Hull planked with Obechi. The planking is nit the neatest job in the world but it will be covered with resin and cloth and painted.
Stern will eventually be blocked in with Basswood. Making a start on rear deck superstructure. Decks lose fitted for now. So far really enjoying this build.
Edited by Riotvan88
Are you using plans from Billings? I built Smit Rotterdam 35 years ago so I will be interest to see how you get on.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
No the plans are from a German hobby company done in 1/100 scale. I believe the billings zwarte zee kit is in 1/90. I've already built the billings smit rotterdam which is 1/75 so I've scaled these plans to match.
  • 5 months later...
Hull looking good - workbench may take some time to find😀.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
  • 8 months later...
20 hours ago, Riotvan88 said:
After much messing about
It must have been a major messing about - 9 months. Hull looking very good.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
On 8/14/2024 at 9:29 PM, Ian_Grant said:
Looking very nice!
What is her length? What type of motor(s) are you planning to install?
Thanks. It's 41 inch long 1/75 scale somewhat bigger than the billings kit which I believe is 1/90 scale. I'm not sure about the motor setup yet. Most likley a high torque low RPM 600 size motor powered by a 6v lead acid battery.
Edited by Riotvan88
  • 7 months later...
  • 3 months later...
