HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Here is a dropbox link if anybody wants it for a 3d hull model and basic superstructure, lines, stations  etc for an Empire Class Tug taken from builders drawings for Empire Shirley and Jane.
https://www.dropbox.com/s/muw1fkcvd63nxpi/Empire_Class_Hull.zip?dl=0
I will remove in a few days but if you get Rhino trial ( which is long)you will be able to at least see how the surface is put together, the construction lines are not there just the final result.
But you could build an accurate model from this.. I am actually for my Wahine Support vessel.
On he subject of 3d modelling of ships, here is another example of how its used, this was done for the 2011 Cutty Sark restoration I was involved in where I had to document in 3d from hundreds of measurements of ships frame while planking was off to capture the ships structure, I intended to do an anatomy of the ship book but it did not get approved, but this is the model and you will notice the usage of resurfacing a scanned hull of the real ship to capture true lines like never before.
Sorry I will stop, I don't want to seem to hijack post but thought it might be of interest as it is relevant to the topic.
Over and out.
Edited by Richard Dunn
Now for the Bottom View image...
Select the top plane and create a new sketch and load the bottom image just like you did for the last four....
Process the rest of the image the same as the deck image, rotation, scaling and position don't forget to  set your transparency.....
Close the Sketch picture properties and the sketch, Finish the process as with the previous four planes...
Now to finalize the the build environment, Look at the feature tree, notice that yellow line at the top, grab it and move it to the bottom of the list...
What that does is lock the drawings and added planes from any ability to edit them...
Your construction box is complete....
Ready to model....
At this point
Save your file to a place where you can find it again and give it a name that tells you what it is, I called it Drawings....
Next, I will go thru the process of setting this up in Fusion 360....
Thanks for reading/following...
Over and out.
Beautiful work Richard, Rhino does some fantastic modeling no doubt... Yeah your right it is just a tad bit more advanced than this thread needs at the moment, we are, (most of us) relative newbies ya know... (just getting the basic drawings into a useable work environment is an accomplishment) {chuckle}
Thank you, if you have some advice for newbies just starting out on process please jump right in.... Please remember we are not building real ships so that level of construction detail is not where we need to be..... We need to be concentrating on software and how to use it, the artwork of it is still a ways down the road for us..... You are already at a spot in 3d modeling that some of us may reach some day.... (a couple of decades from now if ever)
Quote:
EG, this is a very helpful tutorial around basic workflow alone, I’m already beginning to feel slightly less daunted by the idea of taking on a hull (I.e a whole scratch built 3D printed mode).
Richard, such a shame your couldn’t get permission for an AOTS book for the Cutty Sark. It’ll be the next thing I’ll build. I’m sure many here would appreciate a topic on building it in CAD.
Kevin
Current projects:
Very interesting Egilman. Even with a complete table of offsets, drafting a hull is a big job. I am taking a sit in the back, curious to see how you ll fill the gaps between the different views you ve included in your 3D box.
Welcome to the thread.....
The information in the drawings is the only information that going to be used... It can be done....
Quote:
Setting up Fusion 360 to model the Sunseeker Predator 108...
Startup fusion 360... It will open on a generic screen... Go to your data panel and click the little home icon.. you see a button saying open a new project which you do and name it to what you want... Everything you do will be saved to this project so it's all in one place....
Once you've done that go to the assemble tab and click create new component, name it something that contains the word hull..... (I used Predator 108 Hull) This is where your modeling will take place...
Now your going to need five planes for the drawings.... You go to construct tab and select offset plane it will open a dialog box asking you to select the plane you wish to offset.... I selected the top plane, and you fill in a distance for the deck plane you enter 10m and select OK.... Fusion instantly creates a new plane 1 10m above the current top plane.....
Next you add the second plane except you select the front plane and the distance is 32.92m, you now have plane 2 full scale distance from the front plane...
In your feature tree you will also have a construction folder containing the two new planes....
At this point you select the insert tab, then select canvas... A dialog box pops up asking you what you want to insert on your canvas, you select the insert from my computer button and navigate to your drawings and select the front bow view..... Another dialog box will open asking which face to put it on... Select the front plane and hit OK.... The image will open on the plane you selected and a canvas properties dialog box will open, set your visibility to 40% and select OK.....
A canvasses folder will be created in your feature tree and open it... You will see your image in the folder... Right click on the drawing you just installed and it brings up a menu, one of the selections is "Calibrate" what that does is put your canvass in a mode that will scale it to whatever length you want it at keeping the aspect ratio constant...
