Hi Wim,
this handrail is something I want to do in the future, but at this time no preparations are made for that. I will first findout if other Wasa builders made this also in scale 1:75 and discuss with them about their experience.
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
finalizing the parts on the railing (pins for belaying)
prepared the first clamps:
and continued with the galleries
Jan V.
Really nice work! I see alot of the original construction in your details. Theres a lot of work to get those inside walls of the bullwark to look like that. I like the weather deck planking also. Very realistic!
/Matti
Billing Boats Vasa
Hello Jan,
Nice progress. It's looking good.
The mountain strip is called the chain plate.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Anja,
These parts are called 'channel(s)', ('rust', in your native tongue)
Chainplates are the iron parts that hold the dead eyes in place. (in Rotterdam and surroundings better known as 'puttingijzers')
Jan
Anja and Jan, thanks for your comments
I should use the book of Montfeld when typing a post in English
Jan V.
Jan,
Hi, Ive been away and just starting to catch up. Nice updates. I really like your galleries. Those layered timbers make a huge difference. Your mast bracing plates (channels) are going to be perfect. You really captured the edge curves. No nice to have photos as a guide (:-) I also really like your hull and deck planking. Looks so good.
I'm happy to be back home and following my favorite builds Cheers.
MIchael
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Finally holiday, so some spare time to work on the Vasa
The guard of the King is visiting the yard
last stage of the galleries
and fixed the first channels
Jan V.
Jan,
In your Dutch build log you asked for feedback on why your bow roster was too high. As far as I could see on your pictures, it seems that you have attached the outer parts of the bow sections somewhat too high. I compared your bow section against mine (the level of my roster is somewhat below the hull level) and the curve of the outer parts ends somewhat lower in my build than in yours. At the time when I attached them, I checked with the brass figures how high these bow parts should be.
Hope this helps..
Completed:
Catalina from Mamoli (1/32)
European small river ship (scratch build) (1/50)
Currently building: Wasa from Corel (1/75)
Future: Titanic (Mantua), Batavia (Kolderstok), Friesland (Mamoli), Bismarck (Hachette), Prins Willem (Corel)
Hi Andre,
This point reminds me an hint I received from another Wasa builder to setup each item without glueing and check for further stages.
I made this mistake and cannot correct all items anymore.
But before fixing the outer parts I used the brass figures for the correct location, I will verify these again.
another problem is that I made some modifications without checking the consequences to later stages, like the canon openings.
Jan V.
I have started to redo the bow section as there were some failures
first the problem was that the planking in the bow section was not correct and second the doors were not correct
after thinking this issue during my holiday in the sun with over 30 degrees I decided to remove the wrong parts and start again
as the weather forecast for tomorrow is extreme high temperature (35 degrees) I might continue with an extra fan in my workshop.
Jan V.
Jan,
Nice update, again I love the "old look" of your build.
So you are also rebuilding areas that are not correct. Time consuming for sure, but after the fixes you will be much happier. They are worth the time and effort. If only we had known about these errors with the kits Before we started our builds (:-) Now that we have become "obsessed" its hard to move forward without first repairing the mistakes. Your bow doors will look much better. Too late for my incorrect doors.
Regards as always, Michael
Michael
Under the table:
Completed:
Vasa-Corel -
Jan,
I know that I have said this twice, but I so love the old look that you have so perfectly captured with your Vasa. This last photo is perfect. Are you thinking of  aging the wooden decorative pieces as well? I notice that your weather deck canon decorative pieces are "fresh" looking.
PS: Your galleries are so beautiful !!
R/ Michael
Michael
Under the table:
Completed:
Vasa-Corel -
I am still thinking about how to finish the wood. My first idea is to paint the wood partly in dark red like the 1:10 model in the Museum
all decorations are already partly painted with matt paint (Humbroll)
the old look you are refering to is done by using only wallnut wood. I replaced all other wood, specially the plywood parts
at this time I did not use any paint or varnish to the wood
the canons are directly out of the box as delivered by Corel, so no modifications or paint is done, I expect these deck items to be completed once the autumn has started.
the galleries are a free impression based on your start. :)
Edited by JanV
Jan V.
Nice going JanV. I'm following this build with interest. I specially want to see you paint job finished.
About a comment above about "aging", remember Vasa sailed only one mile and a half. She did not have time to "age" at all.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
made a test with varnish
I used varnish which is used for old looking furniture
the varnish is water based
Jan V.
