I’ve read the excellent thread here on MSW discussing the Model Expo ratliner and some related pros and cons of rigging on ship vs off.
In Ship Modeling Simplified, Mastini recommends putting the mast into a hole drilled into a 2x4 and building the rigging off ship before moving everything onboard.
What are peoples thoughts on his recommendation?
Mark,
What ship are you working on?  Rigging buntline, lift, and similar blocks on the yards is definitely a great way to go.  Rigging shrouds and ratlines off the ship,,,,,, no advantages and a lot of disadvantages.  There are good books on rigging as well as dozens of logs here that show good techniques.   Look at Ed Tosti's build log on Young America as one of many examples.
Allan
Thanks Mark,
At least you do not have to worry about ratlines on the pram😀
Seriously, study the build logs, there are a number of top rate builds in both the kit and scratch build forums.    Also consider putting some money towards a book or two that will teach you neatly done rigging from masts and yards, to standing and running rigging, blocks, and more.  When you go to choose your project that has shrouds and ratlines, to make life easier, consider a small vessel at a large scale (1:48) or larger if possible to start.   I am sure there will be suggestions from members on books that will help without braking the bank.
Allan
Hi Mark
Im currently rigging Caldercrafts HMS Diana as per the Mastini method and highly recommend it. Masts are assembled off the ship with the topmast shrouds and ratlines  firmly fixed to the deadeyes before attaching the yards. All off the ship. The mast and yards are then placed in the deck and all centre line rigging complete before attaching the stays. The lower shrouds follow. This is my second model using this method.
Mark...visit my log on Glory of the Seas(scratch build section, 1851-1900, and you will see my method...I always rig the mast/yards off hull...then mount the mast and finish things up on the lower mast.
Plus you can work at eye level and without any encumbrances.
Its the best method I've ever used.
Rob
Current build:
Finished build:
Current build(On hold):
Hi Granta,
I am confused by the order of dressing you give from Mastini.    From Lees, The Masting and Rigging of English Ships of War page 158.  The normal order of dressing for the lower masts is the "pendants of the tackles, shrouds, stay, preventer stay (on small ships it was sometimes the practice to carry the preventer stay under the stay.)"   For the topmasts, the order is "Burton pendants, shrouds, backstays, preventer stay, and stay"    Regarding the center line rigging which lines are you referencing on the center line if not the stays and preventer stays?  Is it that merchant ships used the opposite order of dressing than warships??
Thanks
Allan
Hi Allan
The “centre line rigging” as per  my post refers to the attachment of the lifts, truss pendants that belay directly to the deck beneath the mast. These are all attached to the yards when the yards are attached to the mast (which is a complete unit off the ship).
The mast unit  off the ship consists of the three masts (lower, top and topgallant), tops, all shrouds with the top shrouds plus ratlines attached to the top, all stays, Burtons, backstays, preventer stays, yards with slings, jeers, lifts, halyards. This is up to Mastini’s step 7 on page 62). This makes for an terrible tangle, but blue tape keeps things in a sort or order.
Then… masts are glued in. Then…the “centre line rigging” (sorry for being clumsy with the description) of lifts, halyards. Then…the stays  (Mastini’s step 12). Sorry I was unclear. “Attaching the stays “ refers to the final belaying.
Grant
Mark:
My vote would be for rigging off-model as much as possible. I tried it on my last model, and liked it. However, on my next build I’m going to rig everything from topmast up separately from the lower mast and yard, to keep a lot of the clutter from above out of the way for as long as possible. Also, I’d wait until the very end to add the ratlines for the lower mast shrouds … keeps open space for accessing the fife rail and pinrails to secure lines from above  A952A713-75FE-468D-A9F5-9D995DA955AF.thumb.jpeg.4ae8afccec16a42b6587fef0a960355b.jpeg
Steve
"If they suspect me of intelligence, I am sure it will soon blow over, ha, ha, ha!"
-- Jack Aubrey
Builds:
Yankee Hero, Fannie Gorham, We’re Here, Dapper Tom (x3), New Bedford Whaler, US Brig Lawrence (Niagara), Wyoming (half hull), Fra Berlanga (half hull), Gokstad Viking Ship, Kate Cory, Charles Morgan, Gjoa
This is my mizzen mast built off model for my Glory of the Seas build.   I leave off the crossjack and lower shrouds till after the mast is set and the bunt and control lines are belayed.  Makes it far easier to work around.
Rob
Edited by rwiederrich
Current build:
Finished build:
And after she is mounted and shrouds/ralines and backstays are added.
Much easier this way I think.
Rob
Current build:
Finished build:
One of my masts built off model for my Great Republic.   I also added the billowing sails at this time too.  Just way easier.
Rob
Current build:
Finished build:
