I have been building this one while doing the George  was really liking the look alot just shiny enough and the same clear same bottle the last coats lost a shade of shine.The pic on the stand is right before the last clear 🤨
21 hours ago, Javlin said:
seemed to be working till the last coats Tom don't know why?
Look's like what is happening is the air brush needle point tip is loading up. ( this reduces your volume output making a dryer coat ) This will realy hapen bad when you set the air brush to the side, waiting for flash time between coats. Take the front end apart clean it, and if your going to set the brush to the side for flash time.... spray Windex through it.  Also make sure you have the right needle in the brush, you want the one for a high volume cause your covering a large area.
On 3/23/2025 at 12:05 PM, Javlin said:
I may of used a different AB  on the first coats now you mention it that had a higher volume?
Future/Pledge also needs a wet coat brother, on everything/place your going to put it...  So plan on complete coverage and do your setup accordingly... It dries very thin so the only real complication is handling run off... (thinned wet coats tend to run) What I do is keep a pile of absorbent material next to where I'm clear coating and when the future runs enough to start collecting on the low spot, touch it to the absorbent material to wick off the excess...
You only want the droplet that forms to touch the wick, do not allow the surface to touch otherwise you will have a touch up to do...
Definitely needs a wet coat to work properly...
EG
Edited by Egilman
Quote:
