6 minutes ago, Old Collingwood said:
Superb work,  all the extra work  will  so be worth it  as  she builds into a  real piece of art.
OC.
Thanks OC
Your build is the inspiration for mine and I refer to what you did with your Pearl frequently
I really appreciate your commenting and support, mate👍🏻😎
Scott
1/72 Zvezda The Black Pearl
13 hours ago, Twokidsnosleep said:
Thanks OC
No problem at all.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Working on the foremast I believe this is called
I re-inforced the mast with a wooden dowel ála Mr OC
And then took it to the lathe to remove the six moulded rope windings so I can add the Ropes of Scale rope
I was fully prepared to make a wooden mast if this broke or I FUBAR’’d it
Was careful and it came out ok, but the styrene is very flexi on the lathe and so hard to turn concentric
Now in primer to get the oil paints today
Edit: added the oil painting pics
Edited by Twokidsnosleep
Scott
Your lathe makes quick work of those plastic wooldings so that you can replace them with rope — it will look much nicer.  On the kit that I am building, each of the wooldings consisted of two separate “rings” spaced a few millimeters apart, so I eliminated them by scraping them down with a blade, because I also plan to redo them with rope.  I imagine that it would have been much more taxing to scrape them down by hand if they were 5 deep like on the Black Pearl kit.
I have another pic of taking them off the foretopmast as well..will post it later after work.
What purpose did those rope windings have on the masts??? I have not been able to find an answer so far in my research
Scott
  Masts are sections of tree trunk, of course - so the growth rings (harder than the early season wood in between) encircle throughout.  Take a look at the 'end view' (or a stump) of a newly felled tree and you'll see what I'm talking about.
  a living tree has an awful lot of water content, and much of this is lost once cut as it dries ... but there is always a water content (unless left in the desert, and even then there is a little).  Wood shrinks width-wise as it dries, so the further out in circumference the greater chance of a serious crack developing - which will run up and down. Oiling dried wood helps lessen the travel of moisture in or out of wood in the short term - furniture makers know all about this.
  Strong forces can bend and snap a mast, and if you simulate this by snapping a branch often large 'shivers' connected to one piece or another can be produced.  Wrapping rope around in bands will significantly reinforce the mast section against snapping.  Perhaps you've seen period cannon with iron or steel 'bands' around the barrel ... they also do reinforcing.
What a most thorough and excellent answer SHJ
This is why I joined here, just great advice on this site so far
I am a woodworker so clearly understand your lesson. I was worried I was missing that this wrapping  tied into the rigging somehow, but could not see that on any of the research pics so far. So your answers absolutely makes sense and I thank you a ton
Scott
I took them off
Then added them back
I used the tan 0.7mm Ropes Of Scale as I am saving the black for rigging. I can weather this up and easily darken them
Not bad result, looks cool especially in the contrast colours
A research pic shows unevenness and really worn rope, so some realism in my imperfections
Scott
I learned about “whipping” a rope today from a YouTube video and have used it on the mid foremast wrappings.
A loop is made with a tail lain along your mast. You wrap around this from the bottom up, threading through the loop at the top.
Then pull the bottom tail and it tightens the loop down under your wrappings. Trim top and bottom threads off.
All of these rope wraps have zero glue on them. Zero. This has the tell tale  pull down ‘v’ at the top that matches my research picture in the previous post.
Paint touched up and test installed with the rest of the foremast
Masts make a ship pretty darn tall pretty darn quick
Scott
Excellent work  -  so  makes  a  difference.
OC.
Current builds
Completed works.
That whipping technique is usually used to stop line ends to fray. It is quick and easy when you get the hang of it.
For a more secure whipping one can use needle and sew it on.
Anyway, your whippings on the mast look the part!
Happy modelling!
Håkan
Previous builds
Kågen by Wintergreen
Regina by Wintergreen
Billing Boats Wasa
Gallery:
Starting the main mast. Using telescoping brass rod and tubes for internal strength and solid connections
The foremast and its’ rope wrappings got a coat of the black oil wash that brings the black into the Black Pearl
Scott
  "I tawt I taw a puddie-tat ..."  (Tweety Bird in the  old Warner Brothers cartoon)  Then there was Yosemite Sam, "Great horny-toadies!"
I am away from my modelling desk travelling so some downtime to research
Looking at OC’s build and how he replaced some of the smaller mast parts and spars with wood🤔
So do I worry about the styrene mast parts supporting the rigging tension or do I replace them now with wood or brass?
Have learned the hard way that styrene plastic may let you down.
This motorcycle’s main fork tube was left styrene ( green) and it broke well after full assembly😱
I had  to jiggy-Jack telescoping brass tubes into there to get around the electrical, brake and clutch wiring to reinforce it all and get the forks back on.
Would have been way easier if I did that at the start.
I think I am  answering my own question with the plastic mast parts and the rigging😊
Scott
Wooden  top masts  and  spars  will  certainly  benefit  you, to avoid  the  rigging  bending them.
OC.
Current builds
Completed works.
5 hours ago, Jeff T said:
I plan on using wood for the small masts and spars to try to avoid bending while rigging (but also so I can change their lengths).  By the way, very nice job on those motorcycles — you really make them look real.
Thanks Jeff
I have built a lot more bikes than ships😱
Scott
Alright, my goal this Victoria Day long weekend was to finish the brass work for all three masts
done!…,wasn’t easy, some burns, some screw ups, some swearing and some back to starting boards
Everything is still loose here and not in final positions or perfect alignments
All three attach to their respective mast differently. I would love to say this was on purpose to avoid confusion, but it is truly just poor planning on my part.
‘I have kept the plastic masts as back up I suppose. It is easier to create something when you have the real thing to copy from
This sucker is going to be hard to work on and photograph as I get all the masts and such on.
Largest kit I have built so far, other than a Space shuttle and her launch pad…that was TALL!
Scott
