Thanks Rob!  I am followed your advice to work from the mizzen, forward.
I‘be learned a lot from your experience, also from George and Jared!
Rick
Well, September was quite a month. Finally retired after 40 years as an Endodontist (root canal specialist) and 45 years as a dentist!
The admiral and I celebrated by taking a Viking Meditation cruise in between clearing out the office and our daughter’s wedding in Ohio.
The fore and main tops still needed to be painted, planked and fitted out.  Both the main and fore topmast were made prior to the cross trees to insure accurate spacing.
The topgallant masts were also made as described by EdT in the YA books.
Finally got the tops planked and fitted out.
The topgallant tops were made same as the lower tops.  The spreaders are 1/32 inches brass.  I found it extremely difficult to cut .030 inches thick brass on the table saw and ended up filling them to a rough shape.  Fortunately after painting, the inconsistencies are not very noticeable.  I made the mistake of using copper for the cross bar. This was much too soft and didn’t hold the shape of the spreaders.  I ended up desoldering them and replaced them with 24 gauge brass wire that I filled flat on 2 opposing sides. This worked great and was easy to do and I will use brass wire again if I ever need to make spreaders in the future.
Both sets of caps were made and banded with thin ,005 thick brass strips.
Finally, items such as bolsters, fid plates chapping battens, blocks and sheaves were added.  I used 26 gauge copper wire for the futtock shrouds which were glued to the futtock band with cyano.
Shackles were made with 26 gauge copper wire.  Eyebolts for the shackles were made with either 26or 28 gauge copper wire depending on the location.  I’m trying to avoid using 28 gauge copper wire as I have had problems with it breaking, especially when it is manipulated.  The eyebolts, once twisted up seem strong enough.  Shackles were made per EdT, at approximately 1/16 inche .  All eyebolts that have lines attached, have shackles.
Finally, the ball shaped trucks were turned on the lathe, painted gold and I will use either straight pins or brass rod for the spires.
I think this completes the masts.
I added some of the rigging lines such as the toping lifts and mizzen course brace lines at this time as they will be difficult to access later.
IMG_4236.thumb.jpeg.fc1c077676eb1bb38b909ee9c8c8f1ee.jpegIMG_4242.thumb.jpeg.9b7c55cd47f16c7df8771371278faaaf.jpegIMG_4249.thumb.jpeg.96a37409826afc171a5d48c0d74a950a.jpegIMG_4250.thumb.jpeg.e2bf0d3ecc4ec5d28d68f2b38892c793.jpegIMG_4251.thumb.jpeg.305ba207d295527e574c6022ea09cf44.jpegIMG_4252.thumb.jpeg.4396e47dba44801111dee69a5af0c263.jpegIMG_4258.thumb.jpeg.96e5bb2ef7e86fd941759a079f2b5b56.jpegIMG_4259.thumb.jpeg.c4e01ba86ee933975ce314eadb9030fb.jpegIMG_4260.thumb.jpeg.0b70689d77955afa6489828f96c5b2e9.jpegIMG_4268.thumb.jpeg.6a4813beb77ac0b85ae3525b67f4b40d.jpegIMG_4271.thumb.jpeg.b6474ad04510a0085874ad3376b69207.jpegIMG_4277.thumb.jpeg.326bdeeaebca0d8b1607fc2f0afae30c.jpegIMG_4279.thumb.jpeg.3df9bc8a6295683ca490e61b7172ff73.jpegIMG_4282.thumb.jpeg.87ddc50311033bdeb7887bd4ea3e4731.jpegIMG_4290.thumb.jpeg.654592b69aefcb422c1ad0c36e680cac.jpegIMG_4293.thumb.jpeg.6bf57b2ca25fe4fc49ab83fd8fa54ef3.jpegIMG_4295.thumb.jpeg.8a5ac607896f4410875a72b43da20d90.jpegIMG_4298.thumb.jpeg.997e4118ad5f4de925cc443fdf4ee86c.jpegIMG_4300.thumb.jpeg.44a32af88392bb0ebc9114780b142e0f.jpeg
Congratulations on retiring, I hope you enjoy it. The model is looking fabulous!
George
I decided to put the mast sections together to see how they look and to check for alignment.
Still want to add some blocks and rigging line, but that is going to take some time as I figure out the sizes and lengths and prepare the lines.  Also , started to make the jib boom.
Merry Christmas to all!
RickIMG_4308.thumb.jpeg.85be73e49d46bfe6a12024645cbc9467.jpegIMG_4309.thumb.jpeg.7da6c397da55b4c1e43cf6f8d206549f.jpegIMG_4310.thumb.jpeg.e84454b5983ff891f42a48638628dc3a.jpeg
 Rick, Merry Christmas and Happy New Year to you and your family.
After completing the masts and ensuring that everything fit well and was straight (I don’t intend to glue the mast sections together), I moved on to making the jib boom, the 3 Spencer booms and the spanker.
All were made per EdT
I started with the jib boom, which was made of AYC.
The bands were made of copper tube and strips.  For most of the bands, this involved heating and expanding the band on a tapered metal rod until it fit on the boom.
The bowsprit band which houses the jib boom was formed with approximately 1/16 inch copper strip that was reduced to.010 inch thickness,  the tab on the starboard’s side was first bent to shape and soldered.  A #75 hole was drilled in the bottom of the band that placed over a pin in the bottom of the bowsprit to secure the band in location. The ends were then wrapped around the bowsprit and the jib boom and the tab was formed and  glued on the port side with cyano.  This allowed the jib boom to be held securely in place while allowing it to be removed for safety.
I decided to make shackles for the jib boom guys with thimbles made from 1/32 inch brass tube that was cut and filled to approximately 1/32 inch thickness.
Trying to solder the eyebolt: shackle combo to the bands was difficult and frustrating because I kept soldering the shackles to the eyebolts as well which kept the shackles from moving freely.  After multiple attempts and way too much time, I finally managed to get 2 bands made.  Not sure I’m going to try that again.
The main and fore Spencer booms were originally made from AYC, but were too fragile and kept breaking where I drilled the hole for the  in haul/out haul.  I ended up making them from boxwood, which is much stronger, although darker in color but hopefully will not be that noticeable.
The mizzen Spencer and spanker were made from AYC , as they are much larger booms.
Bands were made per the jib boom with shackles in the eyebolts on the spanker (I found a technique that worked consistently when soldering the eyebolts to the band)
The pendants for the Spencer booms were made of black thread (.08 for main and fore booms and .012 for the mizzen).
All have brass thimbles for the blocks to attach to.  I’m not really happy with the knots around the thimbles as they look too bulky to me.  The lines are secured to the thimbles with cyano.  I may redo these if I find a better way to do it.
The spanker was rigged with the foot ropes and topping lifts.  The knots in the foot ropes were made per Nic at Bluejacket.  Thanks again Nic!!’
All thread for the running rigging ( smaller than .08, which I buy from Syren) was dyed with walnut dye per EdT, then pulled through a bath of very dilute white glue.
The yoke on the inboard end of the mizzen spencer was shaped out of 2 pieces of AYC and drilled for 3 brass bolts of .02 inch brass rod. The parral. was made from22ga copper wire.
The cleats were made from brass wire and copper strips, soldered and filled to shape.
The in haul/ out haul was also rigged on he spanker and secured on the cleats.
IMG_4323.thumb.jpeg.64a4f4d760cd0605b7466053f9bd163e.jpegIMG_4327.thumb.jpeg.1e880004bfd9ec05f569f87881f1820a.jpegIMG_4328.thumb.jpeg.a40cfbffb7da15a8d4eeed2f83024606.jpegIMG_4329.thumb.jpeg.b4ff4e1dadd115373a05310e4895e71b.jpegIMG_4331.thumb.jpeg.87e01a0a6d1fd1a7b7b7dbbc1a16725d.jpegIMG_4332.thumb.jpeg.26889c5dc05757a58c315daf0dccbb58.jpegIMG_4334.thumb.jpeg.21ca56b7e14ac34ebccf349f9d4b1546.jpegIMG_4335.thumb.jpeg.e3e0c19e8a8ffe5a6603bb549d5e0ad4.jpegIMG_4336.thumb.jpeg.a27bf22b75801d5bf6e232334e036481.jpegIMG_4337.thumb.jpeg.806277b3b2bd9185f3d930cd74b44d1d.jpegIMG_4338.thumb.jpeg.a14f501874528b393fcbc6e810217a54.jpegIMG_4342.thumb.jpeg.cd8329fea0d710797e68d629149eed09.jpegIMG_4344.thumb.jpeg.7b3ebcffc364d830f8c9a6fb5d766357.jpegIMG_4362.thumb.jpeg.be88f2b0deb88fca54f31569571be42f.jpegIMG_4345.thumb.jpeg.262f97067d7783a6739c74e78fefdd7e.jpegIMG_4363.thumb.jpeg.d0474675c98bb361ae66c97f0c29cc06.jpegIMG_4364.thumb.jpeg.6ae849b6e09725b1a7880e54721395aa.jpegIMG_4371.jpeg.77077837360b752bf8d7902a3388a73d.jpegIMG_4372.thumb.jpeg.8160b8b46497fa2570ae239d13a7413d.jpegIMG_4373.thumb.jpeg.69ed1aeb59be53430034b3f941141e2e.jpegIMG_4374.thumb.jpeg.b45b273f0360b5d4f94fb526c01cae55.jpeg
I was just about ready to start rigging the mizzen mast when it occurred to me that
I needed to make a decision about where the davits for the quarter boats were going  to be located and the brackets installed.
My concern is that the davits and the davit guys will interfere with the run of the main topsail brace and the main course sheets.
The plans place the davits forward of the mizzen channels and looks to possibly be in conflict with the running rigging.  In this
position, the davits could be swung inboard, which would allow the quarter boats to be stored inboard.  This position is also shown on the Flying Cloud model at the Boston museum of Fine Art, and EdT’s extraordinary model of the Young America.
Alternatively, both the Buttersworth painting and the China Trade painting show the aft davit between the 2nd or3rd deadeyes on the mizzen channel.  This would obviously prevent the quarter boats from being stored inboard.  According to Campbell, in his book the China Tea Clippers, some ships kept the quarter boats on the davits for the voyage, triced up high.
In any event, I need to know the exact spacing between the davits to accurately place the forward davit brackets.  This meant having a quarter boat to measure from.  Therefore I decided to go ahead and make one of these boats now and not wait until the rigging was completed as previously planned.
I had already made 5 boats (see prior post), 3 of which were mounted on the foreword deck house roof.
The 2 remaining boats are for the quarter boats if I decided to use them.
I attempted to cut one of the boats in half on the table saw ( bad idea as it is not symmetrical and the smaller half had to be shimmed).
These were then caved out and glued to the keel, stem and stern post.
Very small strips of boxwood, for the ribs, approximately 1/32x1/32, were cut on the table saw with absolutely no consistency.
These were glued to the inside of the bulwarks and clamped.  Note in the pictures the liberal use of Bondo to get curves that would not break the ribs when glued.  The boat was then painted flat white.  I also made the rubbing strakes which were soaked in water and clamped to the hull and when dry, painted blue to match the other boats.
The rest of the interior will be made of boxwood and stained with Ipswich pine.
My wife and I are off on a short vacation, which gives me time to decide where to place the davits. Decisions decisions!
Does anyone have any thoughts?IMG_4404.thumb.jpeg.893a5560ed380938a026da7645d16a7d.jpegIMG_4405.thumb.jpeg.b00fe34a09c5f503805154034e91677f.jpegIMG_4406.thumb.jpeg.574da999d0067265e7da516752413f7a.jpegIMG_4407.thumb.jpeg.e24e62c405149c470a19592965541f71.jpegIMG_4403.thumb.jpeg.5a909141d2da4998da2d58362460a495.jpeg
Rick,
     This isn't necessarily correct but here's where I put the davitsdavits.thumb.jpg.e23147b0f0ce7e06d4a1876c7715598a.jpg
so between the 3rd and 4th mizzen shroud (counting fore to aft) and just aft of the main chainplates. I found that running the davit lines was complicated, but I was able to do so without interference if I was careful. The build log entry is here:
The boats are looking great!
GAK
Finished the first quarter boat.  The grating was made as before with boxwood and cherry.  Not at all happy with the result.  The holes and spacing are much too large but opted not to remake it as it’s not very visible.  Will do better next time.  The rudder and tiller were carved out of boxwood and the oars were made per EdT.
Small strips of boxwood were drawn through a draw plate from Byrnes model machines and it worked really well.  This was the first time I was able to successfully use a draw plate.  The first one I had from Micromark didn’t work at all with wood.  I read somewhere that the Byrnes draw plate was made specifically for wood.  The last 3 oars were made from AYC , which was much easier to draw and produced straighter oars.
I chose a length of 10 feet (1 1/4 inches) for the oars.  This looks about right.  One end was then marked at 1/4 inches for the blade and squeezed with parallel pliers.  This also worked well with no need to soften in hot water first.  The blades were then soaked with cyano to stabilize the fibers, filed to shape and painted flat white.
The handles will be painted blue-3/32 and the blades- 1/16, again copying EdT’s Young America.
Hinges for the rudder were made from 28 ga copper wire hammered flat for the strap with a straight length of 28 ga wire, soldered for the pins.  These were bent around the edge of a metal ruler that was the same thickness as the rudder and blackened.
The spacing for the davits is 2 1/2 inches based on the spacing of the eyebolts, which is  shorter than shown on the plans.  This was governed by the quarter boat, where the eyebolts could be placed on the model. The aft davit will be between the first and second deadeyes on the mizzen channel, and the forward davit just aft of the freeing port.  Hopefully this will work well and is a compromise between the plans and the paintings.
I will make the other quarter boat at another time as I am anxious to get on with the rigging.
Finally, the davit brackets were finished and mounted to the hull and the spars for the davits made, again using AYC, drawn through the draw plate, tapered and stained with Ipswich pine and satin wipe on poly.  I’m going to attempt to make the padding from some very old silkspan.IMG_4410.thumb.jpeg.0397779206e2861b372f14683f370904.jpegIMG_4418.thumb.jpeg.4f3b01417c6a2b811bf88cb3b6f66305.jpegIMG_4419.thumb.jpeg.63afc1e4a453c82258ded9e9906fbd6b.jpegIMG_4420.thumb.jpeg.824141cdaf290948dfaa917702172994.jpegIMG_4422.thumb.jpeg.8a5896f4ea8273aa8127584f006c293d.jpeg
A lot of fine demanding work clearly went into building this.  I think it looks great!
Before starting the rigging, it occurred to me that I should check the plans and insure that all blocks and pre rigging were complete.
This has been a long and occasionally frustrating process as I’ve had to constantly refer back to the rigging plans for the size and location of blocks , eyebolts and line.  Even with frequent checks, I am constantly finding errors that need to be corrected.  Because I finished the mizzen top first,  I found myself using the same size blocks for the fore and main tops, which is wrong because those blocks are larger, except for the mizzen brace and bowline blocks on the main top which are smaller.  Very easy to get confused, and I’ve had to correct more than a couple of mistakes.  I’ve also started to add some of the running rigging lines, which will be difficult to access once the masts and shrouds are in place.
I am using Syren blocks and rigging line which are really well made!  The blocks are stropped with 26 ga. Copper wire.  As I previously posted, the 28 ga copper wire breaks to easily and many of the blocks already stropped with the 28 ga wire have broken and had to be replaced with the 26 ga copper wire.  The hardest blocks to strop are the 2 mm blocks and my causality rate is probably close to 50% between dropping them and crushing them.
Because I decided to include the bowlines, I’ve spent a considerable amount of time deciding where the blocks should go on the main and fore masts.  These locations are not given in the plans, or in any reference source I have available, except for the fore bowlines which run to the jib boom and back to the forecastle.  These lines are easily seen on the model of the Flying Cloud.  The runs of the other lines are obscured by the sails.
I’m placing the bowline blocks where it seems logical to me.
I also started the second quarter boat.  This time I made a jig to cut the boat in half on the table saw.  This was well worth the effort as it cut the boat into equal halves.  I also hollowed out the insides and will glue the halves to the keel.
Finished rigging the davits with their spars.  Padding was made from silkspan.  These have been set aside until the rigging is completedIMG_4432.thumb.jpeg.a05bbb6827dcdc463fe106b6c4f8d42b.jpegIMG_4448.thumb.jpeg.02be2483d8ac374ad773aa421c2f87bb.jpegIMG_4449.thumb.jpeg.26fced11657f694e446b6ac622e7c5e8.jpegIMG_4430.thumb.jpeg.affbd27bc4bb8abe7b7396c7fae49000.jpegIMG_4431.thumb.jpeg.61ae62254fd683b3bcf730aafd0d2745.jpeg
 Rick, I post the following trying to be of help and not trying to hijack your build log.
 See page 12, post # 352 on how I wire strop blocks.
Keith, thank you so much for your input!  I read your post and it never occurred to me to use annealed wire.  Much stronger than copper and should be easier at my scale 1/96.  Plus the advantage of using wire closer to the correct scale!
Rick
 Rick, I use annealed wire for a couple of reasons, one it's black so I don't have to paint it and two, it's easy to work with. I work at 1:120 so I need all the advantages I can get. :)
I tend to use annealed wire as well - same reasons - it's black and easy to work with.
GAK
6 hours ago, Rick310 said:
Keith, George, thanks for the tip.  From now on, I’m going with wire.
Rick
Sometimes Revelation is the fuel for motivation.  I use steal wire, which does not abrade and is more naturally Pro typical.  IMV.  New ideas and material are always on the radar.
Good job everyone.
Rob
Current build:
Finished build:
Current build(On hold):
