large to scale so I used the supplied thread, which is too large to scale for any of the rigging. I failed to get the curve on the bottom to conform to the deck. I also added the port side pin rail, not in the plans, as I am adding one or more sails to the formast to hide the out of scale rigging there. I wish I had bought finer thread. The running rigging thread looks better.
It isn’t shone in the plans or provided for in the parts. It would be easy to add and I may.
Still at it but slow going. Since I am adding a couple of sails to my square rigid for-mast, I am making pin rails to secure the buntlines. First drilling the holes, adding the belaying pins, then reducing the rail to its final dimensions.
The lower shrouds need to be in place before I belay the foremast clew and buntlines, so before adding the square sales, I am making the 22 lower shrouds for both masts. The buntlines and clewlines will pass through a guide, fastened low on the shrouds. Since my rail is thin file folder cardboard, for authentic scale, I am faking in a thick spot in wood, to be painted black, to seat the shrouds. Another “invention” for this model.
