Distant diagnoses are always tricky, but I would cut the deck-sheet to size, rub it downs somewhat with sandpaper, apply sanding sealer, rub it down again with fine sandpaper, another coat of sanding sealer, and finally rubbing with fine (0000) steel-wool. That should give you thin sheets of decking with a satin finish, ready to be glued into place.
 Good to see a post from you, Mark.
A little more deconstruction for the good of the build.  I pulled off the rest of the bow deck section and re-did the slope to bring it in line with a better representation of the ship.  I also took this opportunity to add a floor to areas that could be seen.  The real ship is very different (kit is way over complicated) but I didn't want to rip everything out.
I also designed the grating section.  The key here was to go off the actual deck piece and not the plans per se.  The result seemed to fit the bill.  To complicate matters there are two false decks here.  One tucks atop the frames but between the sides (1/32" thick).  This is seen below
The second sits on top of all so rises above the bulwark cap rail seen amidships (1/16" thick).  The side planking will also cover this.  On top of this will be the thin deck shown previously.  On the outside edge will be a 1/32" trim piece that will slightly hang over the edge.  This has not been glued and/or sanded to exact size yet.  You can also see the plastic 'C' channel on top of the bulwarks, not glued yet used for sizing.
The outside holes are for the grating sections.  They will end up flush with the deck.  Given the gratings depth I needed to cut out both false decks for insertion.  The center section stays open.
Next step is to get the gratings sorted and affixed.  Then on to finishing up the stern deck.
Stay Building My Friends, Mark
 The bow looks terrific, Mark.
Okay, I lied.  Decided to add the planks to see how they will look and if the self adhesive is still viable.  I was half way through and not liking the way the planks were not laying down (coming loose).  Decided I had Titebond at hand so started to add my own adhesive.  Seemed to work very well.  Each plank is laid individually.  You do not cut out a section and apply as one unit.
Now just need to carry on down the hull and bring to the same state of readiness for sanding sealer (for when it gets warm - feels like 8 degrees Fahrenheit here with snow falling currently.
Accepting input (did I do this already?) of color choices.   Bottom of hull will be patina-ized copper (greenish) that is set.  Question is upper hull and masting.
As seen today (white hull, light yellow masting with some black upper works) or
Fighting black hull, white stripe across gunports, black gunports, green inner bulworks
Or other.
Give me your thoughts.
 My choice, Mark.
I'm with Keith and think the fighting black hull is the way to go. Far more dramatic. I am really enjoying your build log and am glad you have resurrected your unique model.
Cheers,
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
I have been looking trough my references on Jylland and it looks like she has always been black with the white stripe. As for the inside of the bulwarks these are white on Jylland as she appears today.
Looking at old BW photos it looks like a very light color was used from the ship was new and my guess is it has always been white.
Steggen is always the voice of reason in crazy times / posts.
2 additional details:
1.  for the masting white or off-yellow.
1a.  Topmast black between mast top and cheeks?
2.  What about the grates / other - I 'assume' white also.
1. White
2. Also white
3. Natural or a light brown with a hint of red.
1. Masts are a pale yellow as are the funnel. Topmasts look to be black, but it´s a bit hard to tell as most pictures showing the whole masts are taken from some distance.
2 Gratings. This is a bit more difficult. Looking through the pictures from my visit in 1999 most of the gratings are covered by tarps. The grating on the raised fore deck is not painted as is the one below the steering wheel. This looks to be made of teak. As for the others both gratings and skylights looks to be painted a reddish brown color. At least the base of the grate/skylight is painted, the rest is covered by tarps.
In the drawing that is a postcard the gratings are painted white. This drawing depicts Jylland before she was rebuilt to serve as a transport for the Danish King as there is no raised aft deck.
That helps a ton.  Marching to completion.
One additional question (for now haha):  Is there any rake to the masts?  They 'look' at ninety degrees to water line (and at this scale that may be good enough).
