Working on attaching wale using titebond II. Ive noticed that at the stem / ajoining timber connection the wale pops loose.
The remaining wale has stayed in place. The wale is prepared for this attachment by being  boiled and shaped on a board with pins to hold it until it dries.
The wood for the wale is walnut. I ve used this technique and type of glue for all wood needing to be shaped to follow hull line.
Is there another glue suggestion someone could please recommend at this location.
Thank you
Rick
Titebond needs to be clamped for at least 20 minutes and cure overnight, once it sets it wont pop loose, it’s stronger than the wood at that point m
However I do all my planking with Smith Industries Medium CA. It sets in 20 seconds but should also be clamped or held fast at the stem.
of you didn’t pre-bend the wood it will be more inclined to spring back
Now there will be 10 contrary opinions
Regards,
Glenn
Current Build: HM Flirt
Not from me..
May be too late this time, but next time you should consider providing a rabbet ( groove ) at the stem for your planking to sit into.
― Jimmy Buffett
Slow crawl:    Rattlesnake
Glenn,
I'm a complete neophyte taking your glue suggestion to the NRG "18th-Century Merchantman Half-Hull Planking Kit" bank, as it should be in the mail by the 2nd day of the new week. Thanks for the direction on some good glue. I guess I'll have to blame something else now, and it won't be the development of patience!
Ian the SaltyNinja
Edited by SaltyNinja
grammar