You mark one point on the drawing, then another point on the drawing at the end of a known dimension... I selected the two wings on the lower sides of the hull and a dialog box comes up showing the current dimension of the drawing, input the 6.3m beam measurement and Fusion 360 enlarges/scales the drawing for you to the dimension you specify maintaining aspect ratio... (You will need to scroll back out from the drawing a good distance to see the image cause it is now full sized)
Once that is done, you again right click on the drawing in the Canvas folder and select edit, you can then move it to line up whatever index point on the document you wish to use with the origin.... (I chose the same setup as I'm using in the solidworks setup so I positioned the image with the origin in the middle and along the lower edge....
When that is done, you repeat the process for each of the four remaining planes/images and this is what you have...
It is a much faster setup than Solidworks all it took for me was about 30 minutes to set them all up, and it only took that long cause I tweaked them to as close a matching fit as I could....
Then save your file it will ask you for a name and a project folder to put it in, I used Predator 108 hull for the name and put it in the Sunseeker project folder...
Your now ready to draw.... It's amazingly simple to get background images into Fusion 360 and get them scaled to the dimensions you want.... Much faster than SW....
Next up, we start to create the hull....
Quote:
I’m sure you would do this anyway but it’s worth mentioning at least two things here for beginners (I of course learned the hard way!).
- make sure, when you create these planes, that the hull component is active (radio button checked), not the root. Otherwise It is an utter pain, down the line, to be trying to remember where things are.
- name each plane, much as you do in solid works. Same reason - in a months time ‘Plane 3’ will mean nothing to you.
I now name absolutely everything - every plane, sketch, extrusion, cut, etc etc. It takes very little time doing this as you go along and you get payback later on as it’s now very, very easy to isolate particular sequences in the timeline.
Kevin
Current projects:
Yes an excellent suggestion Kevin, in either software specifically name everything.....
One other thing I want to say, SW takes a bit more time to setup than F360, but SW is more accurate with it's scaling function.... I had to tweak all the images in scale in F360 to get them to match.... Each one has it's idiosyncrasies, the same but different....
Quote:
Ok I will start modeling with the Solidworks version as it is the version I am most familiar with....
The steps of this process is the same for both software's, SW & Fusion 360... The tools used are the same, it's just the way the tools are used is different between the two... Those familiar with SW will be able to follow with no problem, the same with F360.... I will be doing this in both software as I wish to learn to do it in both so those with F360 experience can advise me as well...
Disclaimer: The point of this is to learn the process of designing a 3D solid body ships hull... This is not a tutorial on how to use either software, (sorry brothers) If you need to learn how to use the software I would suggest you use any of the plethora of introductory tutorials on the net to learn the basic operation of the software.... There are many free ones both video and PDF for basic sketching and interface operation...
Also, I'm not going to get into the details of the actual ship... Windows, portholes, deck furniture, superstructure are not going to be modeled... Again, the point is to show the process of using common drawings to produce a fairly decent ships hull in 3D software....
Another thing to note, the software we are using is not CAD, it is parametric 3D modeling software. There is a huge difference....
Now onward...
What are we designing? We are designing a basic deep "V" hull... In it's basic form, it has two panels that form the hull that run the length of the boat... Think speedboat, PT boat, yacht, offshore racing boat etc. etc., it is a very, very simple basic boat hull design.... I think the technical term is a "Chine" hull....
They can be built in many different ways depending on the size of the hull from frames/bulkheads/plating in a shipyard, to molded fiberglass one piece, to plywood stitch & glue in your garage at home....
For our purposes, no matter the size, we will be designing it as a single piece... Creating the port side then using the software's capabilities, mirroring it to the other side and stitching it together to form the complete hull form as one solid piece...
All we really need for this type of hull is three drawings, Main deck, Full Side Profile, (including the underwater part) and a Bow on view, (preferably, so we can check the position of the chine locations) More drawings are better (especially a bottom view showing the chine location which I will be using) but not necessary...
We have already covered the steps in the two software's for getting the images into the software scaled and indexed...
Now on to the fun stuff, actual modeling...
EG
PS: If any of our brother ship  modelers are experienced SW or F360 users it is my sincere wish for them to chime in with anything that is a better way of doing things than I lay out here, please please chime in an d share! this is the point, start the discussion so we can learn the proper ways of using this newest tech and open it up to everyone.... Demystify the process
Edited by Egilman
Quote:
Ok lets get a hull built....
The first step is to start drawing out the hull curves in 2D space...
We start with the top view hull edge profile by starting a sketch on the bottom plane and rotate to the top view....
Using the spline tool create two splines, starting at the intersection of the front plane and the side plane...