 Mark, on each ship some rake added per the captains wishes. From what I've read and seen discussed most are between 3 and 5 degrees main and fore and no more than 7 degrees on the mizzen. If you search "mast rake" I beat you find several discussions on the topic.
Didn't I send you at some stage a list of all the drawings that pertain to JYLLAND from the archives of the Danish Navy Shipyard?
Basically, archival Nos. G1859 to G1896 pertain to her, including a rigging plan (G1872 and G1873). There are additional mast details at G4882 to G4900.
The mast actually look surprisingly vertical.
Mark,
I don´t have any good plans showing the masts and rigging of Jylland, but the attached picture is a sideview of the hull as built and show the masts below deck and there seems to be a slight rake to all of them.
First off - Peter:  Thanks for the kind words, just (trying) to have some fun.
Now to define why all the questions / rabbit holes.  This ship has gone through (it seems) so many big changes externally.  Add a deck, stretch the deck, change the deck furniture (maybe).  I had no idea when I started what a can of worms that would be opened.  Every time I look at a specific topic and compare the plans I have, the updated plans from Billings, pictures I can get from the web, plans from the archives and finally the input from this great group I have quite a few different answers.  Since I didn't know this from the beginning I have baked in some specifics variables from my re-draw of the hull plans.  Again, the bulkhead pieces were seemingly hacked out of the wood with a dull butter knife and the plans as shown did not have a right angle and could not be used fix the pieces (this kit from the 70's, not the replacement one available now).
I laughed this evening because I finally gave a close look at the deck fittings.  Let's start from the stern looking at the original plans:plans(2).JPG.1f28d95985d8213155216199bf530469.JPG
Pictures clearly show the ship's wheel is sitting on a grating (makes sense).  No such thing as defined on this model.  Looking at images, the next item up should be a skylight then a grating.  These are switched (or are they as defined originally?)  Under the ships boats there should be a skylight as exists today.  Would the ships boats still fit here?
Moving forward:
The funnel has a secondary tube.  Shown on the plans aft of the funnel.  Pics of the current ship show it forward.  The stairs down to the gun deck seemingly should be forward of the grate.  Even the funnel in the forward grate can be seen pointing forward and aft.
Is this all time period dependent?  Was Billings this sloppy or did they design off one set of procured source material.  I have looked at the 'new' 'improved' deck plans of their updated Jylland kit (real expensive) and they are not much different.
I think the answer is to rename the ship the Krylland (get it - Krug and Jylland - I crack myself up) and get'r done (joke).  This ultimately is for my Uncle so I will proceed making choices for aesthetics / function / and finally ~accuracy.  As always, I welcome any and all input just know I will probably make choices that will cause your eyelid to twitch a little.
This ship deserves a well made set of plans (or maybe 2 or 3 based on date).  A great ship.
Thanks again to all, I will endeavor to persevere
Mark, I can understand your frustration.
Like most old ships that have survived for more than a 100 years Jylland has been trough several rebuilds during her lifetime and the original plans does not represent the ship as she looks today. In the case of Jylland she was a derlict hull that at one time sank while layed up in Copenhagen. The restoration did not start until the 1980s and was finished in 1994. So Billing probably did not know the deck layout of Jylland when they put out the first  kit in the -70s. I have not had a cloes look at the "new" kit so I can´t tell how accurate or inaccurat it is.
Anders
Ever forward.  Updated the bow based on new information.  The highlighted 'brace' I hereby declare as the Steggen Brace.  I had no idea it existed until his pic.  As it be said, let it be done.  Looks much better overall with the added center platform.
Finally decked the stern area.  That took a minute.  Obviously deck furniture to be added.
Figured out my missing deck height on the main deck.  Looked at the cannon and for this kit they are very bare bones - only the carriage and gun which they want glued to the deck.  Well.....I can fancy them up and add wheels which will give me the necessary height addition.
cannon(2).JPG.9a06c18b2b357344421a46f939f345f9.JPGcannon(1).JPG.50eeeade0cd7431964983a3bf2a70e84.JPG
Now to sort out the main deck furniture so I can start laying out the deck and where planking is required.
