More progress on the copper plating task.
I just have to add the infill plates up to the waterline on the first side, as can be seen in the photos attached below. Once that is done I will repeat the plating process (and hopefully I will make a slightly better job) on the other side of the hull.
I am using cotton buds, dipped in acetone, to clean the copper plates once they are been positioned. Thankfully there is no sign of any ca glue of the plates that have been fitted so far.
001.thumb.JPG.8612e41f72a9c7eab29624a4f8a1fe54.JPG002.thumb.JPG.6a7843ce60cf8b57a13e29e89570ed32.JPG003.thumb.JPG.cf9d68cbd3eb25ca90305e19301951e7.JPG004.thumb.JPG.a04608e45fcd48f81a27c2aeb0a99622.JPG
Glenn (UK)
Today I completed the copper plating on one side of the hull. I will add a 1mm square batten along the top of the cooper plates to neaten of the edges.
I did a test fit of the rudder assembly. I will need to trim the rudder copper plate sheet to match the hull lines.
The following is an insight in to how I went about fitting the copper plates along the water line.
A copper plate is offered up to the hull and the pencil mark is made where it meets the waterline.
Next I draw a line between the pencil marks.
The copper plate is then cut to size, using my guillotine.
The next copper plate is marked up and test fitted against its adjacent copper plate.
When I am happy with how they look they are glued in place.
Glenn (UK)
It's always good to have a system in place, Glenn, it makes for a smother workflow. You did a nice job on the coppering, it looks very neat.
Thanks Mark
Glenn (UK)
Copper plating the other side of the hull continues, I have made reasonably good progress today and feel the end is in sight in the next few days. I will be adding a 1mm square batten to neaten up the copper plating along the waterline.
For the most part I have made a better job of this side of the hull.
I will need to redo the copper plates fitted up to the waterline, as can be seen in the photo below.
The copper plates will be buffed cleaned.
I will need to revisit on small area, as indicated by the yellow arrow as for some unknown reason I had a senior moment. I also need to replace the upper most right hand copper plate .
Glenn (UK)
I guess that proves that practice does make perfect, Glenn :)
Copper plating the second side of the Harpy has been progressing well, in between my wife's post operative hospital visits, and I reached a stage where there was only 1 or 2 more days work left to complete, as can be seen below.
However I have hit major a problem in that the copper plates, when glued in place are simply not adhering to the hull. I have tried a few different things to try to overcome this problem without any luck. The problem is definitely with the surface of the bow section of the hull which is not allowing the ca glue to react, adhere and cure. Clearly I need to resolve this issue but I have no idea what to do for the best as I have already tried several things, such as:
a) adding a new WOP coat.
b) adding a paint layer
c) sanding
d) brushing water on hull
As can be seen below I have had several failed attempts at adding more copper plates to the hull.
Unless I can find a solution I feel I might have to resort to painting the lower section of the hull. This will mean I will have to remove all the copper plates. At the moment I feel this will be lesser of the two evils.
Glenn (UK)
I painted the hull copper before plating. The plates stuck pretty well with the cyano after.
Thanks. I have tried painting and WOP. This morning I have cleaned the area and applied a new WOP coat and have been able to add a few more copper plates, but some still refuse to stick.🤨
Glenn (UK)
I did what ECK did, only a think layer of copper paint, no varnish or wop. And the plates stick super well, so well that I have to use ca gel or they stick too fast.
More importantly, wishing you and your wife the very best!
Walter.
Current build: HMS Ariadne 1776
Finished build: HMS Flirt
Yes, I was going to make a similar suggestion, Glenn, wipe the backs with an alcohol solvent. I wouldn't put WOP on there either, but that is just my preference, not based on any experience.
55 minutes ago, Blue Ensign said:
The only thing I did  perhaps differently to you Glenn was to clean the back of the plates set with fine wire wool and wipe over with isopropanol.
I can't understand other than that why they are not sticking.🤔
B.E.
Hello Maurice
I did clean the back of the plates. I am bemused.
Cheers
Glenn
Glenn (UK)
Hello, would trying a different glue make any difference?  I was told to use Super Phatic glue for the copper on my Pegasus. It seem to work really well for me..
Bob  M.       :cheers:
On the build table :
Pegasus  -Amati-1:64
On hold:
Astrolabe 1812 - Manuta-1:50
Bob  M.       :cheers:
Hello Bob. I have tried two types of ca, the issue seems to be the hull as the copper plates do adhere to other surfaces.
Glenn (UK)
After another day of copper plates not adhering to the hull I finally took the decision to remove all the copper plates. With the exception of a few copper plates they fell off with a quick flick of a craft knife blade and only took approx. 15 minutes to complete.
A big pile of used copper plates.