The end of the first spline is located between the side plane and the side line of the hull... From there create another spline that runs to the portion of the hull side that is straight, (the connection between the two splines should be tangent to each other, SW does this relationship automatically)
Use the spline handles to match the spline to the line on the drawing as close as possible....
Next, draw a straight line from the end of the last spline, horizontally to the stern plane....
Make sure the connection from the straight line to the spline has a tangent relationship...
Also add a fixed relationship to the three lines, this fixes them in space so they can't be accidently moved... (I don't know if you can fix/lock lines in F360, you can in SW so take advantage of it)
Close the sketch and name the sketch to something you will remember... (include a number in the name so you will also know the order they were created, I used 001 Hull Upper Edge H Profile, the "H" is to tell you it is a horizontal profile)
Next, we draw the horizontal upper edge profile....
Create a new sketch on the side plane...
Draw a straight line from the front plane along the top edge of the hull to the point it starts to curve upwards...
Then draw three connected splines following the curve of the hull edge....
Then draw a straight line from the last spline to the stern plane...
At the two ends of the spline section, add tangency relationships between the end splines and the straight lines...
Close and rename the sketch.... (I used 002 Hull Upper Edge V Profile, the "V" for vertical)
Now we are going to create a projected curve in 3D space....
In Isometric view, you can see the two lines you just sketched, on their respective planes...
Go to Insert> Curve> Projected and a dialog box opens asking you to select the profiles you wish to project... You select the two sketches you just created and SW projects the intersection of the two curves in 3D space as a yellow line....
Accept that and the line turns blue and the sketch line dissappear in the viewport, (they still exist on their respective individual sketches).... You now have the top edge of your hull in 3D space... Simple wasn't it?
We will now continue on to project the compound curve chine line in 3D space....
Create a sketch on the side plane...
Draw a straight line over the upper chine line from the Stern Plane to the point where the chine starts to curve upwards...
Draw two connected splines from the end of the straight line to the bow stem line....
Add a tangent relation between the first spline and straight line then use the spline handles to match the splines to the curve, the same as we did for the first edge.... note that the line in the drawing is not a perfect mathematical curve but the spline is so you will have to compensate... (you want the perfect curve, if you duplicate the line exactly your hull will be distorted when lofted)
Close the sketch and rename it... (I used 003 Chine H Profile)
Start a sketch on the bottom plane...
From the stern plane draw four connected splines....
Rotate the model space so you can see you splines and the profile of the last sketch you made...
Select the left endpoint of the previous profile...
Now select the left endpoint of the spline you just created and add a coincident relationship between the two end points.... the spline point will snap to the side plane in the same position as the previous profiles end point.... Return to the bottom view....
Use the Spline handles to align the splines with the upper chine line in the bottom drawing as close as you can, when done add a horizontal relationship to the end of the spline at the stern plane....
Close the sketch and rename it.... (i used 004 Chine V Profile, At this point I think you all get the point of naming the sketches makes it easier to follow the steps you used to create your feature)
In isometric view you can see your two sketch profiles....
So we now project these profiles as well to project the chine line in 3D space...
Go to Insert> Curve> Projected, select the profiles you just created and wish to project, SW projects the intersection of the two curves in 3D space....
You now have two projected curves in 3D space covering the side of the upper hull, before we can loft the surface, we need to close the gaps at the ends....
First the stern...
We create a sketch on the stern plane...
Draw a vertical line down from the upper projected line half way down towards the lower projected line.... then you continue with another line connected to the first angled towards the lower projected line...
Connect the top vertex to the end of the upper curve, the bottom vertex to the end of the lower curve....
Turn on your stern drawing and rotate the view so you looking directly at the stern view, (normal to the stern plane) you see that your lines don't match up well with the drawing... The vertical line of the hull is not vertical it slants towards the center and the corner doesn't match the slight turn of the hull at the intersection of the lines....
Create a 200 mm fillet at the connection of the two lines... Select the vertical line and remove the vertical constraint....
Grab the upper vertex of the fillet and move it to line up with the bend in the hull side shown on the drawing...
Now, to close the bow...
Open a new sketch on the side plane...
Draw a line at an angle but off the bow stem line....
Select the upper vertex of the line you just drew and control select curve 1, when the dialog box opens select the pierce relation... The vertex will snap to the end of the curve line... Do the same for the lower vertex and curve 2...
Go to Insert > Surface > Loft, when the dialog box opens, click in the Profiles box and select both  Curves 1 and 2 as shown in the picture, a preview of your lofted surface will appear....
Make sure that the green balls are both on the same end as shown in the picture, If not, click and drag one ball to the other side of the sketch....
