The next is the level 2 Norwegian Sailing Pram. :D
Unfortunately, this kit also has some minor laser cutting issues.
Don't forget to enlarge plans in the instructions! My ratio was 102.85%.
pram202.jpg.0aad0bd781c0abd7469a6dcd6d975a7b.jpgpram203.jpg.51746dd1afa97ab586d0242791669761.jpg
Bow transom.
pram204.jpg.c8d7c6481e91bd749bee733b37d142ef.jpgpram205.jpg.55452451eedfb962e7026503c59e0f72.jpgpram206.thumb.jpg.ff0162a2f0b4e2d8b2a89a3f5ce3a3e2.jpg
Stern transom.
I made my life better again. :D
pram208.thumb.jpg.89ed69eb8eb2b3d67dd00e1db560d1d4.jpgpram209.thumb.jpg.f05f774bd8cca985ba112fe86ccae01a.jpg
Bottom planks.
It is a bit tricky to make rabbets and gains.
I didn't want to order an expensive Veritas plow plane, so I modified my Veritas block plane. ;)
pram102.jpg.f8beb46bf975b56d16a7c394d9089a1b.jpgpram101.jpg.0c2f71b29f1ae54d1ca07e603a6a2d65.jpg
Planking is done.
Skeg and bilge keels.
Finally, I removed the building board.
I'll print the enlarged plans tomorrow. 😴
I bought the Veritas miniature plow plane, but it wasn't as useful as the miniature block plane. It was too small to keep the track straight.
I confirmed every plan in the instructions is in the wrong scale. It is good to download and print the original instruction PDF files from Model-Expo.
pram430.jpg.2bd9730e8b9f7504e55888a81389cc0c.jpgpram431.jpg.ed6be4c610e7199f54a21fd9c88a2af2.jpgpram433.jpg.ac1cf7bc334e489fa8565b50a34b0fbf.jpgpram432.jpg.e22b393f2104411a3028f3764935b2d5.jpg
Edited by modeller_masa
Modeller. You have done amazing work! I’m just finishing the Pram. But seeing yours makes me want to build it again. Thank you for sharing your skills and talents. I’m excited to learn more on the smack.
