Nice work on your Endurance. Within the next week or so I'll be posting my progress on hull planking . . . so far, only 5 planks on each side.  And as you'll see, my approach is to not worry about uneven planks, cracks, holes and gaps for now, and let filler, sanding and painting hide all the flaws.  The precision in your first layer could be stained and otherwise unfinished.  Great work!
Tom
________________________________________________________________________________________
Current build:  Grecian -- Vanguard Models;  Half Hull Planking Project -- NRG
Completed ships & boats:  Shackleton's Endurance -- OcCre;  USS Constitution cross section  -- Model Shipways;  Joshua Slocumb’s Spray -- BlueJacket
Yacht America -- Model Shipways;  Brig Niagara -- Model Shipways;  J Boat Endeavor -- Amati;  Peterboro Canoe -- Midwest Models;  Bluenose -- Artesania Latina
 Other:  Wright Flyer -- Model Airways;  Sopwith Camel -- Hasegawa
Thank you but I think that the drum is too big and I used rigging blocks (wood) from the box also too big. Brass pulley is a better choice but at the end the cost increase !
Have a nice day
François
In progress Trabaccolo -MarisStella - 1:32
________________
Completed :
Endurance (log - Gallery)(OcCre), Granado 1756 - HM Bomb vessel - JoTiKa/Caldercraft - 1:64
I am debating at the moment if i should either buy the metal blocks for the steering chains, or attempt to scratchbuild them- as to the wooden drum - still looks better than what occre instructs.
Keith
Keith,
Brass block is more realistic and may it is possible to get at the good scale.(https://www.cornwallmodelboats.co.uk/acatalog/CAP-Rigging-Blocks.html). You will need also  chain in black
For your information, just before the endurance came in the weddell sea the steering gear was visible ( not protected). See picture.
François
________________
Completed :
Bonjour,
On the topmast
  • Furled sails (Premium cotton sail fabric - Ecru 75g/m2)
  • fore topmastl with furler + spanner
  • Finished shrouds, beginning of ratlines (0,5mm brass wire with chemical blacking)
  • Beginning of the stays (anchoring on front deck and not on bowsprit)
  • Installation of the lift
  • backstays to start
François
________________
Completed :
Bonjour,
Almost finish after the liferafts...
I change the flag ( blue instead of white) I add navigation lights
Edited by Jorez de Saint Nazaire
François
________________
Completed :
Very well done François.  I'll be referring to your log frequently in the many months ahead as I slowly make progress on my build.  Thanks for showing the way.
Tom
34 minutes ago, wmherbert said:
Beautiful job. How did you do the ratlines with wire? They came out very nice. Any tips?
Bill
for the ratlines I used brass wire (diameter 0,5mm) after blackening
Have a nice day
François
________________
Completed :
