I am working on the HMS Bounty from DeAgostini and have found that I am short in supply on the planking. I am trying to figure out what kind of wood is used for this build so I can mill my own planks and finish the kit. The closest thing I have found to this wood is Light Red Meranti, but I am not very convinced that I am correct. The wood has light grain to it, sometimes it is speckled in places, it is difficult to bend, and difficult to get a clean edge even with a fine grit paper. When a clear poly is applied the very slight redness to it starts to come through. The pic below is the best I was able to do with my cheap phone camera. I will try to get a better one, but in the meantime was wondering if anyone has any ideas on what wood this may be?
Edited by tenderfoot
If you have not checked the Wood database  I can recommend it as a good source of information.
The wood you show could be Abeche, but it’s not clear from your picture.
I have no idea what the species in your photo is, but it looks like a poor choice for planking a ship model.  If you can remove the already applied planking of this stuff,  you should consider substituting the planking with a more appropriate species.
Already milled planking in the same color range from Modeler's Sawmill would be Castelo or AYC.   If you can do you own milling, there are more choices.  Hard Maple, Beech, Birch,  or even Yellow Poplar if you choose carefully for the light color cuts - probably about 25% yield.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I had a small stash of this wood supplied by DeAgostini for planking, part of a box of spares I scored: it is dreadful wood.
I suspect it is in the mahogany family. I realise this isn't what you want to hear if you are part way through the kit but there is no telling now what exact species DeAgostini used.
I will never use this wood so you are welcome to my stash ( I am in the UK ), PM if you feel it is worth the effort.
STAY SAFE
current builds:
That it is, indeed.
I have considered doing as you suggest and pulling off what I have already installed. I think it may be my best option although I do dread the thought. That's many hours of work down the drain. However, the more I think of it the more the idea appeals to me. I am not very happy with how this planking looks and going with a different wood will definitely improve the look of the model.
So true! It is absolutely awful to work with. Now that I have completed several strakes I find that I do not like how it looks either. I think I am going to go with the advice of Jaager and pull it off and start anew with a better wood.
That looks like the stuff that many outlets today pass off as “Mahogany.”  Coarse, stringy- nasty stuff.  No comparison to the real thing.  If you have a wood burning fireplace it might make good kindling.  If you can mill your own wood, living in Chicago you should be able to find a real lumberyard that can offer something much better.
Roger
Very wise.
STAY SAFE
current builds:
Why not check out one of MSW's newest sponsers?
http://www.modelerssawmill.com/
STAY SAFE
current builds:
  I like 'true' Honduran mahogany - but it is harder to find these days and pricy at that.  One can obtain a plank by picking through what may be offered at 'Woodworkers' Supply' stores (they all have different, uncatalogued stuff in odd lots).  Then one can re-saw into planking stock of the desired thickness, with the desired grain orientation.  If used for ships that did not have painted hulls, no stain is needed.  Johnny
I've seen some pretty decent mahogany veneer..  Not cheap but not crazy either..
I like veneer for 2nd planking on double planked kits..   You can do some spilling and really fine tune your plank widths..
At Rockler for instance..
― Jimmy Buffett
On Hold:    Rattlesnake
I have the seat panel of a piano stool and the hinged keyboard cover from the same piano. The family who were scrapping the piano know it was bought second-hand in the 1920's. There is no way to be sure but I suspect this wood is Honduran mahogany: whatever type of mahogany it really is, it is a pleasure to work with and can be brought to a beautiful surface finish. I am saving the long key cover for making a case (if I ever finish a model!).
STAY SAFE
current builds:
Thank you everyone for the helpful input. Based on this I have decided to forgo the provided planking and get some new, quality stuff from Modelers Sawmill. Visited the site yesterday and the pricing for milled planks is excellent, so made the decision to go that route much easier.
thanks again everyone!