Next, click in the Guide Curves box and select the two end sketches, make sure to set Guide Curves Influence Type to "To Next Guide".....
Click the green check mark to ok the loft.... SW will take a few seconds to calculate the loft and pass it to the screen...
Here is is....
Next post we will start on the lower hull...
EG
PS: sorry for the long winded post.....
Quote:
Now we start on the lower hull...
Open a sketch on the side plane.... Draw a horizontal line from the stern plane to where the keel line starts to curve upwards....
Draw a single spline from the end of the horizontal line to the bottom corner of the loft you just created.... Make both ends tangent with the lines they are attached to.... Then adjust the handles to match the curve of the keel line as close as you can.... (may not be exact)
Create a new sketch on the stern plane... And draw a single spline as seen here....
Rotate the model so you can see both the spline and corner of the loft above...
Select the lower corner of the loft and control select the end of the spline and set a coincident relationship.... The spline end vertex will snap to the lower stern corner of the loft
Select the other end of the spline and control select the keel profile and set a pierce relationship.... The other spline vertex will snap to the end of the profile line....
Go to the normal to view the stern plane and select the spline, and adjust the handles to match the curve on the drawing as best you can....
Your two profile curves are set up....
Go to Insert > Surface > Loft, when the dialog box opens, click in the Profiles box and select the bottom edge of the hull side and the keel horizontal profile as shown in the picture, a preview of your lofted surface will appear....
Make sure that the green balls are both on the same end as shown in the picture, If not, click and drag one ball to the other side of the sketch.... (you see the preview of the loft)
Next, click in the Guide Curves box and select the Stern end profile, make sure to set Guide Curves Influence Type to "To Next Guide".....
Here is is....
Voila! you now have a finished hull surface... Make sure to save your file as giving it an appropiate name... (I used Hull Surfaces)
There is still a lot more to do to close off the Stern but I will do that in the next installment as this is quite long as it is...
Give it a try, it's not hard at all...
EG
Quote:
I now get it EG
Essentially, you created the sheer and chine from 2 views. The keel and stern are in the midline. You created the last needed line which is the stern. Then, the software created the 2 surfaces bound within these lines.
The issue I see is that these surfaces are bound to be flat, since more lines (frames) are needed to determine how convex or concave the surface will be along its length. The frames that this hull will produce will have 2 straight parts meeting at the chine, with no curvature at all.
Still, a complete hull produced relatively fast!
26 minutes ago, vaddoc said:
I now get it EG
Very true, chine hulls for the most part are just that, flat panels bent into a curve in one direction.... Extremely simple and very quick to build....
For example... A Sunseeker Predator 108....
No compound curves..... I'm not saying you can't have compound curves in a chine hull cause you can, it's just not very common and in construction terms overly complicated....
I think the whole process of building those surfaces took about an hour but it's hard to judge given the amount of documentation I was taking.... The whole process of posting that took 4 hours and the actual modeling of it was a very small part of the process....
I'm sure that this would work for a compound curved hull, I've built the superstructure of this boat and it is nothing but compound curves.... Two curves delineate the two edges of the surface and an edge forms the shape of the surface... You see this in the lower hull part, the stern edge not a straight line yet it forms the surface of the lower hull... which makes it a curved loft along a compound curved edge doesn't it?
Take a close look at that lower stern edge, it's a very gentle curve changing radius to a very tight curve at it outer end, look at the vertical stern edge of the upper hull surface it has a 200/400mm dogleg in it...
Compound curve hull, with no lines, no frame profiles, and no problems brother...
Edited by Egilman
Quote:
I would be inclined to return your sheer and chine curves into the centreline and form the radius so your side panel goes from stem to transom centreline.
If you place your control points in the correct way you will form an arc on the corner that is nearly as good as G3 continuity.
G1 means a surface is matched to the edge but does not carry on the shape, like the chine to bottom panel for example, G2 means it is Tangent matched, this means its matched only at the actual joint but is not a true curvature continuous joint and G3 means its a proper curvature match.
I would assume you are planning to create the transom separately and fillet the corner which is fine to but it gets messy when you create the stern duckboard, because you then have multiple surfaces you have to join up.
when you create a radius within a curve you need 2-3 points at the tangent point but along the straight (they must be in line) part and then one point out at the apex of the arc, imagine that the radius is a 90 degree corner before being filleted, you would place the point at the corner, normally you can control the weight of a  point to to make the  radius more or less pronounced or parabolic.
This is also how you forma turn of bilge radius into the hull side and flat of bottom without having to break the curve by filleting it, the closer you slide the 2 sets of 3 points to the corner the smaller the radius.
