Still struggling a bit with planking, I decided to take on the Nautical Research Guild's 18th-Century Merchantman Half-Hull Planking Kit  (aka half hull planking project or the half hull) before continuing with the rest of the boats in the Model Shipways Shipwright Series. It has a long tutorial book and several builds to follow, including one by the developers of the kit:
Some Lessons Learned (Post-mortem):
I added this note after (nearly) completing the model - I wanted to point out issues folks taking this model on might want to make note of:
1) Definitely don't rely on the instructions alone. They're generally well-written. The illustrations are not the clearest. So check out a lot of build logs with nice photos. Bookmark a few. The one by @JacquesCousteau is nice. As is the one by the developer of the kit (linked above).
2) Pay close attention to the stern end of the model. You really want to check out successful build logs to see what it should look like and how the planks should lay. There really is a lot of fairing that needs to be done and careful attention to the transom and counter.
3) Don't be afraid to make the rabbets and mortices a bit deeper so that the planks can really hug in there.
4) What might be easily missed in the instructions is that the counter (at the stern) actually needs to be shaped. It has a curve in it.
5) The instructions suggest maybe waiting to add the transom and counter because they might get knocked off when fairing. I followed that advice and then realized that I had faired the last few ribs too low and had to add wood back and reshape. If anything, I suggest adding the transom (gluing it in place) and shaping the counter so it's ready to fit in (but not gluing it in place until after you fair). Having the transom in place lets you check the fairing. Leaving the count off lets you really get into the stern end where a lot of work is needed.
6) Also check on where the counter will fit in and mark its location on the last piece of the skeleton. That'll let you know if you're fairing too much.
7) Make sure you check, re-check, and re-re-check the fairing on the bow end. I ended up having too much of an elbow and lost some of the smooth flow that should be there. Get some really flexible buttons that will let you really check how blanks might lay (basswood is too brittle to use as a batton - if you bend it without wetting it, it will break).
8) Basswood is really soft. If you get an indentation, you can often wet the wood down and it'll spring back to shape after it dries. It's also easy to bend. I never had to pull out my heated plank bender. Just needed a little water. You definitely don't want to glue wet wood, so let it dry first. However, being soft and thin also means that it's easy - as I did - to sand through the planks right to the ribs - which I did.
Edited by palmerit
Looking forward to following along with this build!
Looking forward to your progress.
In progress
Lady Eleanor by JIm M - Vanguard Models - 1:64
On hold
Norwegian Sailing Pram - Model Shipways
18th Century Merchant half hull planking - NRG
On the shelf
Muscongus Bay Lobster Smack - Model Shipways
Peterborough Canoe  - Midwest Products/Model Shipways
Batelina - MarisStella
Junco China - Disarmodel
Completed
Model Shipways Lowell Grand Banks
Grand Bank Dory - Midwest Products/Model Shipways
I see that the lines do not fully match on the keelsom. I had the same issue this looks really good.
In progress
On hold
On the shelf
Completed
I see the same issue on Toni's log.
She doesn't mention it.  I think you should be able to just forge ahead without doing any trimming,  without affecting the final outcome.
But of course that is up to you.
Looking ahead in her log, I still see a small deviation there at 4.  So I think you will be good.
Edited by Gregory
― Jimmy Buffett
Slow crawl:    Rattlesnake
@Gregory I had to sand mine down a bit on both the keelsom and fore keelsom to get it to fit, and line up mostly to the lines.
In progress
On hold
On the shelf
Completed
10 hours ago, palmerit said:
They don’t line up now
I had the same issue (as have a lot of people) and found that lining up the fore two slots by trimming the aft end still left the aftmost slot slightly off, which I corrected when I deepened the slots.
I’m on the rabbet/mortice step along the keel and stem.
So it took me reading the instructions a couple of times and reading through a half dozen builds to get to a point where I think I understand what’s going on. I’m sure I could have just followed the instructions and parroted other builds but I wanted to understand why I was doing these steps. Once you get it, it makes sense. It’s getting it that takes a minute, at least it did for me.
