Captains Log: Note to future self:
Self, remember how you decided to make your own sails and found the earliest blueprints then didn't use PPPPPP? Lest you have forgotten, you didn't bother to check the scale of your prints and then had to manually convert all the original measurements of each 46 sails to metric (hopefully you've learned how to read a ruler, or we've finally come to our senses and moved to metric) then had to redraw and cut the templates so you could then cut out each sail twice? Don't make that mistake again dummy.
A smooth sea never made a skilled sailor.
Link to my build
Captains Log: Although I'm at peace with cheating on the rigging and the generally poorly attempts thusfar, I cannot do so with the sails. Indeed one does not work without the other, but in Valkyrja's model ship world no one is losing sleep over the lack of proper knots. But a ship without sails is just ridiculous. I think I'd rather see burlap sack sails than none at all....But let's hope it doesn't come to that.
I've decided on what I feel to be a happy medium between realism and scale, a trade-off for my aesthetic, and I'm going to be implementing some (perhaps) unconventional techniques so that I can achieve this. I'm also going to repeat some of what I've already said but I want all my sources together.
So I started with the 1976 Revell Model Kit, which although plastic, I find to be very fine in detail and realism, something I don't see ever in today's age. The rigging was brutal so don't look too close, but I'm going to pull the "it's my first model ship build" card.
I don't know what I was thinking but I ended up putting the upper masts at the wrong location and have since amended that.
The Revell Kit comes with these plastic sheet sails that I scoffed at in distaste, but as I have now researched and experimented till my eyes bled, I can easily say I understand why they went that route...someone obviously had the foresight to want at least a few of their models completed...
I still don't like them, and after all the blood sweat and tears that went into that stupid rigging, how could I not give her the sails she deserves?
I am using the 1927 restoration sail plans by the Boston Navy Yard and generously offered for our use by the U.S.S. Constitution Museum, who also provided most of the information I was looking for under Modeler Resources. The plans differ slightly from the Revell Kit, but are more accurate for the look I wanted to represent.
Much invaluable help can be found in sail details, verbiage and actual use provided by the Historic Naval Ships Association textbook of seamanship manual, it's very much worth the read.
I printed the sail plans not thinking of printer scale and had to rescale all the templates, which may seem like more work than necessary (and it was), but I found it a good revisit of scaling math. In the interest of humor I will admit that I was extremely rusty and originally converted all the measurements to metric before I decided to use an engineers ruler....like I said...unnecessary work- here's a snap of my hot mess that makes sense probably to myself only.
DA65E0D1-BDE0-4F4D-B837-6006366CFFFE.thumb.jpeg.f85c9df52d92139c60408c790874c845.jpegI used an engineers ruler because I hate fractions and it provides much more precision than a standard ruler (architects rulers are, I believe, what most real modelers use).
The fabric I decided on after all my experiments was the Blackout canvas. It's true that it's heavier than scale and true to form, doesn't allow for any light, but I really liked the look and way it stretches and holds form. If anyone decides to try it out remember to mirror your studding sails as blackout fabric is canvas on one side and flat on the other.
0D50D3C7-7B98-42E2-9D6F-599ED59C6DC2.thumb.jpeg.94486f72bfa633011e3b565f65dcbe5e.jpegED557A9F-7B7F-4D93-A37C-7BFC4B4600DD.thumb.jpeg.e7cc96166e21add23175800869b8df46.jpegThe added benefit given by the nature of its construction, allowed me to score the seam lines instead of painting or sewing them on.
I'm at another decision point on whether I want to add any color, My Constitution has organically (or maybe subliminally) ended up as she was upon maiden launch, I'll be adding the Hercules figurehead and original rendition of the Greco-Roman gallery decoration. I've had a hell of a time finding an actual reliable rendering of these. But after painstakingly searching and sifting through The National Maritime Historical Society magazine archives, I'm using the Hercules as envisioned here and here as my "inspiration" lol. I could not find anything on the gallery aside from this ONE rendering which I find perfect, but I have no idea who posted it as there is no alluding to the maker or what their source was...so mysterious.
I also debating whether I want/need anything on the sails. In her beginning her sails would not have been so weathered as I've seen in other models but I may add some light weathering/shading for depth and realism. It's also unnecessary to do anything other than stretch the fabric to form it, but I can't believe that will withstand gravity for very long, and the non canvas side is very slightly "flocked" which I fear will end up looking fuzzy after manipulating it.
