Very meticulous, Glenn and the results speak for themselves sir.
Many thanks Mark, much appreciated.
Glenn (UK)
Work is progressing slow and steady on adding the second planking. I have now completed the planking on the right-hand side down to where the water line terminates at bow and stern. I have also added the garboard along the keel, comprising 2 x 4mm planks.
001.thumb.JPG.bdef211c17007fc84b4c627e22ac4f0d.JPG002.thumb.JPG.bf0afc389e73aabf76e0ed1444ba00ce.JPG
I have continued to use shorter plank lengths (max approx 140mm). In the photo below the red arrows shows the position of the different plank joints, noting the pattern does repeat with every third strake. When fitting a plank I do mark the position of the next plank, as indicated by the blue arrow.
The bow planking is looking reasonably Ok at the moment. I am colour matching the planks as I go along. The lateral bend is really helping and there is no real evidence of clinkering which is a first for me.
In the photo below the CA glue stain will be hidden by the wale, when fitted. The blue arrow indicates where the plank width is tapered to 3mm and will taper to 2mm at the stem post.
The final two photos shows the stern area. Once the plank ends have been sanded flush with the stern counter I am planning to add a square tuck finish.
006.thumb.JPG.dc24eac6f8b08ab4f2be4ba441a006b0.JPG007.thumb.JPG.c04f128abbc7be84896a25eacbfb34c4.JPG
There is still a few days work left to complete the right-hand side before moving on repeat for the left-hand side.
Glenn (UK)
I have now completed the right-hand side second planking. There is a wet nature in the photos below as I did brush the hull with a dampened brush. This was done to remove any unwanted dust from the hull and to also highlight any areas which may require a little bit of attention.
Overall I am very satisfied with how this has turned out, it is not perfect but generally it looks good to the naked eye. I will now spend a few more days repeating the process for the left-hand side. Fingers crossed I can repeat what I have done already.
The wale (when fitted) will positioned between the lower laser etched line on the bulwark pattern and the third strake.
I am planning to add a square tuck to the stern.
001.thumb.JPG.6f3ab7b38d6603d4232a7057474d34e3.JPG002.thumb.JPG.2e17fcd64db69e09bd674ec72ddc94e3.JPG003.thumb.JPG.32ae6bebcba9a6b95b92bd99ffbd408a.JPG004.thumb.JPG.f2844841d73f33e4b288719193dd5b91.JPG005.thumb.JPG.9786cb92c40b7621d4fb312624111237.JPG
Glenn (UK)
I think you have done a fine job there, Glenn. Forgive my ignorance (I am a newbie to model ship building and have scant knowledge of the vernacular), but isn't a square tuck usually placed to strengthen the stern to support cannons and the like at the aft end of the ship?
The square tuck arrangement is for framing so there are no open ends where the planking terminates at the stern.
Glenn (UK)
Aha, got it. Thank you, sir.
Planking on the left hand side has started and so far it is looking good. The first 6 strakes that sit beneath the wale have been added. I have added some marks to aid with the the plank tapering around the bow. In the first photo the blue arrow is where the planks are tapered to 3mmW and the red arrow indicate where the planks are tapered to 3.5mmW. The end of the plank which fits in the stem post is tapered to 2mmW. The final photo shows the planking terminating at the stern.
001.thumb.JPG.62765f812f4aa121e8513ecb39d75070.JPG002.thumb.JPG.e8c6c62890be9c5b897679d1b1cd8c7e.JPG003.thumb.JPG.a2155d41bd87bdb5f39726f6785f8dc5.JPG
The following set of photos, shows, in detail, the complete process I follow to fit a strake.
Step 1 - Stem Post
After making an initial angled cut the plank is placed in the rabbet and a pencil line is added so an accurate shape can be made. The plank is then removed and cut along the pencil line.
Step 2- Marking the taper points
With the plank held in place the 3mmW and 3.5mmW positions are marked on the plank. A 2mmW mark is also added to the stem post end and a mark for the end point for the taper is also added. Using the vernier caliper the taper points are then marked so a line can be drawn between all the marked points. Once the taper has been cut the plank width is checked using vernier calipers.
005.thumb.JPG.5b7c9dcbdf55ab70b65e0833bdb9cce2.JPG006.thumb.JPG.9c016ad04c328169f9c17d85a9f117f8.JPG007.thumb.JPG.dd36c847bb9cad9b22b40aaf3f823e32.JPG008.thumb.JPG.0059ec7721edebff85562e2c83798939.JPG
Step 3 - Adding a lateral bend
After the plank has been dipped in some water it is clamped so a lateral bend can be added. I used a hairdryer for approx. 1 minute to apply heat to the plank.
The laterally bent plank is then test fitted, and as can be seen below, the plank is not a perfect fit. When this is the case the plank is then wetted again and the lateral bend is adjusted.
It fits much better the second time around and also, as can be seen in the final photo below, the plank does followed the 3.5mmW and 3mmW marks. 009.thumb.JPG.bd16e26d9382a81c1216e85eb57a8ba3.JPG010.thumb.JPG.ec863fa7085556c949132a06f16a1884.JPG011.thumb.JPG.2d586fdad7e6b191c7be46451d949301.JPG012.thumb.JPG.8d68d2a6dc773a90fff2fe526d811819.JPG
Step 4 - Fitting the Plank
As I am fitting planks of approx.140mmL the position for the cut is made on the plank. The cut line repeats for every third strake.
I used my guillotine to make the cut, and the reverse side of the cut plank is marked to ensure I can line up the cut edges when fitting the next plank.
I apply a bevel to the top edge of the plank as this helps to keep the plank tight to the upper plank.
I do have a couple of bowls on hand, one has clean water and one has some acetone to remove any excess ca glue.
Ca glue is then added to the hull and the dampened plank is then added.
013.thumb.JPG.e3e359df8065fc4472a7ce93883b86d3.JPG014.thumb.JPG.5275d204650ae5616148def1651bb472.JPG015.thumb.JPG.2ebb45083520cb94164ae9c57b3f2978.JPG016.thumb.JPG.8c78c97b35fc5fa3294dc9aa1b595d11.JPG017.thumb.JPG.6c2af0b59f809206189f002a20f760a6.JPG018.thumb.JPG.5ad2deeb732ea6fca292b4f20156f12e.JPG019.thumb.JPG.dfd63b40c591f7c9d1f09dcb4309f45b.JPG
Step 5 - Adding the remaining planks
The next cut position is marked on the plank. Once the plank has been cut a bevel is added to both the top edge and also to the end which butts up to the previous plank.
The dampened plank is then glued in place and any excess ca glue is wiped away. The process is then repeated for the final two planks.
The final plank is then trimmed close to the lower stern counter pattern.
020.JPG.c142ad39b33e5ba473d9c515255341d2.JPG021.thumb.JPG.a02a1ad0f91fabe881fe48df8487586d.JPG022.thumb.JPG.a7c3b3b05357229a3d9b4acec780b873.JPG023.thumb.JPG.92391fd2955d2158550ec8c855d11a7d.JPG024.thumb.JPG.adbab2893baf9d44acd4b3f0d709176f.JPG
It might seem a long winded process but it works well for me and is producing much better results. And it is not as time consuming as you might imagine once you get going.
Edited by Glenn-UK
Glenn (UK)
That is a good, steady process, Glenn and it certainly works well judging by the look of that hull. Thumbs up from me sir!
I have now completed the second planking on the left-hand side. As with the right-hand side I fitted planks of approx 140mmL. I also applied a lateral bend for the planks that were installed around the bow section.
For the most part I am really pleased with how the second planking has turned out.
The hull will now require sanding to iron out any bumps before I add the wales and copper tiles.
001.thumb.JPG.806040097410b22f043c8b0d0dd08c16.JPG002.thumb.JPG.476f484e7f4725dc4bdbcfdd117743bd.JPG003.thumb.JPG.7870ed1e7c6ab839c502525446a590e0.JPG004.thumb.JPG.7690a3ae27c9558e3768f5a32abc7289.JPG007.thumb.JPG.bab20043df3d0f9fdcde2bf680f2accd.JPG008.thumb.JPG.b9774cf944b052be08b72212051365fd.JPG
In the final photo I am starting test fitting the parts I have made for adding the square tuck. There is a little bit more work required before they can be fitted. I also have to made the top right-hand square tuck frame part.
Edited by Glenn-UK
Glenn (UK)
Thank for sharing all the detailed steps.   This is really helpful to us that are still trying to figure out proper planking.
Hi Ross
Thanks for the comment.
I am still trying to figure out proper planking also.
Cheers
Glenn
Glenn (UK)
You made me smile with that statement, Glenn. It is true for me too mate :)
Hello Mark
Planking is one of the dark arts and I am making progress in making a better job of it. The light bulb moment for me was when I finally understood the lateral bending method and the benefit adding twists to planks for the garboard.
Cheers
Glenn
Glenn (UK)
Yep, I would imagine doing that really helps the planks to sit nice and neatly. It is something you just have to take your time with, isn't it. It was worth the effort, Glenn, she is looking fine.
39 minutes ago, Blue Ensign said:
Coming along nicely Glenn,  well done.👍
B.E.
Many thanks Maurice. Not working in the shipyard day 😫 due to grandparent duties.😁
Glenn (UK)
The Square Tuck
Following on from @Blue Ensign lead I decided to fabricate a square tuck to finish off the second planking. Previously I had used the lower stern pattern, before it was fitted, as a template to shape the lower framing pieces for this task. The square tuck frame pieces were cut from some spare 0.8mm pear wood.
After a little bit of tiding up work the lower curved framing pieces were glued in place. The bottom edges were then sanded flat with the second planking, where necessary. The top edge framing pieces were then glued in place.
The next task was to add an infill to the framed area. I initially make an card infill template and planked on top of that. I ended up abandoning this approach as the planked assembly did not hold together when I tried to trim the excess material from the planks to the get the required shape.
In the end I simply added strips of 4mm planking material, using the template as a guide for the bottom edge shaping. This was easy to do and did not take long to complete.
The final task was to sand completed square tuck area so that the planks were flush with the frames.
It has been an interesting little side project and one which I am glad to have undertaken as I am really pleased with the end result.
The square tuck area is still slightly damp from the cleaning process in the two photos below.
001.thumb.JPG.53537e7459f4b528e1dc876b906eaeb9.JPG002.thumb.JPG.4bb0e58b1a03af09a7c2bc5528104ec9.JPG
Edited by Glenn-UK
Glenn (UK)
As you should be, Glenn. It looks very neat and tidy sir.
Hello Mark
Many thanks for the kind comment. It nice when you enhance a kit and the end result justifies the extra work.
Glenn (UK)
I have experimented with some different wood dyes and ended up adding a cherry wood finish to the square tuck. There is still a little bit of tiding up work required in this area.
I then moved on to adding the wales. I marked and taped the position of the waterline. I also added tape to the area above the wale. Once that was done I sanded the area smooth between the upper and lower tapes. The previously bent wales were then checked and I did end up adjusting the bend for a better fit around the bow area.
I have also been experimenting with both oak and cherry wood dyes on some spare planking material and will add a cherry wood finish to the planked area below the wales and above the waterline.
The wales were then coated with a sanding sealer and two coats of dull black painted were brushed on.
Next I brushed some wood glue to both the underside of the right-hand side wale and the hull. The wale was  then carefully aligned and clamped in place and were left to dry. Once the glue had had time to cure the process was repeated for the left-hand side wale.
You may note in the photos below I did add one pin to the lower wale section at the stern so it follows the curve of the hull. I will remove the pins first thing in the morning.
The upper tape layer has also been removed now the wales have been fitted.
002.thumb.JPG.c8e9a72b1063446ba4d984e06840454f.JPG003.thumb.JPG.0416a41003eb66c9ea681a2465768ab1.JPG004.thumb.JPG.a6b484df058525bbd8355f8a6e005f0f.JPG005.thumb.JPG.98a83c101adf032064118467fbe56a68.JPG006.thumb.JPG.83e9f704f39e20aa3e256dc62dc18f27.JPG007.thumb.JPG.673a925e9dc006bbd7f74adcfffe5b56.JPG
Edited by Glenn-UK
Glenn (UK)
The top outer rail has now been added. Before fitting I brushed on some sanding sealer and then painted the rails dull black.
I decided to apply some cherry wood dye to planked area between the waterline and wale. It might not be to everyone's taste but I am pleased with the end result.
Next I applied a WOP coat to the hull.
After checking the position of the waterline I added tape so the hull is now ready for coppering.
001.thumb.JPG.f48098a52fefbeccc8259ab3237c9835.JPG002.thumb.JPG.7abe2e821bf90e7f139b412f6a3b1e36.JPG003.thumb.JPG.29644eca7caa8efbbc296d942421739c.JPG
After removing the bulkhead ears the laser etch deck was test fitted and seems to be a perfect fit without any need to make any adjustments. I still need test fit some of the deck items such as the masts and bitts to ensure there are no issues before the deck is glued in place.
