I decided to start my Chris Craft kit to take a break from the Morgan
this is a Dumas kit that ends up just over 13 inches
on inspection seems the frame and first plank layer is balsa wood, will see how that goes
IMG_0833.thumb.jpeg.11d0eafff196ab2e3b5f38ed3bbdf6ce.jpegHere is kit pieces and the frame I already assembled IMG_0807.thumb.jpeg.1381244944278cf1b4100512a73221bc.jpegIMG_0808.thumb.jpeg.28fecb79e543501fd3cff2e7aab5fe98.jpeg
kit has lots of planking and bag of resin parts like horns, prop, wheel etc
also decals , I think I will see if I can make some of the details like step areas instead of a decal
IMG_0831.thumb.jpeg.d359397c67a3010d9c7acc74f15df562.jpegIMG_0833.thumb.jpeg.11d0eafff196ab2e3b5f38ed3bbdf6ce.jpeg
Installed the chines
used elaborate string work to hold them in place
the balsa is too flimsy to clamp, basically turns to mush
onward and upward to the sheers
those will require soaking and bending at the severe twist in the stern, barrelback section
Hey man, I didn't know you had a Proxon! Congrats!
Looks like an interesting small model.
Remember my old Lumba-Lumba which was balsa? ... not ideal for an RC boat; too soft. Still has a ding where George's boat hit her. 🤨
She's still in the basement drydock. Here are two of the fleet which you may remember.
I can’t believe you still have the box for Lumba Lumba
i had forgotten about the cabin cruiser
i have the cheap Proxon, no tilt, no height adjust
should have gotten better saw
Oh, HaHaHa!   I don't have the box from the 70's; I just found that image......;)
No tilt, no height adjustment?  That's very limiting in a saw, all right.
Edited by Ian_Grant
I am working on balsa layer of planking
i saw a picture of actual boat that shows the planking has a bit of an upward sweep at the shear as well as quite a weird shape at the bow , that deep cut or twist below the chines
seen here
not obvious in the instructiions
Edited by rookie
Added further comment
  • 3 months later...
I finished the balsa layer of planking.
still some shaping to do then I move on to mahogany layer.
i also put together the seats. I have been thinking of ordering faux leather or real thin leather for the seat cushions to make it look more interesting.
IMG_0908.thumb.jpeg.d18f49d32044b425889e65d0f0bc8e60.jpegIMG_0907.thumb.jpeg.4f5227d8d2a77a598ad5d025df525c13.jpegIMG_0904.thumb.jpeg.1c3b984dda5d2052c3b472b5be5a1233.jpeg
  • 3 months later...
Managed to do a bit of the mahogany layer on bottom over the summer
going about it in a strange way likely but I find the flat bottom quite different to the usual ship hull
IMG_0928.thumb.jpeg.dbe2234d449e579eaf80c0fd721a5f1b.jpeg9IMG_0921.thumb.jpeg.14456cc66623594ab64be7aacb8787cf.jpegI also had an idea to add the engine and have the compartment open
spent time looking at Chris Craft engines from the late 1930’s
seems to be inline 6 usually
I searched for 3D inline 6 engines and found a few sinam printing sample parts to see if they will work
IMG_0929.thumb.jpeg.50a9f5bd22ba760a0e47eb14490c832b.jpeggone back to my Morgan for a change of pace for now
