Frank,
Absolutely beautiful work with your rigging and sails. You certainly set the Bar very high (:-)
Michael
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Michael
Michael,
Thank you for your kind words!!
And to everyone else, thanks for the "likes" and for visiting the log!!
Frank
Hello,
I have been working on finishing the shrouds for the foremast and also pre-rigging and mounting the foremast top sail.
Shrouds and ratlines for the top sail
Shrouds and ratlines for the top gallant sail area
Foremast topsail ready to mount onto the yard
Blocks added to the rear of sail /yard
Blocks and pr-rigging done to the lower half of sail
Continuing on:
Foremast top sail ready to mount on ship
Sail mounted and halliard finished to mainmast stay
I now ran the rigging thru the ship to makes sure everything is where it should be. However, at this time, nothing will be fastened or leveled until all the sails are on the foremast and I am sure of where the lines will end on the deck. So everything is still loose!
Overview of where I am at this point with the installation of the sails
My next step is to rig the foremast upper stays and install the top gallant sail
Thanks for visiting,
Frank
You're doing a beautiful job with the rigging Frank, and she looks outstanding!  :dancetl6:
GEORGE
Hello.
Still working on mounting all the sails!
Continuing on, I now rigged and installed the middle foremast stay.
My next step is to work on the foremast topgallant sail.
Sail ready to mount onto yard.
Mounted on yard
Pre-rigged the topgallant sail prior to mounting on mast.
Topgallant sail mounted on foremast
The foremast topgallant sail halliard rigged to the mainmast stay.
At this point, most of the running rigging is not fastened to the deck until I am sure of where everything goes on the deck.
However, I did finish the rigging to the center rail.
View of the ship with all the sails mounted (but not leveled and set) on the foremast.
On a side note, I took the opportunity to head up to the Peabody Senior Center and had a lot of great folks help me mill out the base for my ship, using their equipment. I am still a few months away from finishing, but I wanted to get going on the case!
I bought some cherry and and milled out the shape I wanted.
The top groove will be where the plexiglass will be inserted and the side groove is where the felt covered plywood base with fit into.
The black felt will be put onto the plywood and wrapped around the edges and stapled to the back.
Over the next couple of months, I will work on finish sanding, staining, and sealing the pieces with polyurethane before assembling all the pieces.
Thanks for visiting and for all the previous "likes"
Frank
Frank,
Nice update. You're almost at home port. Case will add the final great touch.
Michael
Under the table:
Completed:
Vasa-Corel -
Thanks Michael,
I am still a few months away from being done, (Finish bowsprit sails, upper railing system, rigging of lower sails, anchor buoys, stern lantern and flags), but starting on the base is a nice little diversion and break from all the rigging on this ship.
Frank
Sure is beautiful Frank.  :)
GEORGE
Hello,
I have been working on the bowsprit topsail.
When I made the sail, I cutoff about 1/3 of the sail so that it would furl better.
However, I think I should have cut off about 1/2 of the sail instead. (this sail is unusually large compared to the yard) When I furled this sail, it still looks a little too bulky.
Oh well! I am pretty sure that when I put tension on all the running rigging attached to this sail I will be able to flatten it some more. We'll see.
Sail mounted onto yard.
Blocks and rigging added to sail
Sail and halliard rigged to platform
Finished foremast topgallant stay mounted to foremast and bowsprit platform
Blackened brass fittings rigged and mounted under platform
View of ship status so far.
Next I will be finishing the standing rigging from the bowsprit mast to the foremast lower stay.
Then I will work on attaching and mounting the spritsail.
Thanks for visiting and for the "likes"!
Frank
Hi Frank - outstanding work on those sails.
Thanks Mark!
As I stated above, I wasn't too happy about the bulkiness of the bowsprit topsail. However, I am confident I can repair the look when I finish the rigging. If not, back to the sewing machine!
Last night I furled the lower spritsail (photos coming soon), and I was much more satisfied with the way it looked on the yard.
Finishing up with the rest of the standing rigging now.
