I am looking for ways to print the name of the ship onto the transom of my Rattlesnake build. KenW has a great idea of using a black and white laser printer to print a black background on white paper to simulate white lettering on a black background. The results are really quite convincing.
I want to use a different color than white, but still have the black background. I was thinking about painting the paper with an airbrush using the color I want and then running that through the printer, but before I do that, I want to ask if anyone has had experience trying that idea. My concern is if the paint comes off during the printing, it could contaminate or damage the printer. Also, I don't know if toner will bond to the paint.
John
John
Current Build: Rattlesnake (Model Shipways 1:64)
Stores like Jo-Anns and Michaels in the US have tons of colored paper that should go through your printer nicely without damaging the printer.
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
I've been wondering the same thing in recent days.  Even if you match the color of the paper, the sheen, texture, precise shade is never exactly like the paint-- you learn quickly that there's a million forms of "white."  In the photo, you can see the color difference between the white paper and the white paint adjacent the stripe. I have also been printing text and then going back with fine brushes to add the correct white, and then tidy up with the text color-- essentially using the printout as a pattern of sorts.
I think the biggest issue might be paint wrinkling up the paper as it dries.  Perhaps if you know where the text will be on the paper, just pre-paint that particular area, so you aren't working with a full page of painted paper-- I haven't tried it, but this could work.  Wondering who will try it first(!)
Best,
Harvey
Another option is that most print shops will print a color page pretty cheaply.
Staples is a great place to get stuff printed.
That’s how I made custom decals for a P-51 that I built a while back (nose art, etc).
I printed them on a single sheet of paper, cut them out and glued them down.
Building:
You can buy waterslide decal paper from many places, it is available for inkjet or laser printers. The link is for the inkjet one I use. Just make your art work on whatever program works for you, I use Excel. Do a test print on paper and then print it on the decal sheet. in order to protect the ink you need to clear coat with spray can clear lacquer. I let that dry overnight and then you can use them just like any waterslide decal.
https://www.amazon.com/Nova-Horizon-Waterslide-Transfer-Printable/dp/B07X7GCP46/ref=sr_1_9?keywords=nova%2Bhorizon%2Bwaterslide%2Btransfer%2Bprintable%2Bpaper&qid=1636946168&sr=8-9&th=1
Be VERY careful selecting papers/decals to print in a laser printer! These machines fuse the pigments to the paper by melting the pigment at high temperature. A lot of inkjet materials will not survive a laser printer's fuser.
I speak from experience! I shopped around for a glossy paper designed for a laser printer. Someone at a print shop recommended a particular paper that "they used all the time." One pass through my laser printer sent the $800 machine to the dump (Samsung printer that did not have a replaceable fuser). Lesson learned the hard way!
1. As far as I can tell there is no way to print a glossy image with a laser printer.
2. Never buy a laser printer that does not have a replaceable fuser!
I currently have a Brother LED printer that has a replaceable fuser. It runs so hot it melts the glue on envelopes, sealing them shut. I can still split them open, but I haven't found any envelopes that do not have this problem.
I have printed decals with earlier printers, but I am worried that the Brother printer will melt them and cause a several hundred dollar repair.
I think you can be certain that if you run a painted/stained paper through a laser printer it will damage the fuser and possibly the paper feed mechanism. The bright side is that you will get to buy a newer and better printer.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