004.thumb.JPG.171d3345c78456b6e0ef3e3a436a65af.JPG005.thumb.JPG.b527e05775323d020138ed618c5dfb7e.JPG006.thumb.JPG.6a772571cdc65c1549ec8ad467b822f7.JPG007.thumb.JPG.5daa4df22eef6c5d504d2e179d3a3c41.JPG
The rear inner bulwarks patterns were test fitted without any issues. I used some pins, placed in the gun port eyebolt holes, to help with the alignment of the rear patterns.
009.thumb.JPG.488bbc2379bdc390443db94ca009c9b2.JPG008.thumb.JPG.3644266a55137384497bc44fedb90459.JPG
The front patterns need to be bent to follow the curve of the bow.
After soaking the front inner bulwarks patterns in warm water for a few minutes they were clamped in place and will now be left overnight to fully dry out.
Next I moved on to test fitting the inner stern counter and board patterns. The upper pattern required a little bit of tweaking and then split along one of the laser etched lines as I was sanding. I was able to add some glue to rectify the problem.
With both parts in place they do not look great. The top part is not a problem as it lines up perfectly with the two openings. I will need to spend some time working out a solution to get the lower pattern to line up with both the deck and the upper pattern.
In the photo below the top pattern is not correctly aligned but the join between the two patterns looks better.
My next task (in the morning) will be to test fit all the rear cabin outer patterns.
Glenn (UK)
And I say once again, dry fitting can prevent so much added frustration and headache further down the line. Thumbs up from me, Glenn.
Totally agree.
Glenn (UK)
Much to ponder on the way forward after a morning of test fitting various parts.
I did a check that some of the upper deck items will align with the lower deck openings. I am pleased to report that no issues were found.
I then turned my attention to the inner stern board and counter pattern. After a little bit of trimming of the lower pattern I was happy with how the join between the two patterns looks. However there is an issue with where the lower pattern joins with the deck, as can be seen in the photo below.
I am undecided what to do but my current thinking is either:
a) to see if I can add some material to the bottom of the stern board pattern so there is no gapping with the deck edge. I will also need to add some packing to bring the stern board up to the same level as the back end of the deck. This will be time consuming and I may end up creating some more problems.
b) Leave as is and then fit a filler piece to cover the gap, as per the photo below, noting the filler piece will need be full length rather than the short experimental test piece shown below.
c) Add some packing to bring the stern board up to the same level as the back end of the deck and then add a filler piece.
I am currently drawn toward option c).
However there is bigger problem to resolve before I can fit stern board and counter patterns. In the photo below I am test fitting one of the rear cabins side patterns. It can be seen that the pattern does not sit flush of the deck. This can be rectified by removing some of the patterns curved section so it follows the shape of the lower stern board pattern.
Also the pattern is not square where the cabin door pattern will be located.
The cabin door assemblies are a good fit.
The outer cabin frames were then glued to the cabin side and door panels.
Another aspect to consider is the fitting of the cabin roofs. As can be seen below the cabin side panels need to be level with the cabin frames,
When looking at both the cabin side panels and the stern board and counter patterns I am happy that there are no issues with regard to how cabin side panels will fit against the stern counter pattern, as can be seen by the red arrow. The problem area is indicated by the yellow arrow.
However as this is not the case with the stern board pattern. My options are:
a) Fit both the stern counter and board patterns and then, when fitting the cabin side panels, trim the bottom edges as necessary to get a good fit.
b) Resolve the alignment issue of the cabin side panel before fitting the stern counter and board patterns. The curved edge of the cabin side panel can be trimmed so it sits flush on top of the stern board pattern.
c) Sort out the basic alignment issues as per option a) above. Once the stern board and stern counter patterns have been fitted trim the curved edge of the cabin side panel so it sits flush on top of the stern board pattern.
Unless anyone has any bright ideas my current thinking is to go with option c).
Glenn (UK)
Take heart. I had to sand down quite a bit . There is a small gap but not easily seen unless you look real close. The sides of the cabin needed quite a bit of sanding to fit. Initially looked a lot like yours. See below at the lines of the edges, so I chose option C
IMG_9808.thumb.jpeg.eed415c11870798dcbab8a9752d45b66.jpegIMG_9809.thumb.jpeg.e8a6a9b3a96e0728c5448d63d73f1699.jpegIMG_9810.thumb.jpeg.241af81b5521302ca653dbb7931b8209.jpegIMG_9811.thumb.jpeg.2ec982f80aa9db2997f00edd3ff8dfdc.jpeg
Many thanks. I have done a bit more work. I have made a test cabin side piece which I am using to work out the required adjustments. It is still WIP at the moment.
Glenn (UK)
Smart move there, Glenn.