I think you are right EG, these ships look elegant but in reality their hulls are fairly simple surfaces and as you have proven can be built in a simplified way. Had not realised till now.
Couple of more thoughts
The stern line will indeed affect the shape of the surface but it will progressively get flatter the closer to the bow it gets, I see a ripple in your surface near the stern, I think this would need some looking into prior to building-something is not quite right.
Another thing, Rhino can do this, probably faster and better, as you have access to it you could have a play with it. I think you ll like it a lot!
I understand what your saying Richard, now I can change the stern edge of the upper hull to remove the fillet and use a spline to make the curve having complete G3 continuity, I just saved myself the work of that with lines and a fillet... I'll change it and post the results... As the hull build progresses the turn of the bilge is done with edge fillets along the curve which will result in the same thing.... The program handles filleting surfaces differently than filleting lines in a sketch... Being as this isn't a mesh cad program I don't have any control points to manipulate but showing the curve as control points is a good way to illustrate the problem you are explaining...
Thank you I will take out my shortcut and do it the hard/right way..... Good catch...
Thank you...
The ripple your seeing is a curve in the upper hull side that I took a shortcut in creating, it did the job but not as well as doing it the correct way with a spline...
Yes, Rhino is very capable I tried to learn it a few years back, but I just couldn't get around the whole vertex manipulation thing... ie. you build something over hours being very careful to make sure you get it right then you find you need to move an edge so you rotate the model so you can select the vertex's that make up the edge but when you do it you miss one... to make matters worse you don't catch it until your three or four more steps down the road..... Not being very experienced I couldn't fix it and more often than not had to completely redo the thing I was working on... Mesh software and I do not get along....
I'm not sure about the faster and better though.....
Blender, Maya, Rhino there are more of them and I've tried a lot of them... They all do beautiful work, for someone experienced in how they function... They are just frustrating to me, a tool I was unable to master...
I have a great deal of respect for those that get them to work for them... But I see work done in SW and Fusion 360 that rivals them all... and for some people I think they would be easier to learn and use... and yes I have access to Rhino version 8 is the latest I think...
Just my opinion.... Set up my table and drag out my pencils and I'll draw with the best of them, I still have all my drawing tools except for the table.... (and I shouldn't have gotten rid of that) But I have to go into software if I want to model what I want and SW and F360 are the first ones to actually give me useable, real world results....
Quote:
Ok I did the work on it tweaking the corner....
Much cleaner now....
Besides, it's all going to be moot, building the beavertail I'm going to have to cut all of that stern edge away....  Live and learn I suppose....
Quote:
8 hours ago, vaddoc said:
Looking good now EG. Time to build it now?
Not quite, I have to finish the build of the hull, solidify it add the transom and beavertail, mirror and stitch it together....
Although this would be buildable as a hull it is far from a complete model, but it can be used to show the possibilities of what SW & F360 are capable of...
I'll be posting the rest of this experiment later this evening...
Quote:
Hi Egilman Is this boat something that you will also be 3D printing?  looks like it would really be a treat to run (and fast) on the water for sure!
My Current Builds:
The USS Maine - 1/72 3D printed Armored Cruiser (1889) USS OlympiaUSS TexasUSS New York, HSwMS TapperhetenCerbere
Ships I am currently designing or have completed in Fusion 360:
German: SMS ScharnhorstSMS Kaiser Sweden: Svea, Gota, & Thule (both early and later versions), Flygia
France: French battleship Charles MartelDupuy de Lôme, Faucon (aviso), United States: USS Katahdin (1894) Ram ship, USS Monteray USS Oregon Japan: Mikasa, Fuso Russia: Izumrud, Novgorod Spain: Pelayo Great Britian: Turbinia (1894) - First ship with Steam TurbineHMS Edinburgh (1882) DenmarkTordenskjold
Ships I intend on designing & building in the future:
French JauréguiberryMassena Bouvet United StatesUSS Virginia USS Brooklyn, USS Minneapolis USS Ericsson
Russian:  Rossiya Peresvet Bayan SlavaTsesarevich
BrazilRiachuelo SpainEmparador Carlos V
Hi HG,
I'll admit it was an idea I toyed with,  but decided not to, besides I would do it as a static model... She would be a fast runner for sure, capable of 40 kts in real life, depending on which engines and drives she has.... a person could build her to run at any speed and she would look good...
I'm just using the hull to show the process of modeling one in a solid modeling program... Overall, I have about an hour and a half into modeling her and that is with correcting my shortcut... And I'm a relative newbie....