One feature that pops out is the mid-ship walkway so decided to knock the base structure out.
Still need the guard rails but that can come later.  Affixed the plastic c-channel on top of the bulwarks to finish the look.  This walkway is easily removed.  This gives the ship an overall look of:
Decided to look closer at the cannon:
The bottom row left three are from the kit.  That flared out muzzle sure make them look older than the mid to late 1800's.  All supplied cannon are the same type.  For the main gun deck you get the top row guns which affix to the hull.  For comparison I grabbed in my stash a set of 18 pounders which I showed as the three shiny right hand ones.
My basic research shows the ship used (1864)  8-18 pounder, 4-12 pounder and 32-30 pounder guns.  The top deck has 16 gun ports with 12 guns identified so that is another question on what goes where.  I am toying with the idea to use some of my 18 pounders (obviously only on the top deck).  Have to ponder that one.  The guns on display at the museum definitely look more like the 18 pounder version than that supplied by Billings.
To ramble some more I am seriously considering having this ship put back into my list of ships to do once this is complete.  I have the next three projects waiting but think I could take what I have learned, research some more and produce a set of plans (and a list of assumptions) that would produce a better ship.  I would definitely need to find that book referenced at the start of this project.  The old girl is growing on me and I would like to do her justice.
Up next is to finish the planking on the starboard side and fabricate the missing deck furniture.  Masts/Spars are quickly coming up.
Edited by kruginmi
grammar
For drawings on Danish naval artillery 1850ff you may want to browse the archive for number G2092 and above:
 https://arkivalieronline.rigsarkivet.dk/da/billedviser?epid=17149179#190263,31920089
As I said earlier, rigging plans and details can be found under numbers G1872 and above: https://arkivalieronline.rigsarkivet.dk/da/billedviser?epid=17149179#190444,31922330
 Mark, the planking looks great.
It's probably a bit late comment, but I think something is off with the position of hawseholes and chase ports. They both appear to be more forward and closer to centerline on most of the plans and on the original ship as well. And the size of the chase port is identical to the regular gunport + angular cut.
image.png.4a49eb7c5b0f71f5045e5967dc82b248.pngimage.thumb.png.e6c648a0f017c0b5aabd97bd625e5ef4.png
Thanks Martes, but this is a conundrum of the original kit and not realizing how off the kit was.    They were baked into the build before I realized how different the two were (reference the deck fixture observations above).  I should re-iterate this kit is from the 60's-70's and not the latest incantation.
Pushing forward.  Mark
Yes, I thought it's the kit problem.
FWIW, the easiest solution would be to shut the incorrect ports and holes off, and just paint them in the more correct places afterwards. That won't fix the shape of the forecastle, but still give better appearance in the end.
The chase holes and such were modeled after this piece of plan that Anders has shown previously.
The ship has undergone a lot of modification and somewhere a line in the sand (or hull haha) had to be drawn.  I based the chase port off of the leading edge of the forward top deck - not the forward stem.  To get this to my Uncle and move forward I am going to leave things as assembled.
I also think some camera distortion in the pic is making things look stranger.
Working through my view of how to do the deck fixtures.  I think I am happy with the result.  Getting these set will allow me to begin planking the deck.
Notes:
- The skylights (2) are currently placeholders.  They will be replaced with better examples.
- The binnacles (plastic) will have their posts replaced.  May keep the top part.
- All the belaying pin mounts are still TBD.
Using cherry wood means I do not have to paint these.  The funnel base is the one exception - black.
IMG_7612.JPG.7162a4b66bc5c94fc88b4fbbcdf93a17.JPGIMG_7611.JPG.008c3d2b9b0dade1be014e1b137edc7e.JPG
Cheers, Mark
