I have began working on this and should be done glueing the frames together this is my third build and biggest yet. I will be making this RC and I’m setting my finish date for opening day for boating here in Seattle (May 3rd) so I have a bit of work to get done and and may have some questions along the way. I have not seen anyone post much further than just glueing the frames together so if anyone has done a similar build please show me thank you
day 1 frames glue. Don’t mind the plaid wax paper it is all I could find but it’s slightly helpful lining things up
Edited by ccoyle
corrected log title
Looking good Andrew. There are builds of Miss Adventure at “rcuniverse.com” and “ rcgroups .com” . Not sure if they are finished but they were well on the way when I looked.
Best Regards……..Paul
Was another very long day working on this one and I got it all strung and ready to be faired a bit. Another first doing stringers and soaked in alcohol to get it to bend maybe not the easiest way but it worked for the most part like ya of clamps and rubber bands. About 20 hours working on this in two days has been a lot of work but I could not be any happier
Looking good!  The frames and stringers all look very stout.   You mentioned the basswood sheets…do the instructions just have it single planked?  That would seem a little questionable for an RC boat.  The one Dumas mahogany speed boat I built long ago was double planked with balsa and mahogany.
Waiting on response from model expo because it appears the kit came with a propshaft assembly that is short by 2-3 inches no response in 4 days. I’ll mock up with a longer piece of tubing so I can get started on the exterior this weekend
Alright here goes nothing after looking around and finding a few builds I decided to put some sheeting under the planks so slight deviation from the kit so I’m a little nervous. I left some of the stringers from the wider bits long so maybe they can stick out between the darker wood to give some lines and break up the solid look without painting. Ok slow moving today had a late start went to a big boat show and got inspiration from some vintage race boats.
Edited by Andrewiscookin
Well here is what I was able to get done this weekend lots of bottom work. Added this extra detail that it didn’t call for but I thought would look great and I was not wrong. Did some research both online and in person and I am thinking it may get a bottom color covering up that detail after all that but I know it’s there and that is all that matters.
I picked up this marine spar varnish and am wondering if that is ok to use as waterproofing inside and outside or if I should return it for something else and insight on that would be helpful thanks
Things are slowing down a bit as I have never planked a bow before but I think I have it figured out starting the taper for the bend.
I have also got the propshaft and rudder tube in place. That required mocking up the motor and I was having trouble getting everything to fit properly and figured I need a different shorter coupler than it came with so I have ordered a couple different ones to see what will fit.
time for a break before I get back to it later today
Andrew, I would recommend you to use epoxy for the second hull planking. Epoxy creates a watertight seal then sand the second layer make it super smooth then apply your varnish.  Sand inbetween sessions.
That should do some of the sealing, also I would recommend to epoxy the inside of the hull. Use WestMarine 105 and 205 and silica powder.
Btw, nice progress.
Good luck.
Respectfully
The words that come to mind are using drop planks and stealers but I do not see a need for them yet in your photos above.
Take a look at post #34 at: https://modelshipworld.com/topic/37626-hms-harpy-1796-by-blue-ensign-–-vanguard-models-164-scale/page/2/#comment-1081778
You will see some quite good examples of drop planks and stealers if you should need to use them.
Have you tried steaming or soaking your plank in hot water then clamping them to dry to shape before installing permanently?
Edited by AON
Alan O'Neill
I slept on it and I feel dumb I was trying to force them to go straight ahead instead of bend in to the center but if I go this direction I’ll need to fill in the blank area that is created  if that makes any sense. Glad I didn’t glue further than I did and if I hate the way it looks I can just paint the bottom
For some reason my brain could not get this figured out easily so I tried my best and it doesn’t look super great right now but I think with some filler and sanding it will be ok. Also seeing that it isn’t perfectly symmetrical but that too won’t be too far off less than a plank width.
I am also thinking of making a metal cover for the bow (or make my jeweler wife do that for me) and it would cover up some imperfections.
It was a very frustrating weekend and I’m tired of this particular section but I won’t be giving up just yet. Thanks for the help
A few drop planks would fill that nicely.
As it will be right side up who will notice.
Alan O'Neill
Having fun today working sides and transom. I’m adding a basswood layer to waterproof it does not say to do this and to plank right on the frame so making a panel and copying it for the opposite side nothing is glued yet and I am still shaping and fitting together. The transom I’m doing a little different and filled the spaces in the frame and a single layer of the dark wood which I will be planking over
learned that I really don’t like the smell of  5 minute epoxy when I filled in gaps from the propeller shaft and rudder shaft.
started layers of varnish on the inside the other night
back to it I go
Was able to get the hull roughly in but It should fair well before I do the planking.
Once I finally got it all in place I did a little I got a boat dance I must say.
now to bust out some filler and sanding.
questioning if I should varnish the sides before glueing the planks
wonderful work this weekend
Finish all planking and sanding before any varnish, otherwise you might have issues with adhering.
Respectfully
I’ve taken a couple weekends off of building this waiting for a plank bender now. But I have spent my weekends looking at others boats in all these small shops in Paulso and then today touring the Virginia V while it is in dry dock being repaired and learned quite a bit today. Hopefully once my plank bender gets here I will get back to work daily on this project I feel bad with it just sitting there but field trips were had
Ok finally back at this as I’ve been waiting weeks as this plank bender has traveled all over the country for the last 3-4 weeks this is making planking so much easier than how I was just forcing it how I wanted (yay learning). For now I am gluing one plank at a time per side and going back and forth while soaking and shaping the planks further down the hull. The way I have been clamping the planks in place will need to change soon and I’m not quite sure how I will be doing that so I’ll get creative with rubber bands and anything that I have. So happy to be back working on it I have felt so bad just watching it sit there while occasionally catching my cat climbing on it. Also a picture of a little regatta I watched this morning from the ferry as I was waiting for the plank bender to get delivered
Andrew, are you located in Poulsbo?
Respectfully
No my wife and I went to Poulsbo for our anniversary getaway we are in Seattle but I like going around where we can look at boats. So many models all over that small town almost every single shop had one on display