Anyway when I get the rest of it up we can see what people think of her and my weak attempt to model her...  {chuckle}
Quote:
Ok, three more sections to post, lotsa pics I hope it works...
Blocking in and shaping the stern...
We start with a sketch on the side plane.... Turn off visibility for both lofts and turn on for both the upper hull curve and the Keel profile....
We are going to draw a straight line matching the diagonal line from the top curve to the keel curve....
Now we reverse the visibility changes we made earlier....
We move the ends of the line coincident with the upper and lower edges of the hull surfaces, that check the line that it is still in position by turning off the upper loft...
You can plainly see that the line position changed at the bottom, so we correct this and turn the loft back on and close the sketch, (don't forget to rename it)
Now we trim the tail of the hull off, go to Insert > Surface and select Trim...
A dialog box opens and you set the trim type as standard, in the Trim Tool Box select the line you just drew... Set the Remove selections option button... Select the two surfaces on the right side of the cut line (they will turn purple).... Set the Surface Split Options to Linear.....
Click OK...
We start a new sketch on the side plane and draw two centerlines... (construction lines)
Select the upper centerline, control select the upper edge of the loft and give it a tangent constraint, then, do the same for the bottom centerline....
Now draw a diagonal line from one centerline to the other as in the image below....
We are now going to loft the upper part of the stern....
Go to Insert > Surface select Loft.... Click in the Profiles box and select the stern edge of the upper hull loft and the last sketch you drew.... Make sure the green balls are on the same end of the loft and your preview will show...
In the start constraints drop down menu, set the start constraing to Tangency To Face, and, Change the Tangent Length to 1.3...
In the end constraints select Normal to Profile, and Change the Tangent Length to 2...
Click OK
You now have the starting makings of a transom....
Start a sketch on the side plane....
Draw two lines...
Go to: Insert > Surface select Extrude, Change the distance into 5000 mm
Make sure that the extrusion is directed as shown in the picture.
If the direction is wrong, change it with the Reverse Direction button
Click OK
Go to: Insert > Surface select Trim, Click in the Trim tool box, Select the Surface-Extrude you just created, Select the “Remove selections” option, Select the three purple surfaces as shown in the picture, Select Surface Split Option Linear....
Click OK...
Go to Insert > Surface, select Knit, click in the selections box and select the Upper and Lower hull faces along with the Upper Transom surfaces, (they will turn blue) Select the ‘’Gap Control’’ option...
Click OK
IMPORTANT NOTE: It is absolutely crucial that the color of the knitted edges changes from blue into black after the Knit feature is applied. If the edge of the Knitted surface stay’s blue it means there’s a (small) gap between some surface transitions. Make sure that the color of the Knitted edges always changes from blue into black when you’ve applied the Knit feature. Otherwise it will cause problems later on when you want to convert the surface body into a true solid body.
They have turned black, this means that the upper and lower hull surfaces and upper transom have become one complete surface....
Go to: Insert > Surface Select Trim, Click in the Trim tool box, Select the Hull surface as the Trim tool, Select the “Remove selections” option, Select the surface extruded cut tool you used previously as shown in the picture....
Click OK...
We have just closed in the bottom transom...
Create a new sketch on the side plane....
Turn off the Bow Plane and draw a line from the vertex on the bow to the vertex point on the upper transom....
Go to: Insert > Surface select Fill then Select the two upper hull edges and the line you created....
You will see the preview of the fill operation...
Click OK
You have a temporary upper hull surface.... (almost a complete shell)
Go to Insert > Surface, select Knit, click in the selections box and select the hull face along with the lower transom surfaces and the temporary top surface, (they will turn blue) Select the ‘’Gap Control’’ option...
Click OK
All the lines are black, meaning it is one contiguous surface shell... We are about to make a solid...
Turn off all planes and drawings, then, spin the hull around to see the backside....
Go to: Insert > Surface select Fill, Select all the edges on the centerline... (you get a preview)
In the options section, select Fix up boundary, Merge results and Create solid options.....
(this will solidify your model)
Click OK
It is now one solid block... For confirmation we select the section view feature ....
That's it for this post, next post, I will be creating the hull bulwarks and the main deck surface.....
We are getting closer.....
EG
(sorry for the long post)
Quote:
Hi all, second to last installment...
Creating the upper hull Bulwarks and main deck...
Go to Insert > Features select Shell, In the dialog box, Change the distance into 120 mm... In the blue box select the two surfaces in the image below...
Click OK
A warning box may appear warning about minimum thickness radius may result in problems, Click OK for the thickness warning...
The solid body is now a shell at 120mm thickness...