I was thrown by the instructions that opened with “the rabbet is nothing more than a 90 degree groove cut into the keel/stern”. I thought 90 degrees relative to what?
It wasn’t until seeing later photos in the instructions and in build logs that I realized the 90 degrees refers to the edge of the plank that will be laying inside the rabbet. The planks have 90 degree edges, so the rabbet needs to accept those 90 degree edges no matter how the plank enters that rabbet.
I took some photos before cutting the rabbet and I’m using a leftover piece of pear wood plank from my Sherbourne (since the hull comes with sheets you need to cut rather than planks).
The first photo shows that because of the fat bow on this model, the plank will essentially go into the sternpost at a 90 degree angle. That’s why the rabbet there is referred to as a mortise. It’ll be a notch the width of the plank.
The second shows that along the keel, the bottommost plank (the garbourd) will intersect with the keel at a 45 degree angle (hence cutting a rabbet on the keel and keelson at a 45 degree angle.
The third shows that the planks will run up against the sternpost flush, at a 0 degree angle. Later on the instructions, part of the deadwood will be sanded down so that the planks when installed are flush with the sternpost.
It seems pretty simple once you get it, assuming I correctly understand what I’m aiming to do and why.
Edited by palmerit
On the keel and keelson, I drew a straight line the width of the planking material (around .035” on my caliper). I tried using the compass I have, but mine wouldn’t get that narrow, so instead I marked the measurements from the calipers and drew a line between the marked points.
I ended up drawing the line the same width on the inside edge to help keep the 45 degree angle. I’m going to make the rabbet a bit shallower than needed so that the resulting rabbet will accept the plank flush (with two sides of .035”, the hypotenuse - where the plank will hit flush - will be more like .049”).
Edited by palmerit
i am at the same spot and i just marked everything out and have given it a couple of days to reflect before making the cuts. i am still having a challenge in visualizing the rabbet at the stem. more so the start of the mortise and the end
In progress
On hold
On the shelf
Completed
I know by waterline 4, it’s just a mortise and only on the stem (the stemson is untouched). p. 8 says “above waterline 4, the entire rabbet will be on the stem side”, to accept a plank at 90 degrees.
p. 9 says “the stemson side of the rabbet finally disappears just above waterline 3, the third line from the bottom”.
and p. 11 has “at the third green line (at the point where no more wood was removed from the stemson), the rabbet will resemble a mortise or step rather than a V-shape”
It’s pretty clear where the transition ends (right above the third green line). I’m not quite sure where the transition starts on the fore keelson to the stepson. I’ll need to reread and check some builds.
Ohh I missed the page 11 comment. Thank you.
In progress
On hold
On the shelf
Completed
Not to get too far ahead of myself ...
Tree nails can be done on hulls as well as decks right? Has anyone done an NRG half hull with tree nails? The scale would seem to be okay for that. I don't do it if the hull ends up trash (i.e., just a learning experience) but if it's something I'd feel good about staining and framing I might consider adding tree nails too. I don't know if there's anything about the basswood used on the half hull that would make that a bad idea (or fine idea).
I sanded out the rabbet on the keel and keelson. Glad I made the marks on the inside as well as the outside to try to keep the 45 degree angle since it’s tough to see through the sawdust. Also thankful for having purchased an optivisor.
Despite have marked the point after which I wasn’t supposed to continue the 45 degree rabbet (below the deadwood), it wasn’t clearly marked enough (and despite the fact I read how others made the exact same mistake). Thankfully, while that part of the keel isn’t a 45 degree rabbet, it is a 90 mortise.
I think I’m going to have to do some repair work. I don’t think the mortise is supposed to go past the start of the sternpost (and I got to that because I continued the rabbet too far). I’ll check the instructions, but if I’m right I’ll try filling in with sawdust and glue and sanding to fill that part in.
Edited by palmerit
