Just starting my first wooden boat, AL King of the Mississippi. The good news is that everything came out straight and centered. The bad news is that there is a small gap between the edge of the planks and the edge of the frame on both sides. It's really small to try and adhere another plank to, but would that be your suggestion? I thought about getting the sides down and then adding another plank to the bottom so that there would be some more width. Thanks for any thoughts!
I'd sand it down to get everything smooth.  Same the sanding dust.   Then brush a 50-50 mix of white glue and water and brush into the gap.doing one "line" at a time.  Then take and spread the sanding dust into the cracks.   Let dry.  While it's drying, go to the next gap and do the same.  When all are done, sand the entire deck.
Are you asking about the gaps between planks (as I believe Mark thought you were) or asking about the small gap at the edge of the subdeck?  For the latter, is there any wider strip wood in the kit that could be used to make the edge planks just a little wider than the others in order to fully cover the subdeck?
Or if you look ahead in the instructions, is the exact width of that subdeck critical?   Maybe you could just shave off that little bit of extra subdeck to meet the planking.  But, I am not familiar with the kit and do not know which deck on the boat this is, so that might cause big problems down the line if that deck must be the exact width of the provided subdeck.
Thanks Mark and Gary. My concern is with the small gap at the edge of the subdeck. I zoomed in on the instructions and they actually put a thin sliver of planking at the edges. I'll give it a try, hopefully without breaking many pieces of wood in the process. When all done, I'll sand and use Mark's method to fill gaps between planks.
You might not want to fill the gaps between the planks if you want the individual wooden planks to be visible on the model - they would be on the full sized vessel.
However, Mark's suggestion is a very useful way to fill gaps that you don't want to see, especially where the parts will be painted.
Phil
Current build: USS Cape MSI-2
Is what we are looking at the underside pf the hull or the main deck?  Either way, I would sand the frame to the planking and plan the sides accordingly.  If underside of hull, the sides could be slightly tapered inward.  Ditto deck...It appears too small to notice.
I build the steamer FAR WEST a few (hundred) years ago.  I don't recall any waterways on a riverboat.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
8 minutes ago, WGibson said:
This is the underside of the hull.
So it's a flat bottom hull.   Hmm....  will anyone besides you ever see it?   What I offered is truthfully described by the other as to issues.   However, if you're painting it oar not, don't sweat it one way or the other as to fill or not fill.
Riverboat hulls are really pretty basic...a flat bottom barge with alot of stuff on it.
Chuck Seiler
I belive I glued little stips on each side. Then after the sides were planked , I filled in the gaps with plastic wood then sealed it. they were small gaps so I think they turn out ok
                   WASA
                   USRC Harriet Lane
Quick update. I filled in at the bottom with a plank on each side. I think it turned out fine. As for the rest of the planking, the front of the boat was a bit of a bear. The previous version of this kit had plywood that wrapped around to form the front of the hull. This version has fully planked side, but they are single planked. That curve is pretty challenging with 2.5mm thick planks that also have to twist down.
For my first time planking a hull (previous builds have been on my model railroad), I can live with it. Much sanding and filling and more sanding to do with it and I'm confident I can get it looking fine. At this point though, I would not suggest boarding a boat that I've planked.