Create a sketch on the side plane... Flip the model around so your looking at it from the back side... Turn on your side drawing...
Draw a line from one end to the other past the ends of the hull matching the main deck line on the hull....
Stern...
Bow...
Turn off the drawing...
Go to Tools > Sketch Tools select Offset Entities, In the dialog box change the Offset Distance into 50 mm, Select the five outer edges of the hull, the offset will be previewed (yellow)...
Make sure that the offset is directed inwards... If not, click on the Reverse button in the dialog box to change the direction of the Offset.
Click OK...
Go to: Tools > Sketch Tools, select Trim, In the dialog box select the Power Trim option and zoom in at the stern...
Click and drag the cursor over the over hanging line ends to remove them....
Repeat the process at the bow and select ok....
Select the blue deck line and apply a fixed constraint to it... The color of the line changed from blue into black which means that the line is fully defined...
Click OK and close the sketch...
We are now going to fill the remainder of the hull below the main deck leaving the upper hull bullworks...
In the feature tree on the left side of the screen select the sketch you just created...
Go to: Insert > Boss/Base select Extrude, In the dialog box, change the Blind direction to "Up to Next"... (make sure merge results is checked) You will see a preview...
Click OK...
You now have bullworks and a main deck....
Next up...
Final steps, cutting away the stern transom to open the poopdeck and creating the beavertail, fileting the hard edges and mirroring & merging the half hull to make a complete hull....
Quote:
Ok Brothers, Final installment....
Opening up the poopdeck and building the beavertail...
Create a sketch on the side plane... Flip the model around so your looking at it from the back side... Zoom in on the stern....
Draw three lines as seen in the image below, making sure that the forward line is coincident with the deck, and the aft line clears the transom and is lower than the deck....
Draw another line from the intersection of the deck and the inner transom wall up and to the left as seen below..
Select the deck line and the angled line and apply a collinear relationship, the angled line will snap to the same angle as the deck... Then trim the overhanging lines...
Click OK....
Draw a line connecting the angled line to the forward vertical line this creates a closed profile that we will use to cut away the transom... Close the sketch....
Select the profile you just created and Go to: Insert > Cut select Extrude, Change to Top view and turn on your deck drawing.....
In the dialog box, direction 1 section, click on the Reverse Direction button, (two angled arrows) to make sure that the cut arrowhead is directed towards the hull side.... Grab the arrow head and move it to the line as shown in the images below...
2021-10-23_07h28_54.png.a3573445aeb82a9595ab3eafafa95cc5.png2021-10-23_07h30_09.png.6dc701ff274a55b3694721ee01ab7554.png
Click OK....
This part of the transom needed to be cleared away because the ladders from the beavertail and a portion of the superstructure would need to take it's place...
Now we create the Beavertail....
Turn off the deck image, Turn on the side image, Create a sketch on the side plane... Flip the model around so your looking at it from the back side... Zoom in on the stern.... Turn off hull visibility of the last extrude that created the main deck... Draw the four straight lines as seen below....
Connect the upper and lower line with a spline closing in the profile, then give the upper connection a tangent relationship.
Close the sketch, (and remember to rename)
Go to: Insert > Boss/Base select Extrude, Turn on your deck image and switch to the top plane...
Pull the arrow to match outside line of the beavertail on the drawing... Zoom in to get it right, the line is a tad bit farther out than the hull side....
Select merge result and Click Ok...
This is what you wind up with, Perfect!
Turn off the deck drawing and turn on the bottom drawing...
Rotate the model to the bottom view.... (the grey area is your hull half)
Create four straight lines as in the image below.....
Draw two separate splines as in the image below, (don't draw them continuous, draw one, exit the tool, and then draw the second, you don't want them linked together....
Now, select the top spline move the right handle up and then give it a horizontal relationship....
Then select the left side spline, the lower handle giving it a vertical relationship...
Go to: Insert > Cut select Extrude, pull the extrude up past the top of the beavertail, as in the picture below...
Click OK
We now have the basic shape of the beavertail in place, we just need to smooth it out....
For this we use fillets & chamfers....
Go to: Insert > Features select Fillet/Round, Click on the blue edge as shown in the picture
Change the Radius into 1000 mm...
Click OK....
Go to: Insert > Features select Chamfer, In the dialog box select the Distance/Angle option change the dimension to 50mm, make sure tangent propagation is turned on in the dialog box and select the bottom edges of the beavertail...
Click OK....
Go to: Insert > Features select Chamfer, In the dialog box select the Distance/Distance option, In the parameters section Select Asymmetric, Turn off tangent propagation, put 300mm in the first dimension and 150mm in the second... Click on the blue edge as shown in the picture
Click OK...