So the next decision is what to treat it with. I'm really leaning toward "RSG" or rabbit skin glue, since I won't be fully painting them with acrylic. RSG if you are unfamiliar is an archival glue that back in the old old days sculptors used in part to make "compo" or composition ornament for decorative picture frames, and was the standard ingredient in traditional gesso for priming and sizing painters canvases.
I am an oil painter and past conservator, so I have it (it's really cheap), and it's amazing stuff, with all kinds of uses. When used as a size, it's transparent, sealed, and tightens and stiffens fabric. Adjusting the ratio of water, adjusts the temperament and strength. Nevermind, I'm totally using it lol.
Link to my build
I think white of almost any shade would be distracting. Your build has a bit of antique look, which is a look I favor, so I think the sails would  look good with a sort of old ivory look. Very light and subtle.
You're the artist so use your judgement.
― Jimmy Buffett
Slow crawl:    Rattlesnake
Captains log: After cutting my sails and scoring my "seam lines" I found the same blackout material too thick to look natural as tabling and reef bands, so I opted for my sheer ripstop material. Glue was inadequate, messy and affected my paint so I used strong archival double sided tape and cut my strips from that. Then I used rabbit skin glue to stiffen and shape my sails. Below, the ripstop with two strips of double sided tape. This also made it possible to avoid shredding and cut very precise small strips.
612D6109-8A91-4081-AA3E-D7959403E6FF.thumb.jpeg.0c2d16b24a12456f335b0bff70ae2815.jpegIt was then necessary to paint them separately as they were very white.36C8165E-4BE6-4866-A675-A4AD197EDE78.thumb.jpeg.a574509816c59a0518eef2669ea58103.jpeg
The addition of rabbit skin glue was a wise choice if I do say so, the sails hold shape and can be reshaped well. The only downside was it affected my double stick tape creating a ripple I dislike. In the future I will add the reefing and tabling after as in the above photo.CD05D7A4-A8FA-4285-A2C4-F270133D85D2.thumb.jpeg.7b98b524a56290b201bab59b1e10ed68.jpeg
Here is the beginning of the final haul to port, which has taken me enormous amounts of time and figuring as I navigate how to best approach attaching and rigging the full sails. FED9A0D3-96BC-4A61-9EC4-09C550AAF64B.thumb.jpeg.0dfe1351d5541af7f458384dde0a0013.jpeg
An invaluable resource to me in doing this is The Young Sea Officer's Sheet Anchor; Or, A Key to the Leading of Rigging, and to Practical Seamanship. A free Google book written in 1853,  surprisingly easy to follow, and chock full of nautical skill.
Link to my build
I'll also add this wonderful and kind of funny email from Larry Ward of USSCMSG who confirms that I am the captain and may do as I see fit 😂👍🏽:
Hi Adrienne,
You have delved into a fascinating and confusing subject about which scant information is available, i.e. what did early frigates look like?  And since all serious model builders are hyper about details, you have plenty of company.
As to the colors used on USN sailing ships, in the first place the color scheme was determined by the Captain. And each Captain had his own preference, And each ship had several different Captains. And there were hundreds of ships, large and small. So, there are a thousand different possibilities. Which infers no matter what you decide, your chances of being correct are very positive in as much as there must have been at least one Captain who agreed with you. So, you as the builder are right, and no one can say you are wrong. Black hull, White gun stripe, Brown hull, Ochre gun stripe, whatever you like, you are the Captain.
Prehistoric Ochre was a favorite color of the early cave men who used it to decorate their caves. Lord Nelson wasn't that old, but Ochre was also his favorite color, for his ship, the HMS Victory, which was painted Black hull and Ochre gun stripes. Soon all the British ships were painted the same as Nelson's ship because the Captains wanted to emulate their boss. (Good career move kind of thing).
In the beginning the Constitution sometimes used the same scheme, depending on the Captain's preferences. But so as not to be confused with a British ship, the White gun strip became the most popular color for the gun stripe.
It used to drive the constructors nuts, but the Captains preference also ruled the number and size of the guns aboard the Constitution. And the design features were also subject to what the Captain wanted, For instance sometimes the waist was open and with another Captain it was closed.
Link to my build
