Lower mast sections dry fitted. The sections painted, woolings added, unnecessary groove at the top of the fore and main mast filled prior to painting. Blocks added to the bowsprit per Heller instructions and bowsprit glued in place. Still need to add the gammoning. I always love it when the mast, to include the bowsprit, line up perfectly behind each other as can be seen in one of the photos. Of course this is just the lower mast sections. Will see how they stay aligned as I add the topmast and the topgallant mast along with the shrouds and stays.
On 6/19/2023 at 6:05 PM, popeye2sea said:
My plan is to cut the mast sections flush with the caps. Then drill and re-use the caps, making my new top gallant masts from wood. I will also be making the top gallant cross trees that are very flimsy plastic.
Regards,
Henry
Sorry for the late reply.  I am also basically doing the same as Henry, here.  I will replace the topmast tops as well, as their scale and design is not really appropriate for the time period.  As for the cheeks that support the trestletrees, what Heller has moulded on the topmast and t'gallant sections is this weird conical thing.  I will make cheeks that are appropriate.
Oh good lord Marc, you are right I do have them in backwards 😀.  Glad I did not glue them yet 😳!  That would have been a mess. I will need to look at what the appropriate cheeks look like.
Thanks Marc.
Marc and/or Henry help!  I am dry fitting the masts. I can not remember when constructing the hull and the bottom deck where the anchor point for the bottom of the mizzenmast is. Does it go all the way through the decks to the hull similar to the fore and main mast? Or does it anchor on the bottom deck?  I seem to remember there being a hole in the bottom deck and I can run a thin stick all the way down to the hull at the mizzenmast location. However I am not able to get my mizzenmast to go any further down than the bottom deck. Holding the mizzenmast up to the side of the hull with the bottom at the keel seems likely me a very low mast top. It does seem to anchor somehow at the lower deck.
I believe the mizzen mast locates in a square hole on the lowest battery deck.  It can only go so far.  If the square pin locates properly, you shouldn’t be able to rotate the mast after it is seated.  If you didn’t true-up that square locating hole before closing up the deck, that may be a slight problem.  Either way, the mast can only go so far.
Ok guys I know I ask a lot of questions and some are probably dumb. I apologize for that and appreciate your patience. I have looked at this over and over. I am going to do the gammoning today. After that is done I want to add the inner and outer gammon support as shown in the instructions. Nothing I am reading shows how to connect these parts to a he gammoning. How do I attach them? Baker I even looked to the 1977 PDF you sent me, again thank you so much, and it does not say what to do to attach them.
Bill, those aren't supports for gammoning, they are a series of sheaves for future rigging threads which pass through them on the way to the fore rail. Make sure you have the openings through the assemblies clear of glue etc.
To attach them? I would lash them, along with a little bit of CA to hold them while lashing.
the 70s 80s solution from Heller.
the modern solution "a la" John  McKay20230622_181843.thumb.jpg.87a1e626397b7db8da0182709ba4789a.jpg
What an "English" method does on a French ship is not clear to me
Looking at the pictures of the rigging I knew they were for future rigging similar to the dolphin striker on the Victory. I referred to them as gammon support because I looked up the part #’s name in the ‘77 Heller instructions you sent me baker. My main curiosity is how to attach them to the gammoning?  There is a little tab at the top and bottom I assume I am to lash around the tabs and then all 5 loops of the gammoning pulling them tight behind these pieces like a pony tail?
Bill, while that did secure the rack block to the gammoning, I was not pleased with the end result.  It did not appear to be secure at all.  My final solution was to drill a small hole through the tabs at the top and bottom of the rack block, then run the lashing through that hole and around the gammoning.  It provided a lashing that is not likely to slip.
Regards,
Henry
Henry
Laissez le bon temps rouler !
Bill, these are called rack blocks in Karl Marquardt's book on model ship rigging. I can't tell yet which lines are which on the Heller kit, but here are two prototype diagrams showing the lines that ran through. The first is from the 1690's Royal Louis model described by Admiral Paris. The second is from JC Lemineur's Le Francois plans.
John O
image.jpeg.da8dcb45b03b307f89c37013addce92c.jpegLeFrancoisrackblocks.jpg.f25b0233c0117e17392a175f3ead8d0c.jpg
Gammoning and Rack Blocks (thank you John for the nautical name) completed. The method I used to attach the rack blocks was to drill a hole in the tap at each end. Then I laced a thread around the center thread of the gammoning and brought the ends through the hole in the rack blocks. Same process for the tip and bottom. Then I simply lashed the two ends around the back of the gammoning threads and tied tight with a touch of white glue.
Following Henry’s design I made a mast coat for each mast. I decided to paint them red to match the other deck features. The masts and the coats are still dry fitted at this point while I decide for sure if I like them. At this point I think I do. If I keep them, once I glue the mast and coats in permanently I have a tiny piece of trim to go around the mast atop the coat to close any visible gap. Thoughts/opinions?
Of course Henry. I know that is not a bowsprit 😊. I really need to proof read my comments and verify my nautical terms. Thanks for the correction. So what I actually did was remake my Spritsail Topmast. That of course is the name of the book I am consuming.
Bill
Edited by Bill97
Ok my extremely helpful friends I am studying R.C.Anderson’s book (pg 126), the Heller instructions with my kit, and the Heller 1977 instructions Baker linked me to. I am trying to determine where I anchor the lower deadeyes of the Spritsail Topsail?  There are 6, 3 each side. According to Anderson I think I understand they are attached with rope around the lower deadeye instead of being stropped with steel like all the other deadeyes at the channels. The rope then goes through a hole in the top and then down to……?  Anderson references an iron cross tree before 1650 and to bolts under the bowsprit after that. Neither set of Heller instructions show what to do. Your help on this issue would be great.
Edited by Bill97
As I read it, after 1650 (and probably before) the deadeyes were stropped in iron, "probably" (he says) with iron "puttocks"/"futtocks" hooked into them (much the usual way for topmast futtocks) and the bottom ends of the puttocks bolted near the bottom of the bowsprit.
The first way with deadeyes stropped in rope and puttocks above the bowsprit seems to me like a mechanically inept way of doing it, with all the sprit topmast strain taken by the knee of the top instead of the bowsprit; probably why Mr. Andersen is unsure of the scheme.
Edited by Ian_Grant
Ian I think I follow you most of the way, but not quite all the way. On the Victory we stropped the top mast deadeyes and then a futtock shroud was attached using a tiny hook. The bottom end of the futtock shroud then tied to the topmast shroud. I will this compare to how I do the spritsail topsail shrouds? I found this close up picture, zoomed in is a bit blurry of the bottom of the  SR spritsail topsail. It shows futtock bolted to the side of the bowsprit, three on each side. This looks like a good design. I just can’t figure out what the futtocks are. I assume the deadeye strop drops down through the top then something is connected to it and is bolted to the bowsprit.
Edited by Bill97