Go to: Insert > Features select Fillet/Round, change the dimension to 100mm, make sure tangent propagation is turned on in the dialog box, select the five edges as shown in the picture...
Click OK....
Go to: Insert > Features select Fillet/Round, Rotate and zoom to the leading edge of the beaver tail, change the dimension to 30mm, make sure tangent propagation is turned on in the dialog box, select the edge as shown in the picture...
Click OK...
Rotate around to get a good look at the lower transom, select Fillet/Round, change the dimension to 100mm, make sure tangent propagation is turned on in the dialog box, select the two lower transom edges as shown in the picture...
Click OK....
Hit enter to restart the fillet command using the same settings as before click on the Hull chine edge....
Click OK....
We are done building a Hull Half..... Yay Team!!!!
2021-10-23_09h41_35.png.094c2776192eb60478eb516af6c7c5c6.png2021-10-23_09h43_16.png.6f9ed7659e6a0d2079a0b85fe3de34dd.png
Now we mirror it over the centerline and stitch it together into a single solid.....
Go to Insert > Pattern / Mirror > Mirror, select the side plane in the Feature Tree as the mirror face, Select the Bodies to Mirror option, Click anywhere on the hull half to select it as shown in the picture....
It shows you an outline of the mirrored body, Select the Merge solids option, Select the Knit surfaces option, Select the Propagate visual properties option to mirror any colors as well...
Click OK, (it takes a second or two depending on how complicated the body is)
2021-10-23_09h58_43.png.01944c4dee80e2c6c88a6cb87e3198d9.png2021-10-23_09h59_02.png.61c191170dd1d6d6ba95e83e40b17d42.png
That's it folks, She might not be as exacting as if she was done in cad, but for a 3D printable scale model? Looks pretty good to me... A fairly decent representation of a Sunseeker Predator 108 hull solidbody in Solidworks....
What do you all think?
Edited by Egilman
Quote:
Anyone out there taking a shot at trying this in F360?
Quote:
Well, I figured that I would take my rudimentary knowledge of F360 and try to build the hull the same as I did in SW.....
I spent four and a half hours trying to project the first two curves.... No go...  F360 does not have the ability to project two profiles lines into a projected line in 3D space...
Well not exactly, it can project two splines into 3D space, as long as they are contiguous, one-piece splines....... if your profile is made of of more than one piece like two splines or a line and a spline, it will not do it... I've searched the autodesk forums for a solution or workaround for this and see a lot of people asking for this functionality to be added to it...
It's probably my lack of knowledge and experience, but I'm dead in the water as far as creating the hull in Fusion 360.... I can't even get to the first hull side loft.... which only took about 5 minutes for me in SW just plugging along.....
I'll continue the series in SW as it seems that I understand it's tools better... Modeling in 3D shouldn't be that frustrating....
Edited by Egilman
Quote:
I just got a chance to try the same thing (projecting the curves) myself, today, as I haven't used the project>intersection function, but as you say, it doesn't do the same as the solidworks equivalent. Pity, there are places where this would be useful.
I think the best way to do this in F360 is through lofting with guide rails. The workflow would look something like this;
1. Draw the half deck view. You will only really need the outside edge, as a lofting guide rail.
2. Draw the side view. for the sake of simplicity here, keep the top edge straight and horizontal. make sure the sketch is closed (extrudable)
3. Draw the half stern view. Again, for simplicity's sake, make the top edge horizontal. (make sure the sketch is closed (extrudable)
4. loft the end to the side using the deck edge as a guide rail.
This will give you a solid half. You could just as easily offset the hull edges to give a thickness and loft these.
For what it's worth, I sometimes get tied in knots when lofting, with profiles apparently intersecting etc. And in passing, I sometimes get problems when combining complex shapes; I mention this because I use the same solution for both - I move one adjoining line either back from (lofting), or further into (combining) the other by typically 0.01mm. This usually does the trick. This issue has been very common, for me, when doing a '90 degree' type loft where the sections have a common line.
Kevin
Current projects:
Hi Kevin, I'm going to give it another try... I've found a couple of tuts on it online, (youtube tuts, Yech!) but any way there are two ways of doing it, I almost sussed out one of them before I got frustrated with it...
At that point it was time to step back and reconsider what I was doing... That hull should be buildable in F360... But it is a darn shame it isn't able to use multi-part profiles to project curves....
It would be much much more flexible that way....
Gimme a day or two and I'll take another crack at it.... I hate dealing with vertices....
Quote:
