I need to know the sizes of the pedestals used to mount this ship. The parts were not included in my kit ( cost savings by manufacturer?) There are two different sizes needed. I am hoping that whoever mounted thier kit has kept the parts list if there kit came with the pedestals.
Thanks for your help.
In its mounted condition, the model’s waterline should be level.  If you have the drawing that you used to build the model simply draw a line parallel to the waterline shown on the drawing.  Draw lines perpendicular to the line that you just drew and measure the distance to the keel.  Buy two pedestals that meet these dimensions.
If you don’t have the drawings set the model up temporary supports with the waterline level.  Measure up just like you did above.
Roger
Edited by Roger Pellett
If there is a lamp assembly store near you - if that is still a thing - hollow brass cylinders of various sizes and shapes?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
If no lamp stores some the bigger hardware stores have lots of lamp fittings.
