A long time of no posting and several requests has made me to start the next Harvey project build log.
This build has been going on for some time.
Many changes and alterations has been done to the original parts, this due to material not measuring to the material list dimensions.
This picture is the latest one some ten minutes old, before uploading.
From this point I will go back to the start and explain what I have done as there are several changes, this in my best way.
Have patience with me, as this kit will be kit bashed. not knowing the final physical outcome.
This picture also shows partial of the pre-bending of walnut strips. As I am intending a single layer planking.If I fail I can go to double layer.
By putting the paper clips on each bulkhead I can there-after put soaked strips through the holes and get the right bending. ;)
Some of the pictures from this build has appeared in other topics.
Respectfully
Well its about time! Nice looking laminated plans you have there! Now don't you dare get ahead of me or your visitation privileges will be revoked! :P
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Floyd, I won't even be near you when it comes to planking......
The "bubble effect" is not bubbles but a mix of glue and walnut dustpost-967-0-09192000-1386997022_thumb.jpg
Respectfully
Okay to back to the beginning
When I started this kit I didn't realize there were discriminates of dimensions material list versus real items.
This resulted with added material to bulkheads but also to the deck aligned.
This picture shows how bad it was. With the aftermath and added work I should have made new bulkheads from the beginning.post-967-0-68304400-1386997788_thumb.jpg
Bulkheads and the added material.
Sorry to have the metric measure upside down.
Part list shows the bulkheads at 6mm.
Real part is much more narrow.
Respectfully
With added material I did have some area to add glue to for the planking.
Respectfully
Respectfully
How Harvey/Harley was naked :)
The mast holes was cut out using templates from the plan. I did change the rake a little to the aft, which would have been more appropriate to the time between  1790-1830 for "this type classes of ships".
There is very little of back ground history of this ships from this time.
One book to rely to when it comes to Rigging is the book of Lennarth Peterson  - Rigging Period Ship Models
Respectfully
With the mast holes cut accordingly to plans (with little more rake) I added material to each side of the false keel, matching the shaved mast.post-967-0-18921900-1387001539_thumb.jpg
Now since that is done I added the masts with the "stays" getting the rake, just for visual purpose.
I added side blocks at the mast steps. post-967-0-24569300-1387001879_thumb.jpg
Respectfully
How would you explain that to Bear? :D
The plans are not laminated per say, but stuck in between two pieces of 4mm plexiglass.
Respectfully
I have done all the planking without any clamping.
In the book "ship modeling simplified" Frank Mastini uses a gluing method of both wood glue and CA.
The CA works like clamps and the wood glue for strength.  post-967-0-91211800-1387318876_thumb.jpg
Respectfully
When I first saw the title, I was wondering "Is he going to turn a ship into a motorcycle?".  :)  Anyway, I'm going to follow along with interest and popcorn. post-76-0-80572500-1387421200.gif
Mark, No motorcycle but named after one of my dogs.
Hope you have your own popcorn as I ran out of them. :)
Respectfully
Late night update,
The 1.5 mm single layer walnut is progressing.
I am planking in "four bulkhead sections"
The grain is beautiful so I am still not sure whether to varnish or paint the hull..
Maybe half and half, underneath waterline painted and above varnished.post-967-0-95248600-1388642265_thumb.jpg
Respectfully
As I am waiting for the last game of the Olympic Ice hockey I have been working of on my Harvey for a while..... and long before, :)  ( updates has been asked for)
Planking is complete and all is with 1.5mm walnut first layer..... and only layer.
However, I do like the finish even without any finish. There is several more steps before any painting will happen.
I tried to use minimal wood filler and where it is filled, a combo of wood-filler and dust from wood has been combined for the matching.
Additional sanding is needed but I am ready to for the next step of planking.... yeah! finally! :)post-967-0-28852800-1393153116_thumb.jpg
Respectfully
Yes I asked for updates. You keep hinting but never updating. One would think that a doctor would set a better example. :P
During a "house call at the West side of the state I also had time to work on my "Harley"
I have come to the stage of "decking" as in the picture the king plank is attached.
To simulate the caulking I used a borrowed graphite pen.
It's a tedious job doing the simulated caulking but progress is certainly on the way.
And yes, I am the one doing the job  .... :)
Respectfully
Oh, forgot the thing about length of deck planks.
Since the kit is 1:50, and guessing a normal "real" plank may run in the length of 6 meters (about 6 yards) I cut the planks to 12cm.
The kit plans shows a plank length of 7cm which should be 3.5m (about 3.5 yards)
Seemed to make some sense to me. :)
Edited by Nirvana
Respectfully
Decking is completed now some trim around the edges, once that is done light sanding with 340 paper.
Respectfully
Very nice job! But you didn't finish the planking on my Harvey. That was why you made the house call wasn't it?
Waterways being installed, again the material can't be bent in lateral way so I made them in sections.
Probably wrong to the time era, but has to work with material provided unless swapped
Respectfully
The waterways are of walnut .... so ******** (don't even know that word) to bend lateral way.
Respectfully
Hah, found my way around the waterways, and no doesn't involve removing them. :dancetl6:
The part to the stem is a three-piece glued walnut to be shape accordingly.post-967-0-27272200-1395969170_thumb.jpg
Respectfully
I would say I am pretty pleased with the trimmed piece. no need for lateral bending anymore.post-967-0-87045100-1396046642_thumb.jpg
Respectfully
The waterways are in place.
The material for the bulwarks in the kit is 1.5mm plywood. I didn't like how the shape turned with that. Besides it is really hard to bend and get a nice shape.
But I did have 1mm card stock, using the bulwarks as templates I cut out two exact copies.
Shaping will be so much easier.
Besides the in and outside will be covered with thin walnut veneer.
Sorry for the messy table.
Respectfully
Port Bulwark in place. The card stock came out very nice.
Now the starboard side. :)
Respectfully
The starboard bulwark installed.
Planking the inside and outside is next.post-967-0-53369400-1397428402_thumb.jpg
Respectfully
Bulwark planking and using the "eye-liner" method for caulking.post-967-0-42191500-1397451377_thumb.jpg
Respectfully
Guest
This topic is now closed to further replies.
