I made the hull. It looked clumsy and wide.  I had to remeasure to get the proper dimensions
Excess "fat" was trimmed down and it was shortened by 3 cm.
After more careful work I shaped the sides and upon finish wood was polished
Then, I add the PE heli deck on rear and a 2.5 mm piece of resin on bow to make the right elevation
Finally priming and sanding the bow, stern and the sides, several times.
IMG_20240223_202852.thumb.jpg.7da39161c6ff1edbe4a21d83c2a1a040.jpgIMG_20240223_203058.thumb.jpg.c4583f5a9a2a9f76c9685046f1250cbe.jpgIMG_20240223_203126.thumb.jpg.0ab08a3ebef5ebae51f358a820344f26.jpg
Next was to print the central area between the hangar and the bridge where funnels and towers will placed upon.
However because of warping problems that I couldn't solve after many attempts, I removed it and replaced it with plywood wrapped with plastic fillets for a smoother finish. This handwork took me 2 hours instead of 2 wasted evenings, what a bitter lesson.
Fortunately the other piece, the main canon printed just fine and a barrel made of needle pieces was added along with hand rails.
IMG_20240229_200759.thumb.jpg.26c196339cf2c4c0e455821d72c43264.jpgIMG_20240229_194810.thumb.jpg.85fccebbc8249f1b734fe5164e137900.jpgIMG_20240229_195013.thumb.jpg.72915f05b0722154afc36c7694890347.jpg
Next was the hangar. I printed the right half and made some adjustment to fit the PE externally. I made them in separate pieces so I can scratch built the interior more easily them glue them together. Like in Horizon class because of the side compartments for inflatable storage, the heli hangar is somewhat narrow.
IMG_20240302_181507.thumb.jpg.761a44fa3f8b3c2df6b4316d3668c683.jpgIMG_20240303_204341.thumb.jpg.51201dbc947b93e73d2a0d9c22442106.jpgIMG_20240303_204509.thumb.jpg.18b72669381c993587da69c58846a6cd.jpg
I printed most of the parts.Since I used a plan to calculate the size of the pieces and the PE parts are made to replace standard plastic parts of specific kits some misfitting is expected. Some PEs won't be used as the required details is already designed at the parts I printed.
IMG_20240307_202137.thumb.jpg.00593100d4348ba816c2f22488f5dc15.jpgIMG_20240307_210910.thumb.jpg.2076de29f3cf210568a95b113a1a0dc8.jpgIMG_20240307_211024.thumb.jpg.82c2680f8d182fc7bb5f390198a48224.jpg17098417781672560014720549195373.thumb.jpg.4cf737d9b6eee4746d6dfe297953edeb.jpg
An impressive little ship, excellent work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