I probably have enough spare copper plates to redo however as I have not got to the root of the problem I have decided to paint the hull.
After sanding the hull to remove all traces of any excess ca glue I brushed on some white paint which highlighted a few areas which need some attention. I brushed on some brushed diluted water filler where necessary, as can be seen in the next photo.
In the final photo the hull has been sanded smooth and I am happy with how it looks so I can now tape up the hull and start painting. My current thinking is I will use red oxide below the waterline then to have a thin black band for the waterline and to paint the section between the waterline and wales either yellow ochre or white.
Glenn (UK)
A big decision Glenn , and well done. I may be making a similar decision myself soon.
Richard
Current builds:
Completed builds:
SBLim-2A, MiG 15 variant, WAK card
Harpy by Vanguard
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
It was a shame as I was so close finishing the plating. But I was wasting days of effort and getting nowhere so felt it was the right call for me.
Glenn (UK)
You can also paint the below the waterline white as many of the other Vanguard models, pre-copper so to speak.
I did think about a white lower section but I also quite like the look of red oxide which I used on of the small Vanguard fishing boats. My other option is to spray paint it copper as I did with the Indy.
Glenn (UK)
Good call, Glenn. It wasn't worth pounding through a frustrating situation like that where there was no solution in sight.
After many trials and tribulations I have finally ended up with a simulated coppered hull.
After cleaning and sanding the hull after my failed copper plating attempt I painted the hull below the wales white. Next I painted the area between the wale and waterline yellow ochre.
Remembering I had made a copper plating template I printed out the template on to some stiff card, and then noted that Richard did something similar with his Harpy build.
Next I cut the template into strips which where then glued to the hull using Titebond wood glue.
I then sprayed the hull with some copper paint. Whilst it is not a perfect solution it does give an impression of copper plated hull.
003.thumb.JPG.4094ab8f4c24fac4e87df027edd9ea18.JPG004.thumb.JPG.94cfbee6771cbad3e752f4c82e25dcaa.JPG
With all the masking tape removed the hull does not look too bad and is OK for my needs. I still need to attend to painting the stem post, which I will probably use black paint.
005.thumb.JPG.49c994af92090dfa850a32f36d72aacb.JPG006.thumb.JPG.27a3697cfde42a392ee06f8ab4c49d6c.JPG
Glenn (UK)
It is looking good , did we ever find out why the copper did not stick?
Bob M.     :cheers:
Pegasus  -Amati-1:64
On hold:
Bob M.     :cheers:
Hello Bob
It remains a mystery.
Glenn (UK)
But you came up with a decent solution, Glenn. Nice save :)
Nicely done Glenn.
Richard
Richard
Current builds:
Completed builds:
Harpy by Vanguard
The failure of the copper plating task did knock my confidence and dented my enthusiasm with this hobby. That said I have now moved on to tasks which I tend to enjoy so my enthusiasm is returning.
The first task I undertook was to add the belaying pin racks and carronade eyebolts.
001.thumb.JPG.684b8f5d0ab6825f203b04cf9489a116.JPG002.thumb.JPG.d090f37ef35692bd0181769f0a950372.JPG003.thumb.JPG.85678737426d3345d8f9d0967d9e26bf.JPG
The next task was to add the outer transom pattern which was clamped in place.
Once the clamps were removed the transom looked Ok but there were a couple of areas which required so further attention, as can be seen in the photo below (yellow arrows)
The top area weas sanded smooth and then some wood filler was added along the lower edge. Once the wood filler was then painted black.
006.thumb.JPG.0299156401388c4d4c278597889a6cdf.JPG007.thumb.JPG.73034c79bebc3f74e44770340a0c6ae4.JPG
The stem post was then painted black above the waterline.
The bowsprit bitt assembly was painted flat red.
The leading gunwale parts and catheads were painted black.
I forgot to add the cleats to the catheads when they were assembled.
Finally the leading gunwales and catheads were added to the hull. The bowsprit bitt and bowsprit dowel were dry fitted in the following photos.
012.thumb.JPG.b24f26a7e979d8ae99f9091b17aeb51b.JPG013.thumb.JPG.d7fac53e5711817d00306cac3eee3fc2.JPG
Glenn (UK)
I know exactly what you mean, Glenn. On my Endeavour build I had fully finished the hull, painted and varnished it and was very happy with the result. While I was drilling the holes for the stanchions at the stern of the boat I slipped with the tiny drill bit and went through too far. When I saw the drill bit sticking out through the underside of my nice shiny hull (and the hole that got made when a piece of wood got punched out by the drill bit), I nearly lost it. I had to just take a very deep breath and tackle the issue otherwise I would have thrown the drill against the wall, or something worse.......... Like you mentioned, getting on with something enjoyable and uplifting is the way to go. Your build looks good mate.