Thanks for your comments, it is appreciated.
Frank
Continuing to make some progress on the model!
I finished up all the standing rigging by installing the lines from the bowsprit to the lower foremast stay.
That should do it for the standing rigging.
I also finished working on and installing the last sail. The lower spritsail.
As with all the other furled sails, I took off 1/3 of the sail height in order to make the furling easier. Then I attached the sail to the yard.
I liked the way this furled sail turned out. (Better than the topsail!)
Pre-rigging of blocks and lines to back and front
I fixed the sail to the bowsprit and finished most of the rigging.
I left some of the rigging dangling until I rig the bowlines from the foresails. (It will be easier getting the bowlines in place before the rest of the lines are installed)
Overview of the model at its current state
Next, I will go back to finishing the rigging lines from the foresails and the bowlines from the main sails. (Basically, work on the lines between the foremast and mainmast)
Frank
Absolutely beautiful Frank. Absolutely beautiful!!  :)
GEORGE
Frank,
As you know..I have a folder of all of your sails work. Hoping to emulate your work, as well a Karl's, and (Ulises wonderful rigging). Not sure I can get to all of your levels of work. Wood is my friend, and I so enjoy those parts of the build, but cloth, and rigging, Hmmm? I will see about that next new challenge.
Though I do have great sages whom I am following (:-) and BTW my build is going soo slow (;-(
Your ship is so beautiful,Thanks for following mine as well.
Michael
Edited by md1400cs
Under the table:
Completed:
Vasa-Corel -
I really appreciate your mention. I have to say that your work is much superior, and I really men it.
Sincerely.
Ulises
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Hola Frank:
I am really pleased that the little help I provide to you with the sails has been translated into a superb realization. Congratulations!!!
:cheers:
Saludos Karl
Hola Frank:
Hi Karl!
Thank you for your "big help" in helping me get the sail sizes and configurations correct! Your very fine log got me started into finishing my Corel ship with the addition of sails!
Frank
Hello!
I was able to finish up some more rigging between the foremast and mainmast.
Main topgallant sail bowlines
Main topsail bowlines
Main lower sail bowlines (middle of picture on far side of sail)
Fore topgallant yard braces
Fore top yard braces
Fore lower yard braces
Lines finding their way to the deck railings
Overview of work between the foremast and mainmast.
One thing I am having a lot of trouble with is in trying to minimize the distortion of the main stays
due to all the lines and blocks being attached to them.
My next step is to finish up the bowlines on all 3 foremast sails!
Thanks again for visiting and for all the "likes"
Frank
Nice work Frank. The rigging's outstanding.  :)
GEORGE
Hello!
I did some more work on the foremast sail bowlines and I finished rigging the top spritsail braces.
The foremast topgallant sail bowlines also passing thru blocks on the top stay.
The foremast top sail bowlines also passing thru blocks on the middle stay.
The foremast lower sail bowlines
The top spritsail yard brace rigged
All the bowlines and spritsail braces passing thru the blocks on the bowsprit mast
The bowlines and braces at their final belaying pin locations
I am almost done with all the rigging on the ship.
The remaining lines to go on the ship are:
1. Lower spritsail sheet
2. Lower foresail sheets and tacks
3. Lower main sail sheets, tacks, and braces
4. Lower mizzen yard braces
I will install these lines after I finish the delicate upper railing system on the model.
So, my next steps are to:
1. Install and rig the stern flag pole and flag (while I can still get my hands in that area)
And
2. Install the upper railing system on both sides of the ship.
Thanks for visiting my log and for the previous "likes" !!!!
Frank
You've done an outstanding job rigging her Frank.  Kudos!  :)
GEORGE
Hi Frank -here is a picture of what I was talking to you about concerning the clear acetate with screen material glued on to simulate window panes.
Hi Mark,
Thanks for the photo. I totally understand now how you made the windows!!!
I will do the same on my lantern.
Thanks for all the help,
Frank
Frank,
Beautiful work. Nice update. She's almost ready to sail off and sink an hour later (:-)
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
