Well,the big box arrived yesterday,and,although I'm not supposed to start this model before I've got my new workshop,I just couldn't resist making a start!
This kit may not be the best as far as some people are concerned,but a 1:75 scale Victory for £260 is worth a try!
Instructions are a bit vague,but you just have to sit down and study the pictures for a while.
The wooden parts all seem to be very good quality,and fit together nicely so far.
After the first day I had the main bulkheads in place,and also the lower deck,which I am planking today.
First 2 pictures are a bit blurred,as I've just realised I still had my camera set up for taking photo's of the moon through my telescope,but it's all sorted now!
I haven't got a building slip,but have purchased a keel clamp which is already proving to be very helpful in turning the ship round easily.
More pics to follow as I progress,and I would welcome any input from anyone who has built this model.
Hello Keith
And here we go with another HMS Victory . I would like to wish you the best of luck with your build. And as you say for the price you cannot really fall off. I look forward to following this build with interest . Just take your time and really enjoy it. DAVID
At this rate of progress you will have caught up with me by next weekend
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Hi Kevin,
Just had a look at your build,(I'm green with envy!) If mine turns out to be half as good as that I'll be well pleased!
Cheers,
Keith.
Hi Kevin,
Cheers,
Keith.
thank you - but have you seen Gils - http://modelshipworld.com/index.php?/topic/485-hms-victory-by-gil-middleton-jotika-172/?hl=%2Bgil+%2Bmiddleton
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Day 3,and things seem to be going well at the moment. Only got another week before my new workshop arrives,so the ship building will come to a halt for a couple of weeks while I get it all kitted out.
Here's a couple more photo's.
I'm using a natural oak stain for the window frames,with a dark oak on the backing to set them off a bit. Will also use natural oak colour on the decking.Just got to cut a few holes in it then sand it down ready for staining.
Already got the next project- a Billings Cutty Sark that has had the hull partially built,then the chap got fed up with it,so I bought it off him for a quarter of the price of a new one,with fitting kit as well!
I'm sure you'll enjoy the many hours she'll provide. Could you elaborate on the nature of the fittings supplied by the Billings brand...thanks a bunch.
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Hi Keith
I am following along in the background.I know you log title says 'another'but to my knowledge(someone may correct me here)this is the only Billings version being built on this forum.I very,very nearly purchased this kit when Modelzone was closing down,but in the end decided they hadn't knocked enough off the price when comparing what I could get it for from other suppliers.I wish you all the best with your build and look forward to seeing how Billings have tackled the details on their kit.
Kind Regards Nigel
Currently working on Royal Caroline
I'll put some photo's of some of the fittings on later.I haven't opened the packet yet,but there are lots of metal parts,and it looks like all the gun trolleys are plastic,but I'm sure they'll be okay when painted up.
Rear deck in place ready for planking.
First of the side pieces in position.There are a couple of locating pegs on 2 of the bulkheads for this,so it is crucial that the bulkheads are built perfectly square,or this panel won't fit. I've marked the locating pegs.
Here's a few photo's of some fittings.I'm not going to take them out of their bags yet,as I'll probably end up losing some of them! The figurehead is a particularly nice,heavy,well detailed casting.
Guns,and all other metal parts seem to be very good quality as well. All the deadeyes and blocks are wood,not plastic.
The gun trolleys,although plastic,are very sturdy and well detailed.I think they will look good when painted.
The front columns in this kit are plywood,and after many attempts to bend it round the formers,I've decided that it's easier if I make them out of some planking instead.A bit more filling and sanding should do the trick.
So far,this is the first bit of this kit that I've had to alter,but I'm sure it won't be the last!
Hello Keith
Looks like things are coming on fine, and I reckon you are correct about altering things as you have done with the roundhouses. Do Billing Supply the copper plates for this kit.???? Keep up the good work Keith And enjoy it. DAVID
Edited by Shipyard sid
Hi David,
Yes,I'm really enjoying it so far,even if the instructions are barely understandable! Still,half the fun is working things out.
Unfortunately,Billings don't supply the copper plates. I wasn't really expecting to find them in the box seeing as this kit is priced so reasonably.
Looks like I'm going to have to do a bit of shopping around for them.From what I've seen so far they're quite expensive!
Cheers,
Keith.
Hello Keith
The ammount of plates on the caldercraft victory is 2600 which would cost £65 so you woul need to pay about £60 with your ship being slightly smaller. The best option may be copper roll, but plenty of time yet., keep enjoying it. DAVID
Good old Billings don't give you any window framing,and as far as I can see from the "instructions",you're supposed to just draw or paint them on to the acetate.I thought this wouldn't look very good,so I'm making my own by slicing some thin strips off some 1/2mm planking,and putting them in the frames. A bit tedious,but one of those jobs which can be done a bit at a time while you're waiting for something else to dry!
Hello Keith
I am not sure how you are fitting these windows, but it may be an idea to fit them on the rear face of the profile to give a nice effect. It may also be easier than fitting them in, as the strip would just fit on the back of the profile . Also styrene strip would be a good choice for the frames instead of the strip you are splitting. You may already be doing this, but I am not sure. Keep enjoying it. DAVID
Hi David,
I'm fitting the uprights on the rear face,and just the cross pieces in. The wood strip actually cuts quite easily with a pair of scissors!
Thanks for the input though,and I'll keep the styrene strip in mind for my next build.
Cheers,
Keith.
Hi Shihawk, I think that will be 3 of us making this kit now.I look forward to your log.
New workshop arrives today,so Victory will be on hold for a couple of weeks while I kit it all out.Mind you,I might be able to squeeze an hour or so in the evenings!
just a suggestion - instead of using acetate, try pva glue watered down or one of the widow making film liquids, it would give it a more realistic appearance
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
glad to see you back . thats one great workshop and so tidy i hope it lasts :D Im green with envy when i see all those power tools ,something i have been considering myself since i started the same build as you .We will need all the help we can get ,those intructions are pretty lousey.I have been trying to pick up a few hints from the cc builds but apart from some helpfull pictures its an intirely different kit  Have you tried the CC site  some measurements and diagrams of wales etc which arent even mentioned in my instructions  ? I will be following you with interest as my build will be slow due to some alterations im atempting so get back to work AND POST PLENTY OF PICTURES.  Enjoy!!!
